Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: help i need wireing help..
    big scott's Avatar
    big scott is offline blazin low, and loud
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    hi guys,
    im about to order my amp ( ppi 1800.1 ) it calls for a 160amp fuse.
    ok were to start......
    right now i have 4ga run to my rf amp and 8ga to my 6x9 amp. so i have 2 runs from battery to back of truck.
    now the ppi calls for 1/0 wire and external fuse.
    im trying to figure out what i need to order ( like blocks/ fuse holders , ect.. )
    now do i have to run 2 fueses on this 1/0 wire ? ( 1 at batter and the other at amp ? )
    see im confused and what to do.
    but heres the kicker i plan on getting 2 more ppi amps ( PPI BK120.2 and Precision Power PPI BK210.2 )
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: help i need wireing help..
    You need a 0 gauge kit. And a distro block
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    Quote Originally Posted by mylows10 View Post
    is that 1/0 ? or is there a 0ga ?
    see im new at this.
    also with that amp do i put a fuse at battery and amp ?
    with all 3 amps i want it adds up to 205a so what size fuse do i need at battery ?
    im just confused on what to get/do with this setup.
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    250 at the battery. The distro block. Get a fused one
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    ok thanks.
    im looking at this distro. block. its a 3-way but i can only get it with a 150a fuse. ??
    Fuse Block, Fuse Blocks
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Quote Originally Posted by big scott View Post
    ok thanks.
    I can order everything you need. And send it to you
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    what info do you need ??
    Apr 2014
    THE SOUTH
    110
    62 Post(s)
    see im new at this.
    1/0 is the same as 0 gauge, just different names. If none of the amps you are running have internal fuses, and the amperage adds up to 205, you can run a 250a (external fuse at battery).
    Head Piece - Pioneer AVH-X3600BHS
    Door Front - Factory BOSE for now
    Door Rear - Factory BOSE for now
    Tweets - Kicker KST20
    Mids & Highs Amp - Factory Bose for now
    Subs Amp - HiFonics BRX2400.1D
    Subwoofer(s) - (8) Kicker 10CVR104 (Old Schools)
  9. #9
    Apr 2014
    THE SOUTH
    110
    62 Post(s)
    see im new at this.
  10. #10
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    ya that what im trying to figure out as the 1800 takes a 160a ( external ) the other 2 amp have internal fuses. 1 amp takes a 25a the other takes 20a fuse.
    so i was thinking a 250a at battey the 1/0 to a distro. block with 2 inputs and 3 out-puts. the 1 out-put putting a 160a ? right at the amp.
    does that sound right ?
  11. #11
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
  12. #12
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Don't worry about the amps fusing. Opposed to the wires fusing. The fusing on the wire protects the wire not amp so with that being said you won't or shouldn't have issues with a 250 amp fuse by the battery. Then fuse the distro blocks out puts accordingly for the wire used there
  13. #13
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    ok that makes cents.
    i have another ?
    down the road i plan on getting another 1800rms amp and as said it takes 1/0 wire.
    so running 2 big amp should i run 2- 1/0 from battery back ? or will 1- 1/0 be fine.
  14. #14
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    i have another ?
    Depends in the amps and wire you use
  15. #15
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    ok when done i will have 2- ppi 1800.1 amps // 1 ppi bk120.2 and a ppi bk210.2 amp.
    so thats 4 total amps.
    the 1800 say 1/0 ,, the other 2 smaller amp take 8ga.
    the 2 smaller amps have fuses on amp. the 2 biggers amps take 160 external fuse.
    so im just trying to get what i need now so when i get the other 1800 ill allready have the wireing ready for it.
    that why i asked if i should run 2 - 1/0 wires from battery or will 1 - 1/0 be fine.
    and if i run 2- 1/0 ill need 2 fuse holders for both wires and both would be 150a fused.
    im just trying to do this right, the first time.
  1. Need wiring help and info
    By Gunit412 in forum Wiring, Electrical and Installation Help
    Last Post: 05-29-2005, 01:11 AM
  2. Need wiring help fast!!
    By robert97dodge in forum Subwoofers
    Last Post: 05-04-2005, 02:26 PM
  3. Viper 800 need wiring help
    By chriso in forum Car Video, Security and Electronics
    Last Post: 02-20-2005, 03:46 PM
  4. Need wiring help
    By kisswahili in forum Amplifiers
    Last Post: 03-08-2004, 07:49 PM
  5. Need Wiring help.
    By Qckrun in forum Wiring, Electrical and Installation Help
    Last Post: 08-25-2002, 02:29 PM
