Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: $1200 setup not sounding as good as $600
  1. #16
    kingbmw's Avatar
    kingbmw is offline Junior Member
    Apr 2013
    Kokomo, IN
    25
    6 Post(s)
    Re: $1200 setup not sounding as good as $600
    fair enough ill see what they can do.
  2. #17
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    Quote Originally Posted by kingbmw View Post
    Do not pay them until you verify what you are getting with people here. A lot of local shops do not know what they are doing.
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  3. Likes tc300 liked this post
  4. #18
    tc300's Avatar
    tc300 is offline CarAudio.com Veteran
    Mar 2007
    springfield,ill
    3,015
    605 Post(s)
    Op get rid of that daamn cap and have a box built around your cars cabin gain... Will be the best money you've ever spent and it will sound fantastic
  5. #19
    CaddieJapan's Avatar
    CaddieJapan is offline Senior VIP Member
    Feb 2008
    Japan
    268
    60 Post(s)
    BMW has a sealed trunk so I wouldn't expect much unless you cut the middle ski pass out. Bottom line you need to get more bass into the cabin. I had a 7 series prior too and experienced the same thing.
  6. Likes Garcia915 liked this post
  7. #20
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,647
    106 Post(s)
    7467 Post(s)
    You paid $1200 for that?
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  8. Likes Knowmadic, hispls, IonRL205 liked this post
  9. #21
    Knowmadic's Avatar
    Knowmadic is offline Senior VIP Member
    Feb 2013
    Winchester, VA
    495
    1 Post(s)
    159 Post(s)
    I cringed when I read you were using capacitor, max gain, max bass boost, and prefab box. Please do some more research on the site, you'll get guided in the right direction. First things first though, properly set that amp.
  10. #22
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,599
    15
    35 Post(s)
    3803 Post(s)
    This thread is full of bad advice from people who didn't even read OP's story.
    First if you broke one of those subs off a 1500W amp to the pair you're definitely clipping them hard. Really that's quite an accomplishment to break a 3" coil on 800W... you should be proud!
    Next, if they sounded good and you replaced one and you have almost no output even with cones moving, you hooked one up reverse polarity.
    Finally if the box is buzzing unless you press on it it has a broken seem. I'd say you could probably repair it, but it may or may not be worth the bottle of glue and handfull of screws.
    The point being if OP was happy with the sound until he blew a woofer than he really doesn't need anything but to hook it up properly, figure out how to not break woofers from gross abuse, and repair or replace that box.
  11. Likes DoesDad liked this post
  12. #23
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    2,290
    197 Post(s)
    Quote Originally Posted by hispls View Post
    ^^^^^Thank You!!!! Seems like no one every pays any attention to what was actually posted. You clipped the HELL out of those subs and amp. First of like was stated above, get those gains properly set and the polarity correct. I would def get a box built to spec, do away with the cap(waste of money) and the only other really good suggestion I saw here was to cut out the ski hole, this will make a huge difference. Bimmer's are sealed up pretty good, someone also mentioned the big 3 and this would be a good ideal in most other cars but I'm not really sure how much good it will do you in your E46 cause it may already be done from the factory, my E39 has 0ga from the factory so you may want to check.
    Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
    ____________
    refs:
    Type-S Texan ............Xtremebass5
    NE14MX ........Grinder1989
    NJack2AF
    .............Jameseypoo
    Randyrsx ..........Bagdntagd
    M3Transporter......Teggybwoy
    RJ Sclafani...........Zeuslicious
    Saltyreefguy........Qkassidyw
    Qtrhorse..............Nismos14
    Pistonsfan70........4nine
    SlainNothing.........Orangelss
    [email protected]............Louisiana_CRX
    SW9152..............DukeNut
  13. #24
    kingbmw's Avatar
    Apr 2013
    Kokomo, IN
    25
    6 Post(s)
    I set the pa880 on max not the zx1500 i set the zx on halfs at 70hz and blew a elite the polks surived the zx1500 at halfs and banged hard! Why cant these only difference is the boxes.
    No ski pass not even folding seats :x my polks hit hard you may think im crazy but compared to now. I paid 600 for amp with 3 year free replacement and 300 ea a sub with the same. No hassle just blow it and return it.
    Tried to get a l7 15... Wouldnt fit to save that poor techs life.
    Edit drivers side moves way more than passanger but its pushing the top corner of the box up and letting air out, which is the rattle
    Is the passanger hooked up wrong
Tags for this Thread
