Results 1 to 9 of 9
Reload Thread: 5 channel amp buying advice
    wardrebel's Avatar
    wardrebel is offline Junior Member
    Sep 2009
    Meridian, Mississippi, United States
    i am wanting to use a 5 channel in my crew cab truck do to ease use an install. i have 3 models picked out an i'm not sure wich one is the better amp. i'm running a set of 4Ω components in the front doors and a set of 4Ω coaxials in the rear doors and i am running 2 12s at 1Ω. any advice would be welcomed an a great help as i have never used any of these brands before.
    this is my first choice and the one i am leaning toward.
    Db Drive A32250.5 5-channel 245.00
    4 Ω @ 14.4 VOLTS: 4x 150 Watts
    2 Ω @ 14.4 VOLTS: 4 x 300 Watts
    1 Ω @ 14.4 VOLTS: 1 x 1000 Watts
    second choice
    Soundstream TA5.1250 5 Channel 275.00
    4Ω @ 14.4 VOLTS 75 x 4 + 325 x 1
    2Ω @ 14.4 VOLTS 125 x 4 + 500 x 1
    1Ω @ 14.4 VOLTS 750x1
    third choice
    Massive Audio NX5 Nano Block Series 5-Channel 299.99
    4Ω 14.4 VOLTS 120 watts x 4 chan. + 200 watts x 1 chan.
    2Ω 14.4 VOLTS 240 watts x 4 chan. + 400 watts x 1 chan.
    1Ω 14.4 VOLTS 800 watts x 1 channel
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    Re: 5 channel amp buying advice
    look at the american bass ph5100 fr ,if you like it ,hit me back
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    79bronco's Avatar
    79bronco is offline Senior VIP Member
    Jan 2013
    United States
    201
    19 Post(s)
    Hi, I have a massive audio P950.5 for sale if you'd be interested. Very similar power ratings, feel free to shoot me a PM
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    I would take the specs regarding the 1ohm operation above with a grain of salt. And the specs for the amps above look completely inflated to me, specially db drive and massive audio nx5. If you need such tough iron, I suggest you get a mono amplifier + a cheap 4-channel. I'd recommend Alpine MRP-F300 ($140 Class D 4-channel amp) or PPI P900.4 (4 channel amp, more power, slightly more expensive) + either Soundstream TN1.1200D or PPI Phantom P1000.1 (same board used in both, ~1200watts RMS at 1ohm).
    wardrebel's Avatar
    Sep 2009
    i looked at them and like them, but i don't have any shops near me that carry them.
    2005 Chrysler 300 limited - Hu/Pioneer AVH-X5500BHS , Amps/ jbl 600.1, 80.2 and an 80.4, Mids/kicker, Subs/sundown audio sa10d4, Wiring/tsunami.
    <under construction> 2010 chevy silverado 4x4 crew cab Hu/Pioneer AVH-X5500BHS, Wiring/stinger an monster cable, Amp/???, Mids/ 2 sets of Kicker CSS674 componets, subs/ kicker cvr 12, Sub box/OBCON Dual 12-Inch Chevy 1500 Labyrinth Power Port. <under construction>
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,793
    43 Post(s)
    1859 Post(s)
    You can get the Precision Power amps on here from me.
    I do not recommend running any of those amps at 1 ohm on the sub channel. That's a lot of heat to potentially build up in a chassis with dual power supplies, and usually you have to pay a lot more to get a really good 5 channel amp that takes that abuse. You would be better off with those choices if you design the system to use a 2 ohm load on the sub channel. In theory it's only a 3 dB loss of output by cutting the power in half.
    I would pass on that OBCON box you have listed in your signature. A generic ported box is a bad idea. You might have someone nearby who can design and build a really good ported box to perfectly fit out of the way.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    FB | Rubyservsales
    IG | Rubyserv
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    i carry the american bass amps ,and they do well at 1 ohm n the sub channel
    wardrebel's Avatar
    Sep 2009
    i have already bought obcon box. i got it from a friend who had the same truck as me, an it sounded good with only 600 watts going to the kickers. i'm not a bass head i listen to mainly metal and hard rock so i'm not gonna push the sub channel to hard.
  9. #9
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    I listen to the same music and I have 10s on 3000 watts rms just depemds on the box and amp tuning
  1. Subs/Amp Buying Advice?
    By BCreed025 in forum General Discussion
    Last Post: 05-06-2010, 12:39 AM
  2. Replies: 6
    Last Post: 06-02-2006, 02:53 AM
  3. Wiring 5 Channel Amp - Advice needed
    By edhunter in forum Wiring, Electrical and Installation Help
    Last Post: 12-11-2003, 01:55 AM
  4. Multi-Channel Amp Advice???
    By nrgy in forum Amplifiers
    Last Post: 11-29-2002, 06:32 PM
  5. Anyone have advice on 5 channel amps
    By diveguy in forum Amplifiers
    Last Post: 10-14-2002, 09:47 AM
