Results 1 to 4 of 4
Reload Thread: 2014 Camry Amp ?
    rick1967's Avatar
    rick1967 is offline Junior Member
    Feb 2014
    Lafayette,La
    14
    3 Post(s)
    2014 Camry Amp ?
    I have a 2014 Camry with the base 6 speaker system. I am in the process of adding Polk Audio 6x9's. I would also like to add amp to the system( 4 or 5 channel ). What all is required to install an amp to this system ? Amp mounting location Thanks in advance!! RICK
    tat2bass's Avatar
    tat2bass is offline CarAudio.com Elite
    Aug 2011
    Cali
    1,680
    614 Post(s)
    Re: 2014 Camry Amp ?
    Questions that need to be answered and then I can give you some suggestions.
    1. Budget
    2. Are you going to add subs or just speakers?
    3. Will you be adding an aftermarket headunit?
    4. Will you be doing the work or paying a shop to do it?
    rick1967's Avatar
    Feb 2014
    Lafayette,La
    14
    3 Post(s)
    I may add a 10" sub later
    I would like to keep the factory unit
    My budget is about $300-$400 and I can do the work myself, I am just not familiar with these integrated units.
    Elektron82's Avatar
    Elektron82 is offline Junior Member
    Oct 2006
    Tampa, FL
    Just my 2c contribution:
    I am keeping the stock HU since it has settings for other stuff in the car, I like it, and I feel and have seen other posts on that agree that SQ is ok. I am putting in a RF prime 500 and dayton 15" today. I saw a post that I can dig up if desired where someone made a shelf to hang from the rear deck for the amps. I am putting my amp on the box. Using turn on from the cig lighter and also to power line converter (I am fusing). I am connecting the line converter right to the rear speakers (solder). Power wire through awsome factory grommet on passenger side. There should be a good ground on strut tower brace.
  1. 99 Camry Amp hookup
    By West in forum Wiring, Electrical and Installation Help
    Last Post: 01-22-2012, 12:32 PM
  2. Rocker Switch Help Amp/LEDs 2005 camry
    By Dan.Wood in forum Wiring, Electrical and Installation Help
    Last Post: 04-25-2009, 12:06 PM
  3. Camry 2007 Dash Kit + Amps
    By CamryMTX in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 06-07-2008, 06:39 AM
  4. Help connecting amp to stock head unit in 2003 camry
    By hiphopdrunky in forum Wiring, Electrical and Installation Help
    Last Post: 10-13-2005, 02:17 AM
