Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Smoke coming from amp?!
  1. #16
    Dwayne614's Avatar
    Dwayne614 is offline Junior Member
    Apr 2014
    Columbus, OH
    17
    11 Post(s)
    Re: Smoke coming from amp?!
    Quote Originally Posted by hispls View Post
    So let's assume that OP uses Ohm's law to calculate what voltage it should take for that amp to make the "rated" 2000W into his nominal impedance. Then what? Which method do you think would blow it up faster, backing off a click of the volume knob when it starts to audibly distort or trying to turn up the gain until he sees 45V?
    Naught for nothing, but if your amp is on fire you don't know everything, and if you don't really know what you're looking for, you should probably avoid "deals" on electronics to avoid problems like this. There's 100 junk brands out there. As people catch on to poor quality and untruthful claims these companies simply slap a different brand name on things, change the heatsink and fool a new round of suckers who believe that they're going to get something for nothing.
    Best to verify that the gound is firmly connected to the amp, the terminals are well secured, and you have selected a good spot on the frame of the vehicle and sanded it down shiny to connect the other end. If you have verified your ground is good there's a problem with your amp.
    It's the first time it's done this, i positioned the ground wire a different way this time (when the rubber melted) I'm sure that was the reason, I've changed the position up again and I'm sure it's not going to happen again.. Thank you
  2. #17
    Dwayne614's Avatar
    Apr 2014
    Columbus, OH
    17
    11 Post(s)
    Quote Originally Posted by Jes 42 View Post
    Shoot west down I-70 about 2 hrs and i'll sell ya a quality setup bro.Hook it up and all for a nominal fee of course.
    If something ever happens to my equipment then I'll consider this, but I'm not giving up until something fries or gets stolen. Sh*t happens..
  3. #18
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    Who said it can do rated? I didn't...
    When an amp has lies for ratings, you can't tune it properly. When a person has crap equipment and isn't properly educated on the subject of sound systems, do you think they will be able to audibly tell when to back off the volume knob? Gimme a break......
    I bet you get a kick out of trying to put people down over the internet but deep down inside you live a sad lonely life.
    i wasn't even trying to put you down. I initially said you were uneducated in car audio equipment and installation, you called me a dick. So I responded accordingly.
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  4. Likes Freeman liked this post
  5. #19
    MakkMar10's Avatar
    MakkMar10 is offline Bangin on a Budget
    Mar 2014
    SoCal
    411
    189 Post(s)
    Started from the bottom....
    Attached Thumbnails Attached Thumbnails Smoke coming from amp?!-00b0b_ifg8okl7qza_600x450.jpg
  6. #20
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,127
    15
    38 Post(s)
    4159 Post(s)
    Quote Originally Posted by Beatin' View Post
    The point being your whole "use a dmm to set gains by measuring voltage" theory falls apart here. If someone has good equipment and has half functioning ears and brain they can easily tell when the sound distorts, and if they soft-clip a bit with decent quality gear that's installed correctly it is highly unlikely that they will cause fires. Unfortunately your method to try to retard-proof the gains still won't work for retards that can't correctly connect a ground wire or believe the number printed on the side of their swap meet amp.
  7. #21
    garychoffmann's Avatar
    garychoffmann is offline CarAudio.com Elite
    Mar 2011
    Missouri
    1,978
    6 Post(s)
    545 Post(s)
    Quote Originally Posted by WillMar10 View Post
    now your queeer?
    What are we supposed to take from your post? Square subs mean you made it?
  8. Likes Freeman liked this post
  9. #22
    yogegoy's Avatar
    yogegoy is offline Senior VIP Member
    Dec 2013
    San Jose, Ca.
    312
    97 Post(s)
    Before you continue, I suggest to fuse all your positive lines before you end up with a car bonfire. It's obvious you are shorting out your main power lines, it might power up but I know your amp is now bar-B-qued.
  10. #23
    MakkMar10's Avatar
    Mar 2014
    SoCal
    411
    189 Post(s)
    Quote Originally Posted by garychoffmann View Post
    now your queeer?
    Aye just goes to show we all were young an dumd....
  11. #24
    Beatin''s Avatar
    Nov 2012
    MI
    998
    574 Post(s)
    what if they have a bandpass box.
    voltage be dippin'
  12. #25
    Dwayne614's Avatar
    Apr 2014
    Columbus, OH
    17
    11 Post(s)
    Fixed the problem, no more smoke or anything if anyone cared...
  13. Likes serjr711. liked this post
  14. #26
    yogegoy's Avatar
    Dec 2013
    San Jose, Ca.
    312
    97 Post(s)
    Quote Originally Posted by Dwayne614 View Post
    So ever found out what the cause was?
  15. #27
    Dwayne614's Avatar
    Apr 2014
    Columbus, OH
    17
    11 Post(s)
    Quote Originally Posted by yogegoy View Post
    I guess my ground port was getting too hot and the plastic was melting because they where touching
  1. Please help! Smoke coming from amp!
    By ZeroFury in forum Wiring, Electrical and Installation Help
    Last Post: 07-08-2013, 02:17 PM
  2. Static noise coming from amp?
    By i like guns in forum Wiring, Electrical and Installation Help
    Last Post: 05-07-2006, 05:53 PM
  3. smoking coming from voltage meter? whoa.. helpppp
    By bran_zimm in forum Wiring, Electrical and Installation Help
    Last Post: 07-10-2005, 11:12 PM
  4. smoking coming from my voltage meter.. whoa wtf... help
    By bran_zimm in forum General Discussion
    Last Post: 07-09-2005, 01:42 PM
  5. smoke coming from ports...........
    By basshead20 in forum Subwoofers
    Last Post: 01-14-2005, 01:56 PM
