Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 58
Reload Thread: Affordable amps?
  1. #31
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: Affordable amps?
    Quote Originally Posted by DDtC View Post
    How about we just stop telling people what they want to hear and be REAL with them? You go around recommending stuff thats not even tested yet.... Thats fine but you need to say it. "Here are some cheap pre-order subs, they might be good but knowbody knows yet. Or you might get one and lose your *** cause they ****" OR "here are some cheap amps but they are going to need many $s in electrical, might do close to rated clean, might blow subs cause they are dirty, or might not work out of the box" OR " you can spend a bit more and get this proven preformer"
    i'll repeat myself the OP asked for affordable $250 amp that will do 2k
    what did you recommend $479 amp and you are mad?
    and here you go again with your "rated" claim
    for electrical a big 3 and an extra battery at the back will suffice. and as long as you dont run the amp to the ground and make sure your voltage does not drop to below 12.5 it will work.
  2. #32
    i2ain2thunder's Avatar
    i2ain2thunder is offline CarAudio.com Veteran
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    Quote Originally Posted by naughtyca View Post
    this kind of thing needs to stay in the dome. Ask questions about one's reasoning is ok, but do not start to make snide remarks.
  3. #33
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    Well the voltage is going to drop below 12.5 with a strong alternator. A extra battery wont stop that from happening. Its not about the rated, its about everything else. Say it does do 2000 watts. How long do you think it will do it after heat kicks in? With that cheap board and horrible cooling design how long do you think it will take before the heat takes over? Please look at the big picture, if you dont understand enough to see that picture just stop.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  4. #34
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    have you ran these amps before? if not then you need to STFU, why dont you suggest an affordable $250, 2k amp instead of bickering?
  5. #35
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    Cause there isnt one. Thats why I wont recommend one.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  6. #36
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    remind me why are you on this thread?
    Typical case of Trolling
  7. #37
    Nov 2011
    Dallas, Tx/Ada, Ok
    24
    3,768
    1308 Post(s)
    The BEST cheaper amps that do what they say and do it clean are Crescendo and AQ/SQ. There are others from even smaller compainies but they are not easy to come by. IF YOU GO REALLY CHEAP it will cost just as much in electrical to get them to make the power(if they even will) the better amps will make with less costly electrical. Most of the cheap amps wont do rated till 16v. Do it right the first time or you will be replacing amps costing even more in the end. if you cant save to do it right this is not the hobby for you. if thats the case just get some Type Rs and a solid MRP amp. Thats more then enough for 99% of the population, a good box will make them a loud, and reliable set up.
    This this this fuck you stole the exact words out of my mouth..
    OP take it from someone who's ran all the shit listed above. AQ and crescendo are the best quality "budget" amps, they do their rated power and don't use alot of power to do so.
    Type Rs, and a Alpine MRP-1000, are always a great budget set up, my first set up was a 12" W7 on a alpine MRP 1000. Keep in mind they are only stable to 2 ohms. I had it wired at 1.5 and it took it like a champ, amp got hot sometimes but never went into protect.
  8. #38
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    Not trolling at all. Trying to help people not make the same mistakes I did. IE. listen to advice like you are giving many years ago.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  9. #39
    Nov 2011
    Dallas, Tx/Ada, Ok
    24
    3,768
    1308 Post(s)
    You guys are fucking retarded...
    OP if you get lucky youll find a AQ 2200 around 250. Just gotta be patient and have $$ ready
    ---------- Post added at 02:37 PM ---------- Previous post was at 02:36 PM ----------
    This.....
  10. #40
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    OP, if I were you, I'd just do what 04murdalanche said - wait for a good deal and have the money ready for when one pops up. Even if you need to go used, amps can run for years and years if treated with some respect. Look in the classifieds, there are deals everywhere. Remember, it's better to find a good deal on a good amp, than to find a good deal on a bad one that may potentially need to be replaced.
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
  11. #41
    Nov 2011
    Dallas, Tx/Ada, Ok
    24
    3,768
    1308 Post(s)
    Quote Originally Posted by Full Tilt View Post
    I don't ever buy audioz new... Way too fucking over priced, the wait is usually ridiculous. I've only bought 1 thing new, my SA-8s, as it wasn't even from sundown it was from a guy who bought a shit ton from the yard sale. Everything I've bought in my system I've gotten so cheap, I've never paid anywhere near retail for any of my equiptment, sheit I've gotten a pretty **** good deal on everything lol
  12. #42
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Quote Originally Posted by 04murdalanche View Post
    Keep an eye out for a 1500 - 2000w amp for me.
  13. #43
    JL Audio's Avatar
    JL Audio is offline ThugStep
    Dec 2006
    KY
    13,323
    2 Post(s)
    527 Post(s)
    Quote Originally Posted by supereikenator View Post
    Audiopipe? Really? That's surprising, same with Power Acoustik. Rubicon is Soundstream right? I knew Hifonics, but is their newer stuff any good?
    just to note.. as of like since 2008:
    Soundstream, Power Acoustik, Kole, SPL, Precison Power ---> Epsilon electronics
    Boss Audio, Planet Audio, SoundStorm ---> AVA Enterprises
    for the most part..
    was clarifying that soundstream and power acoustik aren't totally different companies. nothing wrong with them but build quality is totally different.
    my 2 cents, also look into vvme amps, same as the audiopipes and usually slightly cheaper.
  14. #44
    Fireitup's Avatar
    Fireitup is offline CarAudio.com Elite
    Jan 2013
    Alabama
    649
    1 Post(s)
    157 Post(s)
    OP if you get lucky youll find a AQ 2200 around 250. Just gotta be patient and have $$ ready[COLOR="Silver"]
    Hell i'll come down on price to 300 shipped on my 2200 if people will stop spewing **** about flea market amps~
  15. #45
    JL Audio's Avatar
    Dec 2006
    KY
    13,323
    2 Post(s)
    527 Post(s)
    Quote Originally Posted by Fireitup View Post
    solid amp all around. shipped price 300 is good.
  1. Need a good & affordable amp for my in car speakers
    By Bennieficial in forum Amplifiers
    Last Post: 05-31-2010, 10:12 PM
  2. Affordable Amp for Alpine Type R 12''
    By desi8389 in forum Amplifiers
    Last Post: 05-04-2009, 07:37 PM
  3. Affordable amp for subwoofer?
    By heat23 in forum Amplifiers
    Last Post: 11-08-2004, 04:54 PM
  4. Affordable amp for Type R??!
    By Afboy143 in forum Amplifiers
    Last Post: 08-03-2003, 02:04 PM
  5. Best and Affordable 10" sub for my amp
    By <SilverTruk> in forum Subwoofers
    Last Post: 12-10-2001, 06:15 PM
