Results 1 to 6 of 6
Reload Thread: Small amplifiers?...to power 3x 12's
    absolutcain's Avatar
    absolutcain is offline BodyDrop
    Dec 2003
    trumbull
    i have three
    12" Sound Q Subwoofer, 1000w, alum cone
    Power Handling: 1000 watts R.M.S.
    Dual 6 Ohm
    3 Ohm or 12 Ohm Operation
    I would like to run some small in size amplifiers or amplifier?..so i can power these subs..but hide the amplifiers..under seats?..i want then the size of maybe a playstation 2? idk...i know i sound like a newbie..but what do you think..power wise would work the best?
    Dec 2003
    trumbull
    Re: Small amplifiers?...to power 3x 12's
    anyone out there?
    niqnak's Avatar
    niqnak is offline Member
    Apr 2004
    Tallahassee, FL
    30
    96
    memphis amps are realllly small, www.memphiscaraudio.com the 1100 watt amp is like 16x6.5x2 or something
    JBL amps are also small, dont know the specs though
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    31
    3,509
    Power acoustik makes a good same amp. http://www.sounddomain.com/sku/POWA1800DB
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    Dec 2003
    trumbull
    thanks guys..can anyone tell me what i should get for those 12s..what wattage amp?
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    68 Post(s)
    917 Post(s)
    MMATS make excellent amplifers and they have a very small chassis, also look into Cadence, they make the A7HC, small in size huge on power, but I am not sure about the ohm load for it
    CarAudio.com mod(original)
  1. Amp/Spkr power rating Q
    By Seranin in forum General Discussion
    Last Post: 03-07-2004, 12:14 AM
  2. Considering two power HX2 12's. need input
    By cobra65427289 in forum Subwoofers
    Last Post: 12-09-2003, 06:05 PM
  3. Alpine Type R 12's
    By BooLeaN in forum Subwoofers
    Last Post: 12-08-2003, 02:33 AM
  4. Wiring 4 jl subs
    By Gaffney982 in forum Wiring, Electrical and Installation Help
    Last Post: 10-09-2003, 07:36 PM
