Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 58
Reload Thread: Affordable amps?
  1. #16
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: Affordable amps?
    Quote Originally Posted by supereikenator View Post
    Audiopipe? Really? That's surprising, same with Power Acoustik. Rubicon is Soundstream right? I knew Hifonics, but is their newer stuff any good?
    there are some brands that has a good line, even lanzar has the opti drive that is a good line
  2. #17
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,965
    109 Post(s)
    7680 Post(s)
    Quote Originally Posted by naughtyca View Post
    So since the opti does close to rated at 16v makes it good? Since t he AP does 500 underated clean makes it good?
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  3. #18
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,965
    109 Post(s)
    7680 Post(s)
    when you buy an inexpensive amp dont expect to get what the rms says, but price = watts per dollar these inexpensive amp still a good bang for the buck, audiopipe apsm 1500 $125 you should get at least 1k to 1200, bamf 5500 $229 you should get at least 2k to 2500, belva 5000 $299 you should get at least 2.5k or more
    i dont call these affordable
    crescendo b2000 =$479
    AQ 2200 = $429
    Even with the power as cheap as it is now days you still get what you pay for. You pay for quality, efficency, AND power. plus good CS. Why would anybody waste money and some cheap overrated amp just to have it burn up in a few weeks? You have a 50/50 chance its even going to work out of the box. I have ran the cheap forum boners. I thought it was all good until I finally went my own way and got what I really should of got the first time. Call it over priced if you want but it walks on what I had before. Maxxsonics stuff, new PPI, new soundstream. Never had audiopipe but freinds do
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  4. #19
    i2ain2thunder's Avatar
    i2ain2thunder is offline CarAudio.com Veteran
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    Quote Originally Posted by DDtC View Post
    My next amp is going to be a sundown. I had a MA Audio HK 602sx, which honestly does way more than rated...but it is unclean, highly innefficient, and I have an extensive power supply that still doesn't seem to give it enough juice. Also had 2 resisters burn up on the amp and one of the transistors shorted out. The problems this amp was having managed to blow up one of my Dayton HO subs, so in the end I'm losing the $350 I spent on the amp, and the $250 I spent on the sub just to go buy the amp I should have bought the first time for $530. I have regret now and money loss from trying to save money the first time. I've learned my lesson and will stick with quality now, but to each their own. For all I know it had something to do with they way I set everything up that things happened. I did everything I could to ensure a quality setup. Electrical consists of a 300amp HO alternator/0gauge wire for big3 and 0gauge wired 2 yellowtop batteries. 0gauge to my sub amp, 4gauge to my speaker amp. Great grounds well done solid platinum or gold connectors. Gains set using a DMM to proper output voltage, and then cut down so as to be even more safe. I mean I was doing everything right as I understood it, and this still managed to happen, in my eyes the only thing I can see that caused this to happen was the poor quality of the amplifier.
  5. #20
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Quote Originally Posted by i2ain2thunder View Post
    Hey lets not knock Alpine Type R's too much, honestly in my book they are one of the best bang for buck spl sub out there, not saying they're top notch by any means but they do the job you would expect FROM A 50$ sub everytime.
    I'll add MB Quart amps are okie dokie for the price. They impressed me a bit for being a maxxsonic company.
    Since when are type rs 50$ ??
  6. #21
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    well you definately have to shop around, but i've owned around 6 type r 12s in my time and i always paid between $50-65 per new. Honestly best buy was having a special on them once for $50 BNIB. I guess if you don't search hard maybe u might spend $75 on one.
  7. #22
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,965
    109 Post(s)
    7680 Post(s)
    You really dont want to know how much I have wasted to this point. I'm sure I had some guy like the noobs we have now tell me its what I should get and everything else is overrated paying for a name. If I ever meet those people face to face now I would cause them a few grand worth of pain.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  8. #23
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
  9. #24
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    Like I said though. My amp did rated, **** it did well well well over rated, I was hitting rated output with gain at about 35% so it definitely had the power. I still had problems though I don't think the power was very clean and it was definitely highly inefficient.
  10. #25
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    everybody is so stuck on this "rated" that you would pay over $500 on a 2k amp just because the box says 2k and the amp produces 2k, when another amp will say 5k and will produce 2k but $300 less. at the end of the day i got 2k and paid $300 less
    the OP asked for affordable amp to hit average 2k watts and he also mentioned $250 budget, not sure why would you tell him to get a $479 amp?
    I have a hifonics brz 1700 for over a year and have no problem with it. Do i need to spend $349 for a sundown 1200 to get 1300-1400 watts? people run audiopipe with no problem, yes you hear people say their amp burned but have you asked how much percentage of these amps go bad and how many of those amp go bad because of mis use.
  11. Likes Dirtrider4eva, bgowdy liked this post
  12. #26
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    Mayhaps you didn't read my post. Going cheap ended costing me more money in the end. That is what us experienced guys try to err caution on.
  13. #27
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    how do we know that its not your fault? how do we know that you didn't ran that amp to the ground? and how many times have you seen the amp you have mess up like yours did?
  14. #28
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    Mayhaps you didn't read my post. I've already covered this point in it.
  15. #29
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    I guess to cover your question I've seen a few other people that have had very similar problems with the same exact amplifier. Parts of the circuit shorting, or components having improper voltage.
    Not to say that cheap amps can't work. I'm sure they do for some people I can believe that easily. All I am saying is for me I did everything I could to install and operate my equipment properly and still had issues, so my own personal belief is from now on it will be a better idea to stick with proven quality.
  16. #30
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,965
    109 Post(s)
    7680 Post(s)
    How about we just stop telling people what they want to hear and be REAL with them? You go around recommending stuff thats not even tested yet.... Thats fine but you need to say it. "Here are some cheap pre-order subs, they might be good but knowbody knows yet. Or you might get one and lose your *** cause they ****" OR "here are some cheap amps but they are going to need many $s in electrical, might do close to rated clean, might blow subs cause they are dirty, or might not work out of the box" OR " you can spend a bit more and get this proven preformer"
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  1. Need a good & affordable amp for my in car speakers
    By Bennieficial in forum Amplifiers
    Last Post: 05-31-2010, 10:12 PM
  2. Affordable Amp for Alpine Type R 12''
    By desi8389 in forum Amplifiers
    Last Post: 05-04-2009, 07:37 PM
  3. Affordable amp for subwoofer?
    By heat23 in forum Amplifiers
    Last Post: 11-08-2004, 04:54 PM
  4. Affordable amp for Type R??!
    By Afboy143 in forum Amplifiers
    Last Post: 08-03-2003, 02:04 PM
  5. Best and Affordable 10" sub for my amp
    By <SilverTruk> in forum Subwoofers
    Last Post: 12-10-2001, 06:15 PM
