Results 1 to 3 of 3
Reload Thread: Amp Selection Question
    kryptonitegamer's Avatar
    kryptonitegamer is offline Junior Member
    Apr 2013
    Logan,WV
    I have 2 JL w3v3 6.5 subs SVC 4ohm.
    I would need a 500watt at 2ohm amp to power them both right in a parallel, correct?
    Making them run at 2ohm, because you cannot run 2 SVC at 4ohm with one amp and running a 8ohm amp in serial to these would be impractical and costly.
    Is this correct? I am not a stereo savvy person just trying to get some insight before I order the amp.
    Thanks.
    ---Krypt
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    Re: Amp Selection Question
    run them at 2 ohm parallel yes that would be your best option , then get an amp thats 1 ohm stable for 1000 rms ,then if you ever wanna go with better subs then your good.cuz you'll get 500 rms from the amp at 2 ohms
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    Apr 2013
    Logan,WV
    Would a Alpine MRP-M500 work? it says 500w at 2ohm
  1. Amp selection question
    By jeffburgess10 in forum Amplifiers
    Last Post: 06-17-2011, 11:45 PM
  2. Cheap Amp selection + REM question
    By ps2cho in forum Amplifiers
    Last Post: 05-10-2009, 10:44 PM
  3. Amp Selection Question
    By mccanng in forum Amplifiers
    Last Post: 12-10-2008, 06:16 PM
  4. amp selection question
    By vibebreaker in forum Speakers
    Last Post: 08-09-2007, 06:39 AM
  5. Amp Wiring question and Amp Selection...
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 02-26-2002, 04:46 PM
