Results 1 to 3 of 3
Reload Thread: Amp connection
    Johnfin's Avatar
    Johnfin is offline Junior Member
    Apr 2017
    Florida
    1 Post(s)
    Amp connection
    I have noticed in most amp instructions they wire it up to the battery. If i put mine in the trunk, does that mean it will be on all the time.
    beatzboi's Avatar
    beatzboi is offline Member
    Jul 2014
    United States
    129
    2 Post(s)
    41 Post(s)
    Re: Amp connection
    No, there is a remote wire. The remote wire goes to your radio wiring harness so when your radio turns on, it signals the amp to turn on.
    You can however, jump a wire from power to remote terminals on the amp, and the amp would constantly be on.
    I don't recommend jumping from power to remote tho. More of a temporary use type thing.
  3. Thanks celicaboy84 thanked for this post
  4. #3
    celicaboy84's Avatar
    celicaboy84 is offline Junior Member
    Apr 2017
    Kent, Wa
    Re: Amp connection
    Quote Originally Posted by beatzboi View Post
    This is correct. You need the power wire from your battery, a remote turn on from the back of your head unit and a ground wire to get your amp turned on.
    The remote lead wire will signal your amp when to turn off and on. If your radio is on, the amp will be on. If it is off, the amp will turn off
