Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Reload Thread: Two amps, strapped vs. individual, what's the difference?
  1. #31
    toysareforboys's Avatar
    toysareforboys is offline Junior Member
    Feb 2012
    Toronto, Ontario, Kanada
    9 Post(s)
    Re: Two amps, strapped vs. individual, what's the difference?
    Quote Originally Posted by vibe View Post
    ampere is a better bet. your brutus arent going to put out what you want. i have the brx 2400 and its not the worst but i could have gotten way better for just a lil more money
    Got a link to one/two of them?
    You don't think two strapped BRX2400's are going to give me 4000 at 14v??
    -Jamie M.
  2. #32
    vibe's Avatar
    vibe is offline CarAudio.com Elite
    Nov 2013
    Prescott, AZ
    28
    662
    313 Post(s)
    Quote Originally Posted by toysareforboys View Post
    -Jamie M.
    i think it will. acutally i know it will. if you have a beefy enough electrical system for them, i would just go with one beefy one with a better sq level. they do look purdy all lit up with the blue leds in them. if your interested im going to be selling mine here in about 2 weeks. ive ran it for a month at 1600w rms at 2ohms. im just upgrading my system. bought through sonic electronics and am most likely going to be selling for 200 shipped
  3. #33
    Bggd_GMC's Avatar
    Bggd_GMC is offline Low & Loud
    Oct 2011
    Fresno, CA
    522
    48 Post(s)
    Quote Originally Posted by T3mpest View Post
    You do realize when you strap an amp it effectively halves the load the amp see's right? So an amp that puts out 1k at 2ohms and 2k at 1ohm, when strapped would only be stable at 2ohms, but would put out 4k at that impedence as a pair, so obviously that's the lowest it will go, it's already putting out as much as 2 amps should.
    Im lost lol I am in the same boat im trying to understand this whole strapping thing im sure you explained it in you quote but im not understanding it.... I have 1 ct sounds 1400 on 2 sa12.. I will soon be running 4 12s and 2 1400s my 12s are d4 so 2 12s is 1 ohm and all 4 is 2ohms what im trying to understand is would I get more power wireing a set of 12s to 1ohm on a 1400 or strapping the 1400s and wiring all 4 to 2ohms would I get the same or more power by strapping compared to running a pair of subs to 1 amp
    1990 Silverado
    -Headunit: Kenwood KDC-X494
    -Front stage: Rockford T2652-S, T165, P152
    -Front stage amp: CT Sounds 125.4 60.4
    -Sub stage: 2 Sundown ZV4 15 Rev2
    -Sub stage amp: 2 CT Sounds 1400.1 Strapped
    -Electrical: Big 3, 2 Crescendo F-31, Mechman 370 amp
  4. #34
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    When you strap you get the max power you'd expect out of 2 amps. So in your case if those put out 1400 at 1ohm, 2 of them should put out 2800. When you strap them, they will then put out [email protected] You could run each set of it's own amp at 1 ohm or strap the amps and wire for a 2ohm load. The advantage is they are perfectly level matched in terms of power from each amp and xover etc when you strap, the 2 amps act perfectly as one.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  5. Thanks Side Show thanked for this post
    Likes Side Show liked this post
  6. #35
    akadj's Avatar
    akadj is offline Senior VIP Member
    Apr 2004
    Edmonton Alberta CANADA
    40
    458
    161 Post(s)
    i have tested two amps run separate vs strapped and I've got more box rise out of strapped amps, so less power. so i say that is the main disadvantage of strapping/linking amplifiers. most likely due to having to complete the voice coil circuit through the second board which would add resistance
    But your right it is a lot easier for a novice or everyday person to strap two amps and call it a day then to set the cross over points and gain match multiple amps.
  7. #36
    T3mpest's Avatar
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Quote Originally Posted by akadj View Post
    i have tested two amps run separate vs strapped and I've got more box rise out of strapped amps, so less power. so i say that is the main disadvantage of strapping/linking amplifiers. most likely due to having to complete the voice coil circuit through the second board which would add resistancehttp://www.caraudio.com/forums/newreply.php?do=newreply&p=8514859
    How much less did you meter?
  8. #37
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Strapping amps just makes it easier to run both. But you don't have to if you don't want or need to. You can line match the gains and be fine. Difference is. If you strap. One amp controls both and you can use the bass knob if you line. But if one amp blows. Then both can blow. If you line match. You can't use the stock bass knob. You have to set each amp to the same output voltage But if one amp blows the other is most likely to be fine depending On Circumstances
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  9. #38
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    It was a test with two 1500 watt amps.
    Strapped I got 2700 RMS rise of .85 ohms
    Separate I got 1550 RMS each rise of .3
    Difference on the termlab was 0.5 dbs
  10. #39
    Nov 2013
    CT
    102
    22
    37 Post(s)
    That's crazy I ran into the exact opposite situation with two strapped vs gain matched. Separate the rise was from .5 to 1.4 and strapped was 1 to 2.3 (total) or 1.15 each. I did recone the woofers between the tests, and always attributed this to a slight variation in the soft parts but I really don't know. Crazy
    ^^BLACK AND BLUE^^
    4.5 Cubes Tuned to 29Hz
    Two BtLN212D2s on (two 2.5ks)***update now on four IA 20.1s at .175 ohms each
    (Four XS D1400s)***update now eight XS D1400s
    Mechman 270
    Lots of mids n highs
  11. #40
    Bggd_GMC's Avatar
    Oct 2011
    Fresno, CA
    522
    48 Post(s)
    Thank you berry berry much I will strap my amps
    1990 Silverado
  12. #41
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    Quote Originally Posted by So Low iT Hz View Post
    Really, hmmm. Now I think I'm gonna try testing it again this time with a pair of 3kw amps.. Maybe it was just the 1500 amps didn't like being strapped or something internally not up to spec when it was built.. None the less gives me something to do in January. I'll make a video of it when I do, since I couldn't find one anywhere.
  13. #42
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,956
    15
    36 Post(s)
    4042 Post(s)
    Strapping loses damping factor as well.... if anybody cares.
  14. Thanks akheathen thanked for this post
  15. #43
    Nov 2013
    CT
    102
    22
    37 Post(s)
    Quote Originally Posted by hispls View Post
    Which nobody running one ohm or below really cares about lol. Otherwise we'd all run JBL Crown 6ks
    ^^BLACK AND BLUE^^
    Mechman 270
  16. #44
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    36
    2,355
    1 Post(s)
    250 Post(s)
    wow.......... the whole point of strapping is to run 4 amps on 2 voice coils... (or 2 amps on one)....... that is it. the modern solution is just a real big amp instead. not only do you loose 1/2 dampening, but you introduce many more possible external failure points to a normally contained circuit. there is more advantage to gain syncing than strapping. btw, you do not gain or loose power, you simply double voltage, which means ohms need to double to keep the fets at the same current load.
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
  1. strap two kicker zx 1000.1 what is the final ohms input?
    By jh83 in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2013, 05:27 PM
  2. What's the difference between these two Hifonics amps?
    By skatingrocker17 in forum Amplifiers
    Last Post: 04-30-2012, 10:10 PM
  3. IDMAX12 vs. IDMAX12v3... What's the Difference?
    By EmEsDub in forum Subwoofers
    Last Post: 10-05-2004, 05:12 PM
  4. Pioneer Vs. Premier - What's the Difference?
    By MonkeyBizIU1859 in forum Head Units
    Last Post: 08-03-2004, 06:29 PM
  5. Replies: 3
    Last Post: 02-06-2002, 03:23 PM
