Results 1 to 6 of 6
Reload Thread: Amp problems
    bmk6795's Avatar
    bmk6795 is offline CarAudio.com Elite
    Jul 2012
    Spartanburg, SC
    1,274
    267 Post(s)
    Amp problems
    So i had my amp hooked up in my backseat temporarily for a couple days, everything worked fine. I unhooked all the wires moved the amp back approximately a foot, hide the wires, and now it wont turn on. Anyone got any ideas as to why? The power wire has power, the ground is fine, the rcas are ok. I assumed the remote is fine but i dont have another amp to test it on. It could be that there is just no output but i checked and rechecked the speaker wires and they are hooked up right. Im puzzled as to what happened, any help is appreciated. Thanks.
    Link to Itrader feedback: http://www.caraudio.com/forums/itrader.php?u=1017953
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: Amp problems
    backseat went flat? try charging it back up or hook it back up the way you had it and see if it works, if not check fuses and grnd and pwr wires
    bmk6795's Avatar
    Jul 2012
    Spartanburg, SC
    1,274
    267 Post(s)
    Re: Amp problems
    fuses, ground, and power wires are fine. I found the problem but i dont know why it is a problem. The speaker terminals have no output, reading .4 volts on the multimeter with the gains in the same exact spot as they were before, turning the gain up or down has no effect on output. Any idea why the speaker terminals have no output now? i didnt drop, beat, bang, the amp or anything, literally picked it up, and put it in the trunk. Any opinions?
    bmk6795's Avatar
    Jul 2012
    Spartanburg, SC
    1,274
    267 Post(s)
    Re: Amp problems
    bumpp
    bmk6795's Avatar
    Jul 2012
    Spartanburg, SC
    1,274
    267 Post(s)
    Re: Amp problems
    Problem solved thanks guys
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: Amp problems
    was it your rca's? in the output section of your amp and not in the input section?
  1. Rockford Amp problems
    By Corsica in forum Wiring, Electrical and Installation Help
    Last Post: 04-20-2002, 12:45 PM
  2. HELP WITH AMP PROBLEM !!!(please read)
    By pioneer in forum Amplifiers
    Last Post: 04-11-2002, 02:08 PM
  3. amp problem?
    By nibularr in forum Amplifiers
    Last Post: 03-19-2002, 01:17 PM
  4. Kenwood amp problem
    By eljohnny1 in forum Amplifiers
    Last Post: 03-02-2002, 07:55 PM
  5. amp problem
    By Unregistered in forum Amplifiers
    Last Post: 02-28-2002, 05:20 AM
