Results 1 to 11 of 11
Reload Thread: Amp went out need new Amp - NOVICE need advice
    hotbox's Avatar
    hotbox is offline Junior Member
    Jan 2014
    TX
    2 Post(s)
    I will post my setup below, but the fact is my amp went out and I'm feeling very low because it. I've tried asking friends but they keep telling me different things. I'm on a low budget $100-150 range. It has to fit in a 2005 Silverado single cab. The amp I had before was only 2inches wide so it wasn't that bad fit pretty well. Had the setup for over 5 years until it gave out today. I just want something the same if not better if I could for the price thanks. Again don't know much about car audio so any help would be helpful thanks.
    EDIT: I'd go ask the local shops but I live in a remote area and it would be a 2 hour trip to do so, I'd like to go with some idea of what I would be looking for.
    (I bought them for sentimental reasons...)
    TWO - JVC CS-WG1000 800-watt 10" Car Subwoofers
    Features include:
    10-in. subwoofer
    800 watts max music power
    Glass fiber cone with rubber surround
    Aluminum die-cast basket
    Aluminum/El wire 4-layer dual voice coil
    Rubberized PVC gasket
    Black polycotton spider damper
    Nickel-plated screw terminals
    25-1500Hz frequency response
    4 ohms impedance
    The people at the shop stuck me with this amp, at the time I was just happy getting one.
    NT Power NT1832 Amp
    Product Specifications:
    Channel: 2
    4 Ohm RMS: 120x2
    2 Ohm RMS: 150x2
    Mono RMS: 300
    Max Power: 1200
    Dimensions: 350 x 244 x 49 mm
    Remote: No
    Product Features:
    CHROME PLATE TOP
    FULL MOSFET POWER SUPPLY
    2 OHM STABLE
    VARIABLE HI PASS: 50 - 250 HZ
    VARIABLE LOW PASS: 50 - 250 HZ
    VARIABLE 12dB BASS BOOST @40HZ
    FREQUENCY RESPONSE: 10 - 30K HZ
    S/N RATIO: 98 dB
    T.H.D.: 0.02 %
    FULL SELECTABLE CROSSOVER
    4 GAUGE POWER/GROUND CONNECTION
    CIRCUIT OVERLOAD PROTECTION
    INPUT SENSITIVITY CONTROL
    SOFT TURN “ON” SWITCH
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Re: Amp went out need new Amp - NOVICE need advice
    The shop boned you man that amp no bueno anyway look for an audiopipe for $150
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    hotbox's Avatar
    Jan 2014
    TX
    2 Post(s)
    Quote Originally Posted by mylows10 View Post
    I figured as much, I wasn't sure cause I had never heard of the brand before. Any particular model of audiopiple?
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Aspm 1500
    hotbox's Avatar
    Jan 2014
    TX
    2 Post(s)
    Aspm 1500
    I was worried about the dimensions but at 342x154x49mm it's even smaller than the one I had. Thanks for the help!
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Quote Originally Posted by hotbox View Post
    Cool
    hotbox's Avatar
    Jan 2014
    TX
    2 Post(s)
    So I got the Audiopipe APSM 1500 a few days ago, sounded great for about 3 days but stopped working last night. The light on the amp is still on, not flashing in protection mode though. Any suggestions? Did I get a dud? Should I exchange or return it and go with a didn't amp? I'd appreciate any help thanks
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,768
    82
    2 Post(s)
    2447 Post(s)
    where did you get it from? does it still have a warranty? what ohms do you have it wired to?
    you may have just got a bad one. i currently have a Audiopipe apsm-1500 and have had no problems with it, and use to have the apsm-2000 for a bit til i sold it.
    [B]02 KIA SPORTAGE
    2 Sundown SA 12 Dual 4's
    Enclosure: 4 Cubes Net @ 34ish Hz
    Soundstream Ta.3kw @ 1 ohm
    Stock 70a Alt ~ XS D3400 & 1 Kinetic HC1800 ~ 2 Runs Bullz Audio 1/0 ~ Bullz 1/0 Big 3
    Current Build Score ~ 143.5 On The Dash
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  9. #9
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Check grounds and voltage at the amps power and remote.
  10. #10
    hotbox's Avatar
    Jan 2014
    TX
    2 Post(s)
    I have warranty, bought it on eBay u have 60 days to return it not worried about that. Just want to make sure I didn't do something wrong in the wiring. I'll test out the voltage and ground tomorrow check back the, thanks.
    Edit: I wanted to add that I used all the old wiring that I had before just used changed the fuse to the one it came with. I have no idea how the subs are wired inside the box.
  11. #11
    hotbox's Avatar
    Jan 2014
    TX
    2 Post(s)
    So I got the replacement amp, still not working. Changed rca's, tried ipod rca, rewired subs and did some testing. Seems like its the subs that gave out. I've had them for almost 7 years as well as the old amp. I guess it was just it's time. Any advice on subs that would go well this this amp? Keep in mind I have a single cab truck. The inclosure i had could support the depth of my old subs which were 4.88 inches but just barely. Should I go shallow mount or is there draw backs to it?
    Thanks alot for all the advice I've gotten so far in this forum, you guys rock.
    Edit post: By the way, right now I have these in mind Amazon.com: Pioneer TS-SW2501S4 10-Inch Step Up Shallow S4 Subwoofer: Car Electronics
    Although I really wanted these http://www.amazon.com/Pioneer-TS-W26...442404&sr=1-19
    But the mounting depth is 5 1/2 inches that could pose a problems :S
    But any suggestions would be nice, thanks.
  1. need help picking out a new amp today.
    By kingisback06 in forum Amplifiers
    Last Post: 07-06-2008, 09:32 AM
  2. Amp crapped out on me. Need new amp
    By orphe in forum Amplifiers
    Last Post: 04-10-2008, 10:50 PM
  3. Heyt Need Help On Picking Out A New Amp
    By wicked_rider_ in forum Amplifiers
    Last Post: 05-27-2004, 01:41 AM
  4. need new amp......
    By cFlatt in forum Amplifiers
    Last Post: 11-13-2003, 10:33 PM
  5. need new amps
    By Alphafrog1 in forum Amplifiers
    Last Post: 04-04-2003, 04:54 PM
Tags for this Thread
