Results 1 to 5 of 5
Reload Thread: New Memer Questions on an old-school amp
    nasakid's Avatar
    nasakid is offline Junior Member
    May 2004
    Houston Area
    New Member Questions on an old-school amp
    Howdy! I'm new to the forum, but not to the car audio world. I used to run 2 Kicker Comp 12's with Alpine door speakers in an old Dodge truck, and it was a great sounding system. I have been out of building systems since the mid-90's, and I'm working on a small system to give my SUV a little more thump. It's a Dodge Durango, and once my Infinitys blew out, I replaced them with Infinity Kappas. They are lacking in bass, so I'm putting a Kicker Comp 12 in a box and planning to power it with my old Autotek 7050 in 4Ohm mono. I'm running the input signal off the rear door speaker into a line level converter, then to the amp. I'm planning to use a 3-way fuse distribution block (Tsunami) to allow for quick disconnect of the remote, power, and ground wires so I can take the box (amp mounted to box) out quickly if I'm going fishing or having to leave my truck somewhere for an extended period of time (anti-theft in mind).
    Now the question:
    Do I have to worry about this old Autotek being reliable or blowing? It hasn't been powered up in probably 8 years, but it was working fine up until then. Just want some opinions on people's experiences with older amps and what I should expect. If it ends up blowing, what amp should I replace it with for my application? I like how clean this Autotek is, so I'd want something in that quality range.
    Rockman's Avatar
    Rockman is offline CarAudio.com Elite
    Nov 2002
    topeka
    518
    Re: New Memer Questions on an old-school amp
    My 15 year old Crutchfields are still running fine. Only problem I would see in an old amp is maybe the power supply capacitors drying up or something. Run it. If it dies buy a new amp.
    Car 99 Toyota Solara SLE V6
    HU Clarion DXZ835MP
    Front Speakers Infinity 6 1/2 Kappas
    Front Amp Crutchfield CR4X50
    Subs Kicker 12L7's
    Harrison Fmods
    Sub Amp PPI PC 2600's
    nasakid's Avatar
    May 2004
    Houston Area
    Rockman,
    Are you running the in-line Harrison FMods (look like RCA Jacks) on your subs? How do you like them? I just ordered a set for my sub - 100Hz Low pass.
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    2,271
    183 Post(s)
    Your old school Autotek will be just fine.....I do so love old amps heheheheh
    Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
    ____________
    refs:
    Type-S Texan ............Xtremebass5
    NE14MX ........Grinder1989
    NJack2AF
    .............Jameseypoo
    Randyrsx ..........Bagdntagd
    M3Transporter......Teggybwoy
    RJ Sclafani...........Zeuslicious
    Saltyreefguy........Qkassidyw
    Qtrhorse..............Nismos14
    Pistonsfan70........4nine
    SlainNothing.........Orangelss
    [email protected]............Louisiana_CRX
    SW9152..............DukeNut
    nasakid's Avatar
    May 2004
    Houston Area
    Got it hooked up a couple weeks ago. It rocks out like it did in 1991! I might upgrade to a more powerful amp for the sub eventually and use this one to drive the highs and mids. Looks like Ebay is a good source for old Punch, Autotek, Soundstream and Hifonics amps. I like the old ones b/c they were just built better.
  1. sub amp to home receiver
    By PV Audio in forum General Discussion
    Last Post: 05-20-2004, 11:34 AM
  2. A few Amp Questions
    By omnipseudo in forum Amplifiers
    Last Post: 04-29-2004, 04:13 PM
  3. HELP!! no output from NEW concept amp
    By bobo244 in forum Wiring, Electrical and Installation Help
    Last Post: 02-08-2004, 03:28 AM
  4. Got my amp yesterday.
    By 80_Cutlass_mn in forum General Discussion
    Last Post: 01-11-2004, 01:00 AM
