Results 1 to 11 of 11
Reload Thread: My not broken amp thatactually broke.
    Villainstone's Avatar
    Villainstone is offline Senior VIP Member
    Nov 2011
    Boonville, NY
    170
    48 Post(s)
    Hi guys as you may know I have been posting several questions in the amp section. Now about that amp that I am sending out for warranty today. I figured I wouls post a quick question and a few details about the amp.
    First whats wrong is that the amp does not output any sound to the sub. At first I thought it was the sub. I hooked the sub up in the house and it works. So I thought maybe the line in wires to the amp. Nope not the issue. So the amp power light is on, so the amp is getting power. Just no output sound. So what the heck could be wrong?
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    Re: My not broken amp thatactually broke.
    Are there any signal cables?
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
    Nov 2011
    Boonville, NY
    170
    48 Post(s)
    If you mean RCA from the deck to the amp yes and I checked to see if they were bad. I used a different set and still no good.
    IonRL205's Avatar
    IonRL205 is offline DJ h4z4rdes
    Sep 2008
    Abilene, Texas
    2,449
    946 Post(s)
    Have you checked to make sure the RCA outputs on your head unit are working properly? Use a DMM and set it to AC volts, and test the RCA jacks
    Headunit - Pioneer DEH-P8300UB
    Subs - None
    Sub Amp - 2x Crescendo 3kwp
    Front Stage - Polk Audio db651 Coaxial
    Front Amp - None
    Quote Originally Posted by zako View Post
    Most properly done 15 inch subwoofers are not suited for car audio use simply due to box size requirements.
    Nov 2011
    Boonville, NY
    170
    48 Post(s)
    Il ldo that now ty.
    winkychevelle's Avatar
    winkychevelle is online now CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    Make sure ur deck doesn't have to sub turned off. It sounds stupid but people forget about that setting from time to time. And what amp and what ohm load
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
    Nov 2011
    Boonville, NY
    170
    48 Post(s)
    Ok so I checked with a DMM I checked 3 RCA outputs. I checked the two from the deck and the one from the stock outputs that came with my car. None of them measured anything in terms of AC or DC volts. Im not sure what was suppose to happen but to test the DMM I check the bat and it read 14.5 while the car was running.
    My deck doesnt have a subwoofer output. The amp is a SoundStream RUB1.800D and it was running at 4 ohms to one sub.
    IonRL205's Avatar
    Sep 2008
    Abilene, Texas
    2,449
    946 Post(s)
    Quote Originally Posted by Villainstone View Post
    Did you put the positive probe of your DMM inside the RCA connector and the negative probe on the outisde of the connector? Make sure the H/U volume is up a bit so it can read a signal. If you've done this and and there is no A/C reading, then your deck itself isn't putting out the signal to the amp and this is where your issue is from.
    Do you have an ipod/mp3 player you can connect to your amp with a 3.5mm to RCA jack? Or even a phone would work. If you are able to get sound of your subs from this, then your amp is not the problem and the issue is coming from the source.
    Subs - None
    Front Amp - None
  9. #9
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    So this was working, and now it isn't?
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  10. #10
    Nov 2011
    Boonville, NY
    170
    48 Post(s)
    Ty the volume wasnt that loud maybe that is why. I can use my phone with a rca-headphone jack I suppose. Thank you I will post back a bit later.
  11. #11
    Nov 2011
    Boonville, NY
    170
    48 Post(s)
    Quote Originally Posted by jco1385 View Post
    Yeah I just drove to school and I noticed it wasnt bumping. I thought it was the sub at first cuz the amp power light wass green. But after I hooked the sub up in the house it worked o I figured it was either the amp or wiring. I checked the wiring and am following suggestions here.
  1. Something's not right (obviously). But I'm postive my wiring is. (amp problem)
    By christeeezy in forum Wiring, Electrical and Installation Help
    Last Post: 02-23-2011, 10:26 PM
  2. Replies: 13
    Last Post: 04-21-2009, 09:24 AM
  3. WHO Can Fix My Broken Amps
    By Possom in forum Amplifiers
    Last Post: 11-11-2008, 10:11 PM
  4. please help...broken amp? need my boom boom
    By Sspider in forum Amplifiers
    Last Post: 03-24-2003, 05:18 PM
  5. my amp is broke can you help me fix it??
    By sportincamry in forum General Discussion
    Last Post: 09-23-2002, 11:01 AM
