Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 16 to 30 of 141
Reload Thread: Audiopipe APCL-15001D on SMD Amp Dyno at 0.5 ohms Dynamic RMS
  1. #16
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Re: Audiopipe APCL-15001D on SMD Amp Dyno at 0.5 ohms Dynamic RMS
    Quote Originally Posted by neo_styles View Post
    Exactly. Burst power is meaningless. Might as well be the manufacturer's posted MAX spec. Will be interested to see what it does on the certified ratings, though.
    But but peak power lmao
  2. #17
    Timmy13091's Avatar
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Quote Originally Posted by bbeljefe View Post
    And what is music but a series of short bursts? The dynamic burst test on the AD-1 is the closest simulation to music one can get on resistive load and music happens to be what 99%+ audio amplifiers are used for. Peak ratings, on the other hand, are merely expressions of power in a square wave and thus, are indeed meaningless.
    Not to mention, this is the same dynamic burst test that any other amplifier can be subjected to so even though it isn't some exact replication of a music track, it is an accurate and repeatable method of testing more than one amplifier's performance in an "all other things being equal" environment... which is requisite of any test which seeks scientific accuracy.
    Still don't see what your getting at .. This isn't a long enough period to be a burp or music we are talking milla second burst .. And on top of that they were saying the dc 5k was doing 8k+ on this test .. Your not seeing that in your car either lol .. Bottom line this test is worthless lets see the 1 ohm certified runs if were gunna use that crap .. Or clamp it on music with subs in the car .. Will be nothing close to this inflated peak power bs
  3. Thanks Side Show thanked for this post
    Likes supereikenator liked this post
  4. #18
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    My point is the uninformed consumer is going to see this test, see what a "deal" this amp is, take it home, set their gains to that point, and fry their equipment. All because some video online told them they can do it. I see the test as moot and misleading.
    Spotify: http://open.spotify.com/user/neo_styles/playlist/6t9ru42j0wbEsuo4bXqXD8
  5. Likes jrdnhsnbrg, Side Show liked this post
  6. #19
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    ^ dam straight, like anything you get what you pay for. (unless it says JL on it) lol
  7. Likes jrdnhsnbrg liked this post
  8. #20
    bbeljefe's Avatar
    bbeljefe is offline CarAudio.com Elite
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Quote Originally Posted by Timmy13091 View Post
    The test track is ten seconds of bursts, not a millisecond of burst.
    Owner, Audio Anarchy, LLC
    2915 Youree Drive, Shreveport, LA
    318-780-6149
    https://www.facebook.com/AudioAnarchyLLC
  9. #21
    bbeljefe's Avatar
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    So you're arguing that uninformed people wouldn't (or don't already) otherwise buy these amps, take them home and then damage their equipment?
    The video doesn't tell anyone they can do anything. It's a bench test of an audio amplifier.
    318-780-6149
  10. #22
    bigdwiz's Avatar
    bigdwiz is offline Old School Rulz!
    Oct 2010
    NC
    273
    1 Post(s)
    48 Post(s)
    Yes, this test was done on a machine, not in a car. What's the difference? I was using a big power supply instead of an alternator and batteries...that's it!
    The Amp Dyno uses resistive loads and those of you who are "clamping" your amps to get the power are actually getting VA or Volt Amps, not Watts if you are using speakers instead of resistors. It's electrical engineering, but a pretty simple explanation. Reactive loads (speakers) have electrical phasing which has to be taken into account in order to obtain the power factor and Wattage measurement. It's not as simple as you think to obtain wattage measurements with using speakers, but using resistors, yes it is (along with a THD/clipping meter). The AD-1 was designed by the head engineer at RF for over 10yrs and the designer of the impressive T15kW. I test all of my amps now using the AD-1 and it's a consistent way to get results, and yes, they are accurate.
    I specifically put the extra text in the video explaining the dynamic RMS power mode, but doubt most people will watch and read it. Some will just shake their heads and say "NO Way" and go back to keyboard commando mode. I'm just an audio enthusiast who likes to test amps. I didn't really care how this amp did on the Dyno, but it's fun when an amp goes beyond my expectations.
