Results 1 to 5 of 5
Reload Thread: Amp malfunctioning, anyone know what may be problem
    nate1017's Avatar
    nate1017 is offline Senior VIP Member
    May 2013
    DeFuniak Springs Fl
    171
    35 Post(s)
    Okay a few days ago my sub quit hitting and i noticed bass would kick on for a split second when i hit a bump or took a turn fast. So when i got home i started to tinker with it and realized if i pushed down on mid lefthand side of the amp it would begin powering my sub again. Anyone know why this might be happening? Should i take my amp apart to see if there are any loose connections? Any help would be appreciated......btw its a Rockford Fosgate Prime 500.1
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: Amp malfunctioning, anyone know what may be problem
    don't take an amp apart unless you already have experience with electronics repair.
    yes, a loose connection is likely but a novice can do more harm than good.
    until it's repaired, you want to disconnect it. intermittent signals may cause arcing which will cause a fire.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    sounds like a loose solder joint on one of the fets.
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    "left" side is relative to the amp - could be input section, could be output section. does the amp turn off when the signal cuts out?
    nate1017's Avatar
    May 2013
    DeFuniak Springs Fl
    171
    35 Post(s)
    No the power light stays on just doesn't power the sub.....also how much a repair on this might cost? just wondering may just end up buying new amp
  1. Amp malfunctioning, anyone know what may be problem
    By nate1017 in forum Wiring, Electrical and Installation Help
    Last Post: 05-04-2013, 04:30 PM
  2. Anyone know what this amp is rated at?
    By Ayy in forum Amplifiers
    Last Post: 06-13-2009, 11:27 PM
  3. Anyone know what model amp this is?
    By Magz_rule in forum General Discussion
    Last Post: 10-29-2008, 03:16 PM
  4. Does anyone know what could be going on?
    By Anonymous in forum General Discussion
    Last Post: 12-21-2006, 10:14 AM
  5. Anyone know what the port size would be for this design of box?
    By supraman1379 in forum Enclosure Design & Construction Help
    Last Post: 08-15-2005, 08:04 PM
