Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Reload Thread: What amp should I buy for 2 Pioneer TS-W309D2 subs?
  1. #16
    juanmgarza26's Avatar
    juanmgarza26 is offline CarAudio.com Elite
    Nov 2012
    McAllen, TX
    564
    160 Post(s)
    Re: What amp should I buy for 2 Pioneer TS-W309D2 subs?
    with this wattage, a 800-1000 watt amp at 2 ohms will do you well, the power you need should not be too expensive, everyone in here is a nuthugger for a certain brand, i recommend you a soundstream, crossfire if you can find cheap, and db drive personally would go with a db drive amp i'll put some links on here for you to look at
  2. Thanks basskill thanked for this post
    Likes basskill liked this post
  3. #17
    Nov 2012
    McAllen, TX
    564
    160 Post(s)
    Old School DB Drive SPA1200 1 1200 Watt RMS Mono Car Amplifier | eBay
    i've had quite a bit of these older spa series amps, i have never had a single problem with these, but i myself will warn you that thes e are class AB its a different circuitry and uses a little more power, class d is more efficient, i reccomend a class d amp myself, but me from personal experience would recommend the amp in the link
  4. Thanks basskill thanked for this post
  5. #18
    basskill's Avatar
    basskill is offline Junior Member
    Apr 2013
    Dallas, Tx
    8 Post(s)
    Quote Originally Posted by Full Tilt View Post
    You're new to the game, so let me tell you this - you never, ever, ever need to worry about 'Peak power handling'. Don't even look at it. As far as wattage goes, the only thing you'll want to look at on subwoofers is the RMS rating. Peak power handling is basically a huge number that a lot of manufacturers throw on their subs to make them look more powerful. It's an insignificant number. Only worry about RMS rating - since you have two subwoofers, you'll want to put their RMS rating together and find an amplifier that would match your power requirements well.
    How can I find out the RMS rating? its not on the website and I do not have the subs with me yet.
    Pioneer 12" DualVoiceCoil 2Ohm Subwoofer TS-W309D2 - Best Buy
  6. #19
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Quote Originally Posted by basskill View Post
    I noticed that. I'll look it up for you.
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
  7. #20
    Nov 2012
    McAllen, TX
    564
    160 Post(s)
    click on the "overview" tab it says "nominal power" thats the rms
  8. #21
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    I just looked it up. Amazon says it's nominal rating is 400w. Since you have two subwoofers, you'll be looking to find an amplifier that puts out about 800 watts at whatever impedance you plan on running. You have two 2-ohm subs, so your best bet would be to run one in series and one in parallel for a 2-ohm load. So, again, try to find an amp that will put out around 800w @ 2 ohms.
    P.S. - You said you came from home audio, do you know what I mean when I say wiring in parallel/series? If not, I'd be happy to explain along with answering any other questions you have.
  9. #22
    basskill's Avatar
    Apr 2013
    Dallas, Tx
    8 Post(s)
    I kinda understand series vs parallel. Isnt parallel always better? It gives independent output to ech speaker, right?
    I would appreciate you explaining how it work in car audio. Also, if there is any online documentation with diagrams, that would help too.
  10. #23
    06gtmike's Avatar
    06gtmike is online now Senior VIP Member
    Oct 2008
    Williamsburg, VA
    295
    37 Post(s)
  11. #24
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Subwoofer Wiring Diagrams, Two 2 ohm Dual Voice Coil (DVC) Speakers
    Boom.
    Basically, the way you wire your subwoofers up is what determines your final impedance that the amplifier is seeing. Check out those pictures in the link I posted - The12Volt.com is an awesome site to look up stuff that you might need to know. All I had to do was google 'Subwoofer wiring diagram the12volt and it came up - I put in '2 subwoofers' and '2 ohm DVC' and it brought up every wiring configuration possible for your setup, which I posted above. Those diagrams will show you all of the ways you can wire your subs for the different impedences available to you.
    By the way, no impedance is really 'better' or 'worse' than any other ones. You just use different ones to achieve different impedences, depending on what your setup looks like. Some people argue that parallel is better to run, just because most amps are more efficient at lower impedances, which is what 'parallel' does. However, there are many situations where wiring in series is more appropriate, because some amps can't operate below 2 ohms. So, if somebody had a 1-ohm DVC sub but an amp that ran at 2 ohms, they'd have to run a 'series' load. I hate to confuse you, it's just install-dependant.
  12. Likes basskill liked this post
  13. #25
    eli346's Avatar
    eli346 is offline Member
    Dec 2012
    United States
    104
    48 Post(s)
    I've been running two of these on 1100 rms for about 2 months now they're actually pretty good subs considering they were $39 a piece... They do get pretty warm to the touch after playing for a while but that's because I'm giving them a bit more than what they're rated at.
  14. #26
    06gtmike's Avatar
    Oct 2008
    Williamsburg, VA
    295
    37 Post(s)
    Not sure if you picked up a box yet but if you're looking cheap here ya go. It's not gonna be your best option but for the price and since you're just starting out it's not bad. Everyone here will tell you to get a custom made box which I agree with but since you're just gonna upgrade in a few months once you catch the disease, wait until you get some good subs to drop a few hundred on a box.
    Fierce Audio - 12" Dual Ported Flat Pack Subwoofer Enclosure - FPSP212.1
  15. Thanks basskill thanked for this post
  16. #27
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,416
    140 Post(s)
    1 Thread(s)
    6007 Post(s)
    American Bass - VFL 1880 1D this is what you need for the subs 180 shipped new
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  17. #28
    basskill's Avatar
    Apr 2013
    Dallas, Tx
    8 Post(s)
    Boom.
    This is awesome ! Thanks !
  18. #29
    basskill's Avatar
    Apr 2013
    Dallas, Tx
    8 Post(s)
    Also, should I get an equalizer along with an amp? I heard an equalizer makes a lot of difference.
  19. #30
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    I've personally never run one.
  1. What Amp should i get for my DB DRIVE SUBS?
    By taraku in forum Amplifiers
    Last Post: 10-15-2012, 02:26 AM
  2. What amp should I buy for my subs?
    By raminat0r in forum Amplifiers
    Last Post: 09-25-2011, 07:57 PM
  3. What amp should I buy for my 2 L7 12" Kickers!??
    By thaking in forum Amplifiers
    Last Post: 08-26-2010, 02:47 AM
  4. What amps should I buy for 10,000ish RMS, 1 big one or a few.
    By 46panel in forum General Discussion
    Last Post: 07-28-2010, 04:37 AM
  5. What amp should I buy? for Alpine Type X.
    By rotciv005 in forum Amplifiers
    Last Post: 02-18-2006, 09:31 PM
