Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: help i need wireing help..
  1. #16
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    Re: help i need wireing help..
    You can if you like. You know the bk1800 amps are strap able. Right ? So you have to line match
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  2. #17
    big scott's Avatar
    big scott is offline blazin low, and loud
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    ok i have no idea what that means and what is a line match ? sorry i dont know.
  3. #18
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    Quote Originally Posted by big scott View Post
    That's fine. Just means you'll need to use a splitter for the 2 amps. Then adjust the gains with a dmm to get the voltage on each smp to match
  4. #19
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    ****, i was not even thinking about running rca's to both sub amps. ok i do have rca splitters so i can run both sub amp from 1 rca.
    thanks for the help. theres a lot to learn.
    i know the basics but wow there much to this stuff.
    what can you set me up with ??
    if you like you can pm me with what you have that ill need.
  5. #20
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    I have 1 more ?
    right now ill be runing 2 amps.
    160 fuse
    30 fuse
    at battery can I get a 200 amp fuse .?
  6. #21
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    O for got to ask,
    what do you guys use on the power/ground wire were it goes into the amp?
    My amp is a ppi 1800 is will take 1/0 and thats what im going to run to it. But I dont want to just push the wire into it.
    please give link, im not sure what to get, thanks.
  7. #22
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,525
    29 Post(s)
    2249 Post(s)
    O for got to ask,
    Unless your trying to connect a 1/0 gauge wire to a 4 gauge only port then you could use a 0 gauge adapter to 4 gauge pin, but since your amp accepts 1/0 gauge sticking the wire right in isnt an issue?
  8. #23
    big scott's Avatar
    Apr 2014
    edgewood, md
    44
    3,575
    22 Post(s)
    1134 Post(s)
    Well im useing knu ofc wire. Its oversize and will be hard to just push it in. I have a hard time puting the wire in ring terminals I have. I have to tape the wire up really tight then gingerly twist it in.
    could it be done without haveing wire bunch up or fold back, maby.
    Im just saying it would be easier to put the wire into something then slip it into the amp.
  1. Need wiring help and info
    By Gunit412 in forum Wiring, Electrical and Installation Help
    Last Post: 05-29-2005, 01:11 AM
  2. Need wiring help fast!!
    By robert97dodge in forum Subwoofers
    Last Post: 05-04-2005, 02:26 PM
  3. Viper 800 need wiring help
    By chriso in forum Car Video, Security and Electronics
    Last Post: 02-20-2005, 03:46 PM
  4. Need wiring help
    By kisswahili in forum Amplifiers
    Last Post: 03-08-2004, 07:49 PM
  5. Need Wiring help.
    By Qckrun in forum Wiring, Electrical and Installation Help
    Last Post: 08-25-2002, 02:29 PM
