You could look into an Alpine PDX-F4 if you were looking to go the multi amp route. It's not that bad if you find a used one.
It used to. I personally can't hear the difference. The Class D full range amps today are all pretty good so you may not be able to hear the difference either. Obviously some are better than others. I just moved from an "SQ" A/B to a class D and I can't hear the difference. Granted it's a "good" one, but still. That JL is a good one. Even that little PPi is a good one. I wish they'd get off their ass and get that phantom 5 channel on the market already.
There will be purists that will swear to you that they can hear the difference between A/B and D. But the (arguably) best SQ car on the planet right now uses all class D amps.
Read the end of my second post.
@-Josh- ; not if you dont know the clipping point of your head unit and amp.
"When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
I know, if ppi did have the 900.5 on the market I wouldn't be in this situation. So it is just based on preference, I follow. Personally, I prefer the D because it won't tax my electrical system as much. That is why I originally listed mostly d styled amps. One last thing about a sub, just so I can clear this up. If want a nice accurate, deep, and tight bass so I would go with a sealed enclosure?
Do you mean hitting the lower frequencies? You are correct I don't really care about the output levels in regards to loudness. I would match the sub based on the amp I pick. But with putting in a ported enclosure they take up to much space unless I were to go with something like one of JL's microsubs.
Bump for more opinions.
So I decided to go with the Alpine MRX-V70. Now I am looking for a sub for my system, out the ones I picked out, which do you think will best fit my application. The sub will be in a sealed enclosure.
Compare: Component Subwoofers at Crutchfield.com
Id look at a Dayton DVC 4ohm 10,or 12 for the price you would be buying a JL sub for, and they come with a 5yr warranty.Sound great in sealed enclosures,as well as ported,small spaceshttp://www.parts-express.com/pe/showdetl.cfm?partnumber=295-463,and will be great on that amp
http://www.parts-express.com/pe/show...number=295-463
Double post?
Bookmarks
