Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 59 of 59
Reload Thread: Need Amp Suggestions Please.
  1. #46
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: Need Amp Suggestions Please.
    Quote Originally Posted by JISINSANE3 View Post
    wow that audio technix looks like one little bad amp. 120amp fuse rated. Wonder if it capable of 1000watts no issues. Never heard of the brand. BTW, Anyone else see that $7000 Memphis mad max 18" on the bottom of that ebay ad? WOW the insanity. JBL is fine stuff btw. Very fine stuff.
    Uhh that Mad Max ad is a bunch of horseshit. Nowhere close to worth that much. As for amp fusing, don't let it be the judge for how much power an amp puts out. It's actually a part of the marketing techniques, so a company will over-fuse their amps, something goes wrong, and the amp blows anyway. That was some smart R&D right there, huh?
    Spotify: http://open.spotify.com/user/neo_styles/playlist/6t9ru42j0wbEsuo4bXqXD8
  2. #47
    JISINSANE3's Avatar
    JISINSANE3 is offline 1995 dodge stealth r/t
    Sep 2013
    orlando fl
    56
    16 Post(s)
    Thanks for the heads up. The mosfets looked pretty nice. There are so many wanna be fly by night companys now you don't know who to trust. $7k for a 18" LOL, I could buy a load of SMD's for that.
    LOL
  3. #48
    tc300's Avatar
    tc300 is offline CarAudio.com Veteran
    Mar 2007
    springfield,ill
    3,019
    608 Post(s)
    Quote Originally Posted by Arya View Post
    I want something good that will last me for a few years. Another problem I have with buying used is that I won't have the cash in hand to buy the products for another week or two. That's the main reason why I wanted to buy new.
    you need to remember this... YOU GET WHAT YOU PAY FOR!!! spend the xtra $$ the first time and you will get plenty of good use out of your equipment... lol if its installed correctly
  4. #49
    Arya's Avatar
    Arya is offline Member
    Sep 2013
    United States
    73
    53 Post(s)
    Quote Originally Posted by neo_styles View Post
    LOL
    Quote Originally Posted by tc300 View Post
    Thanks for all your help! In the end I decided to go with the JBL GTOEZ and the PPI BK320
  5. #50
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    legit amp. the board has beena round for a while its a legit amp that has been benched around 1100 rms at 14v its rated at 12v's. i am currently running one. the price of the new model is 229
  6. #51
    JISINSANE3's Avatar
    Sep 2013
    orlando fl
    56
    16 Post(s)
    Honestly Im iffy about a lot of things till I see them in real world use and also inclined to try new things. I noticed there are no ballast resistors on that pcb. At least that's what I think there called, The white block resistors you commonly see on amp boards. What does it use in place of them? Or is that a more common thing on class a/b amps? Trying to get more informed on amp technology. How long you been running yours for now?
  7. #52
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    the at800 is class d
    been using mine for around 6 months
    coleman has been around for a long time, they started off with wire and cld
    http://www.ebay.com/itm/Audio-Techni...item19db49e7b7
    http://www.ebay.com/itm/Audio-Techni...item1c3286c06b
    he is clearing out his at amps because of copyright issues with audio technica (same thing that audioque went through)
    http://www.ebay.com/itm/CT-Sounds-14...item19df9e1537
    http://www.ebay.com/itm/CT-Sounds-90...item19df9e7884
    these are identical amps just new knobs under the new name the at1200.1 does 1800 clamped at 14vs for 200 bucks 1/0 required
  8. #53
    JISINSANE3's Avatar
    Sep 2013
    orlando fl
    56
    16 Post(s)
    Yeah, it looks like a well made amp. And I see the bottom one has a sound alarm which is probably for trouble alerts. I would not hesitate to try one. But the ebay ad is completely different. What models are them 2?
  9. #54
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    thats the at1200.1 the bottom one,
    Audio Technix 1200 1 Amp Amplifier 1200W RMS 2400W Max Class D 1 Ohm Stable | eBay
    does 1800rms at 14v's
    Ct Sounds 125 4 Amp Amplifier 125W RMS 250W Max Class A B 4 Channel 2 Ohm | eBay
    the top is the ct125.4 which is not discounted like the audio technix label its at msrp like all the ct brand. the audiot echnix amps are just on closout prices to clear the old names stock
  10. #55
    JISINSANE3's Avatar
    Sep 2013
    orlando fl
    56
    16 Post(s)
    ill be quite honest I am interested in trying that bottom one. Not now. I just scored nicely on craigslist a used jl 300/4 for my mids and highs. But you give me a few weeks I have your contact. I am very inclined to try out that bottom amp.
  11. #56
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    CT Sounds Component and Coax Sets
    The Official CT Sounds Product List, Pricing, and ETA's
    map prices
    Ct Sounds Amplifier Pre-order - Plus new bass Knob - Car Audio Classifieds
    new bass knob on the ct series clipping and voltage indicator
    ---------- Post added at 10:11 PM ---------- Previous post was at 10:10 PM ----------
    which one the at 1200, its not for sale but u can try lol
  12. #57
    JISINSANE3's Avatar
    Sep 2013
    orlando fl
    56
    16 Post(s)
    both those board differ significantly. The bottom one I would get no problem. You say there both the same amp, Do them 2 extra ferrite chokes on the bottom one replace all them ballast resistors on the upper on?
  13. #58
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    I don't know what you ate talking about what 2 amps
  14. #59
    JISINSANE3's Avatar
    Sep 2013
    orlando fl
    56
    16 Post(s)
    mistake, Never mind. your last sentence I thought you said they were both the same amp but I misunderstood. I like that bottom amp how much are they again? the bottom 1200 one? $200? I may try it to be honest. Could you do a video of it in operation? And your about 2 hours from me Id come pick it up if you are a seller. Id like to see it in person. Or do you know of a reseller in central florida?
    if you could PM me if you know of a seller in central florida. Instead of dragging out this post.
  1. Need amp suggestion. PLease
    By Dirtrider4eva in forum Amplifiers
    Last Post: 04-24-2011, 09:03 PM
  2. Need amp suggestions, please help a newbie!
    By Bobby322 in forum Amplifiers
    Last Post: 10-22-2008, 07:48 PM
  3. Need Amp Suggestions/Advice/Etc Please
    By Tone8969 in forum Amplifiers
    Last Post: 07-16-2008, 09:22 PM
  4. Need Amp Suggestions Please!!!!
    By TsX-Euro-R in forum Amplifiers
    Last Post: 04-09-2006, 04:37 PM
  5. need amp suggestion!!!!
    By <frank> in forum Amplifiers
    Last Post: 12-25-2001, 02:20 PM