    Back to the explanations on why this test wasn't valid, just wanted to break for some facts...
    See my Old Skool Car Audio tests on my YouTube channel: http://www.youtube.com/BigDWiz
  11. Thanks corrie32 thanked for this post
    Likes corrie32, bbeljefe liked this post
  12. #23
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Quote Originally Posted by bigdwiz View Post
    I actually read through the test, surprise surprise! That's why I actually admitted I was wrong in calling it a fake result on Facebook, because it is so unbelievable. I do really want to see certified test runs, though.
    2013 Ford Flex Ecoboost AWD “Turbo Fridge”
    Shok Triton 15”
    3.8 cubic feet tuned to 32
    DC 1.2k
  13. #24
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    this amp in question requires a 100A fuse. With some simple math, we can figure out what it may put out RMS-wise at 1ohm
    14.4v x 100a = 1440watts
    1440watts - 30% inefficiency for typical D-class amps = 1008watts rms
    worst case scenario........1440watts - 40% = 864watts
    finding the median......1008 + 864 = 1872/2 = 936wrms
    The audiopipe apcl1500 can do around 936wrms at 1ohm.
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  14. Dislikes av83, TaylorFade disliked this post
  15. #25
    Timmy13091's Avatar
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Post up the certified one ohm run....
  16. #26
    cfox10's Avatar
    cfox10 is offline Rock the house.
    Mar 2011
    Tillamook, Oregon
    1,956
    3 Post(s)
    811 Post(s)
    Quote Originally Posted by Beatin' View Post
    Not saying you are wrong... But fuse rating doesn't always mean how much power something will put out. Theoretically, yes.... But IRL no.,
  17. Likes alec14 liked this post
  18. #27
    Beatin''s Avatar
    Nov 2012
    MI
    998
    574 Post(s)
    Quote Originally Posted by cfox10 View Post
    you can get pretty close. This is assuming your car has a perfect electrical system.
    If you do the math and you get 2000wrms for Amp-X and it actually does 2200wrms, does that 200watt difference matter? Nope......
    936wrms to 1000wrms, the fuse ratings don't lie.
    voltage be dippin'
  19. Dislikes av83 disliked this post
  20. #28
    cfox10's Avatar
    Mar 2011
    Tillamook, Oregon
    1,956
    3 Post(s)
    811 Post(s)
    Every watt matters, I'm poor lol. I get what you are saying though
  21. #29
    Beatin''s Avatar
    Nov 2012
    MI
    998
    574 Post(s)
    another example sundown SAZ3500
    SAZ-3500D V.2
    efficiency at 4ohm is 86%
    fuse is 350A for 1ohm, divide by 2 and it's 175A for 2ohms, divide by 2 and it's 87.5A for 4ohms
    14.4v x 87.5A = 1260watts
    1260watts - 14% inefficiency = 1083.6wrms
    The sundown saz3500 is rated 1000wrms at 4 ohms.
    You can get VERY close if you have a fuse rating and some efficiency standard.
    voltage be dippin'
  22. #30
    bigdwiz's Avatar
    Oct 2010
    NC
    273
    1 Post(s)
    48 Post(s)
    This APCL-15001D put out 1314W @ 1% THD at 14V (@ 1 ohm) for a few seconds then popped the 100A fuse. Sorry to keep you guys waiting, but it's gonna take me a few days to get the full video edited. I have a day job and it's not editing and posting videos for my YT channel
  23. Thanks av83 thanked for this post
  1. smd Amp Dyno
    By d77543020 in forum General Discussion
    Last Post: 02-23-2013, 12:28 AM
  2. Replies: 6
    Last Post: 01-05-2010, 07:06 PM
  3. WANTED: Amp rated at 300watts @4 ohms or below
    By t-rex in forum Amplifiers
    Last Post: 05-09-2004, 04:25 AM
  4. Modded MMATS D300HC Amp Play at 1.5 Ohms
    By james33440 in forum Amplifiers
    Last Post: 01-12-2003, 07:39 PM
