Results 1 to 7 of 7
Reload Thread: Dumb question
    darkmatter's Avatar
    darkmatter is offline Junior Member
    Jul 2012
    Pa
    2 Post(s)
    Dumb question
    If bridging an amp makes more power (in watts) wouldn't the output be louder?
    example 60X4[email protected] RMS or [email protected] RMS
    Just a bit confused because not getting the volume that I figured I would be getting.
    michaellane's Avatar
    michaellane is offline CarAudio.com Veteran
    Oct 2005
    tx
    31
    11,533
    29 Post(s)
    814 Post(s)
    Re: Dumb question
    Quote Originally Posted by darkmatter View Post
    example [email protected] RMS or [email protected] RMS
    Well yes more watts typically means louder. Explain exactly what you have going on
    http://www.caraudio.com/forums/buyer-seller-feedback/414807-michaellane-feedback-if-i-bought-you-traded-i-sold-you-something.html
    darkmatter's Avatar
    Jul 2012
    Pa
    2 Post(s)
    Re: Dumb question
    I went from a Pac Soem4 to a phoenix gold R500.4 amp in 4 channel mode to factory speakers to an Audiocontrol LC2I to the Phoenix Gold Amp bridged to Arc Audio Arc 6.2 speakers. Not sure what is going on when I set it up using a -10db 1khz test tone and a dmm per Audiocontrol's instructions the gain on the amp and the sound was low. When I turned down the LC2I and the gains up on the amp as a test it sounded a little louder. I set it both ways when bridged to 150 watts so I am a bit confused. I figured 150 watts would sound the same either way it is set.
    pickup1's Avatar
    pickup1 is offline CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,467
    19
    7 Post(s)
    838 Post(s)
    Re: Dumb question
    where is the gain set on the amp now?about half?
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    11,052
    897 Post(s)
    Re: Dumb question
    Generally when you bridge two channels the combined output power is just the sum of the two. It's still using the same components so it's unlikely it can create MORE power.
    i.e. 60w x 2 bridged would produce 120w x 1 (not 170w).
    vaiboy's Avatar
    vaiboy is offline Senior VIP Member
    Sep 2006
    Phoenix, AZ
    273
    36 Post(s)
    Re: Dumb question
    When you double the power to a driver the output should increase by 3dB. The problem is you are comparing 2 different drivers too, if the efficiency of the factory drivers is higher than the Arc Audios you may not get any increase in output.
    darkmatter's Avatar
    Jul 2012
    Pa
    2 Post(s)
    Re: Dumb question
    Ok thanks everyone. That's what I figured Vaiboy. I will say this the Arc Audio speakers are cleaner and crisper sounding.
  1. dumb question
    By leighton in forum General Discussion
    Last Post: 05-20-2002, 05:09 PM
  2. dumb question
    By ace7733 in forum General Discussion
    Last Post: 04-23-2002, 07:33 PM
  3. just a dumb Question
    By kicker in forum Subwoofers
    Last Post: 04-18-2002, 08:49 AM
  4. Really dumb question-need help
    By bdog4fosgate in forum General Discussion
    Last Post: 03-18-2002, 12:16 AM
  5. dumb question....but serious
    By audioman in forum General Discussion
    Last Post: 12-30-2001, 11:22 AM
