Results 1 to 3 of 3
Reload Thread: 150 amp fuse w/ 200 amp alternator???
    RUDEF2's Avatar
    RUDEF2 is offline Junior Member
    Apr 2002
    Warner Robins, GA
    33
    14
    hi all, i just installed a 200 amp alternator on my 95' dodge neon.
    The amp i will be running calls for a 100 amp fuse. i only have a 150 amp fuse. [My 2 local car audio shops didnt have anything over 60 or 80 amps.{guess they are not serious bout car audio}] .
    Would it be ok to run the 150 amp for a day or two? i have already ordered ten 100amp fuses off ebay but they wont be here for a week.
    Thanks for your help. -justin
    JL Audio 18w3-D2
    Rockford Fosgate 1000a2
    Rockford Fosgate Components
    Rockford Fosgate 6x9's
    Aiawa Headunit
    CS-144 200 AMP Alternator
    144.2 db 1st Place in stock class (161-260 sq in) @ crutchfield on april 26th 2003. (my first competition! and only one so far.) w/ 1 JL18W3-D2 in a SEALED in 2 cu/ft box wired parallel @ 1ohm.
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: 150 amp fuse w/ 200 amp alternator???
    If you can't find hte fuse rating that you require, people would normally recommend you to put a lower fuse rating.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    RUDEF2's Avatar
    Apr 2002
    Warner Robins, GA
    33
    14
    oh shiz. i just got back in from hooking it all up, 3mins worth of playing sweeps and my sub is smoking! its brand new too...
    can someone double check my amp to sub settings:
    1 JL 18" Duel 2ohm Voicecoil wired in parallel to the Left channel (testing purposes) of RF 1000a2 gain 1/5th the way up.
    help!
    edit: i just figured out i had it wired at 1ohm!!!!! i got it in series now. i hope thats better
    JL Audio 18w3-D2
    Aiawa Headunit
  1. amp to amp or split RCA's?
    By chronicblazen in forum Amplifiers
    Last Post: 03-17-2004, 10:33 PM
  2. use external fuse and bypass internal fuse
    By CarAudioAddict in forum Wiring, Electrical and Installation Help
    Last Post: 01-14-2004, 03:52 AM
  3. help me :( which fuse do i buy?
    By remote-control in forum Wiring, Electrical and Installation Help
    Last Post: 01-12-2004, 03:56 AM
  4. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  5. sub amp going into protection when low notes hit
    By B|2imstone in forum Amplifiers
    Last Post: 12-08-2003, 03:12 AM
