I am putting a half new system in my Chevy Colorado Crew Cab and I'm using some left over equipment from my last install and I'm not sure which amps I should use for what. The only thing I am sure about is that I should use one of the MRV-1005's for the sub. I'll list the amps and their specs plus the speakers and their specs. Let me know what you guys think I should use for what. I know there has to be a good mixture in there somewhere. Any suggestions on how I should bridge and wire them to the speakers would also be greatly appreciated. I also have a question about preamp voltage. These amps are set up for 4V from the HU, what if anything negative will happen if a higher voltage is sent from the HU?
Speakers...
CDT
CL-61's for the front doors (I'm also adding an image enhancement kit)
Mid: Stamped 6.5"
Crossover: "Phase Perfect" Elliptic 4th order 2-Way SatNat-456
Tweeter: TW-20 silk soft dome or titanium dome
Power Handling: 90 watt RMS
Frequency Response: 60-20kHz
Sensitivity: 92.0 dB
Impedance: 4Ohm
CDT 6.5 Mids for rear fill
Diamond Audio (sub)
M610D4
Specifications
Power Range (W RMS): 800
Impedance (ohms): Dual 4
Sensitivity (dB SPL): 90 (2.83-V input @ 1 meter)
Freq. Resp: 22Hz-250Hz(±3dB
Amps...
MRV-1005 V12 Expert (I have 2 of these)
RMS Power (at 12V, 20Hz—20kHz)
Per channel into 4 ohms .................................................. ......... 100W x 2 (0.08% THD)
Per channel into 2 ohms .................................................. ........... 200W x 2 (0.3% THD)
Bridged 4 ohms .................................................. ..................... 400W x 1 (0.3% THD)
RMS power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms .................................................. ......... 150W x 2 (0.08% THD)
Per channel into 2 ohms .................................................. ........... 300W x 2 (0.3% THD)
Bridged 4 ohms .................................................. ..................... 600W x 1 (0.3% THD)
General
Frequency Response .................................................. .............. 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............................................ 110 dBA (referenced to rated power)
Input Sensitivity (for rated power) .................................................. ............. 200mV to 4V
Slew Factor .................................................. ....................................... greater than 5
Input Impedance .................................................. ....................................... 10k ohms
Speaker Impedance ............................................. 4 or 2 ohms (stereo), 4 ohms (bridged)
Dividing Network .................................................. 50Hz—200Hz HP/LP(12dB/octave)
Equalizer Center Frequencies .................................................. .............. 50Hz—200Hz
Q Factor (bandwidth) .................................................. .................................. 10 — 1
Boost and Cut range .................................................. .....................................12dB
Power Requirements .................................................. .... 11—16V DC (negative ground)
MRV-F405 V12 Expert (one of these)
Per channel into 4 ohms .................................................. ........... 40W x 4 (0.08% THD)
Per channel into 2 ohms .................................................. ............. 50W x 4 (0.3% THD)
Bridged 4 ohms .................................................. ..................... 100W x 2 (0.3% THD)
RMS Power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms .................................................. ........... 60W x 4 (0.08% THD)
Per channel into 2 ohms .................................................. ............. 80W x 4 (0.3% THD)
Bridged 4 ohms .................................................. ..................... 160W x 2 (0.3% THD)
General
Signal to Noise (S/N) ............................................ 105 dBA (referenced to rated power)
Speaker Impedance .............................................. 4 or 2 ohms(stereo), 4 ohms (bridged)
Dividing Network ................................. 50Hz—8000Hz HP/LP/Bandpass(12dB/octave)
MRP-F356 Flex 5 (one of these)
MAX POWER (EIAJ)
•75W x 4 + 180W (4 Ohm Stereo)
•180W x 2 + 180W (Bridged 4 Ohm)
RMS Continuous Power (Watt) (at 14.4V, 20-20 kHz/ *:20-200Hz 0.3%THD): 4 Ohm Stereo (0.08% THD) 30W x 4 + 100W*; 2 Ohm Stereo (0.3% THD) 40W x 4; Bridged 4 Ohm (0.3% THD) 80W x 2 + 100W*
•S/N Ratio 100 dBA
•Frequency Response (+0, -1dB) 10-50kHz
•5/4/3 Channel Operation
Register To Reply
Bookmarks
