Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Amp Installation / Old School Amp / Cheater Amp Help?
  1. #16
    IloveTheBass's Avatar
    IloveTheBass is offline Junior Member
    Apr 2013
    LA,CA
    17
    3 Post(s)
    Re: Amp Installation / Old School Amp / Cheater Amp Help?
    Looks like my dad had it bridged.
    But at the same time he said he does not remember if the amp works as he thinks it burnt out. so I will try it out and if not then i will just use the Kenford. If not then the optimus.
    Thanks to all of you
  2. #17
    Apr 2013
    LA,CA
    17
    3 Post(s)
  3. #18
    NIHL8ION's Avatar
    NIHL8ION is offline RUN ur car NOT ur mouth !
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    Quote Originally Posted by IloveTheBass View Post
    GL to you :-)
    - Cadence DCA2500.1 Running a Tantric HDD - 12" D2
    *Bought From: cx-7heaven, nutnbutcustm, naughtyca, agarabaghi, Skip01*Traded With: infamous_e46, basswiigee**Sold To: DeanG, R.S.D., livinloud!*
    Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
  4. #19
    smgreen20's Avatar
    smgreen20 is offline phoenixphorum-com
    Apr 2005
    Lafayette,IN
    41
    1,175
    35 Post(s)
    The 100 is barely under rated, and when I say barely, I mean just that. These things are to sightly regulated, there's but 1 watt of difference from 12v to 14.4v. These amps will do 2 ohms bridged. To do so, have it in a very wide open spot, or have a fan on it. LANZAR made a fan pack for these for that reason. But yes, they WILL do 2 ohms mono all day long. THD is .002% at 4 ohms stereo.
    I don't know why people think that these are cheater amps. They're not. That's why I brought to light it's output. I believe that it's its Opti coupling that makes these amps sound so much more powerful then they are. Put it on that sub, you'll be amazed if that amp works and isn't fried as your dad said it could be. If it is, let me know. I might be interested in buying it from you.
    I'm a collector and user of these amps. This is my setup as we type.
    Opti150- 4 ohm stereo mids, Opti500- 2 ohms mono sub, Opti50- 4 ohms stereo tweeters.
    My install
    http://phoenixphorum.com/viewtopic.php?f=10&t=16998
  5. #20
    smgreen20's Avatar
    Apr 2005
    Lafayette,IN
    41
    1,175
    35 Post(s)
    Double posted above post. Why????
    Also, S/N is >100
    My install
  6. #21
    cablguy184's Avatar
    cablguy184 is offline SQ "White Lightning"
    Oct 2010
    Rankin Co. Mississippi
    47
    498
    49 Post(s)
    Quote Originally Posted by smgreen20 View Post
    Nice Amp Rack Sir ...
    Randal Johnson ... Comcast Xfinity ... 1997 Chevy Silverado 1500 Extended Cab ... 1949 Ford Custom Tudor Sedan
    Linear Power (TIPS) / Blues Car Audio ... Audio Technix ... Hyper Automotive LEDs and HIDs ... Mississippi Street Rod Association
  7. #22
    Apr 2013
    LA,CA
    17
    3 Post(s)
    I will let you know as I will install this on tomorrow.
    But quick question which gauge wire should i use again?
  8. #23
    Apr 2013
    LA,CA
    17
    3 Post(s)
    I will try it out. and also so I should bridge it to this sub?
    and if so what gauge wire? 2,4,8?
  9. #24
    Apr 2013
    LA,CA
    17
    3 Post(s)
    Also if the amp is fried should I worry about my battery being damaged or anything else?
  10. #25
    smgreen20's Avatar
    Apr 2005
    Lafayette,IN
    41
    1,175
    35 Post(s)
    8ga power and ground will be plenty for the 100 alone. 16ga speaker wire will be good for the wattage used. Your battery will be fin even if the amp is toast.
    Cablguy, thank you. I just got it put in this past weekend. I still have some fine tuning to do.
    My install
  11. #26
    Redlineaudio's Avatar
    Redlineaudio is offline The Glass is to Big
    Apr 2008
    Spindale NC
    41
    1,135
    12 Post(s)
    I would like to buy the amp if it is dead or if you don't use it.
    02 Quad Dak
    Cheap Flipout
    Phoenix Gold Ti2 6 1/2 front Memphis Pr 6 1/2 rear doors
    Phoenix Gold SL 10's Behind the rear seats
    Memphis Belle to power it all
  12. #27
    Apr 2013
    LA,CA
    17
    3 Post(s)
    Alright I will let you guys know how it comes out.
    Thank You
  1. Picked up a old School PPI 2150M Amp
    By smullen in forum Amplifiers
    Last Post: 06-09-2004, 10:31 PM
  2. amp for old school kicker solobarics
    By shareef777 in forum Amplifiers
    Last Post: 03-27-2004, 07:07 PM
  3. need helpon old amp (WAAAY OLD SCHOOL FOOLS)
    By mofugga in forum Amplifiers
    Last Post: 07-09-2002, 01:22 PM
  4. Amp info OLD school (Carver)
    By suburbanator in forum Amplifiers
    Last Post: 07-09-2002, 02:23 AM
