Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 82
Reload Thread: This cannot be good! Fried my amp. (Gut pics inside)
  1. #61
    l Droopy's Avatar
    l Droopy is offline Member
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Re: This cannot be good! Fried my amp. (Gut pics inside)
    Quote Originally Posted by hispls View Post
    Over-fused again.... you're a slow learner.
    Dunno much about PPI these days, but I haven't heard any horror stories about those so probably a step up.
    I searched on google for about an hour plus just to verify what size fuse i need to run inline to my amplifier, that includes on this forum, and there were multiple
    threads on this situation. Every single person said to fuse to whatever size wire you have running to your amplifier. besides, isn't that why amplifiers have fuses on them?
  2. #62
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,621
    8 Post(s)
    722 Post(s)
    newer ppi is soundstream. i havent had any issues with the rubi amps, the 1600.1 get pretty hot @.5 daily. the 2500 stays just warm, no complaints...
    never mount to a box unless the box is really strong and mounted to the car...
  3. #63
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Quote Originally Posted by SPLaudio View Post
    My box is not that strong, I did not doubled it up or have any kind of bracing besides having 45's in all the corners, and i'm pretty sure just 45's won't do a whole lot of good as far as bracing. I was extremely paranoid about mounting it on the bacc side of the enclosure... This is what Spooney said about the Rubicons "This style of amp was notorious for vibration related failures and mounting the amp on the sub box doesn't help matters any. I would make all efforts to mount my amp securely somewhere else next time around. The inductors in these amps had a lot of issues with shorting out on themselves due to vibration." When i get my new amp on thursday I will probably just build an amp racc for it.
  4. #64
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,963
    15
    36 Post(s)
    4053 Post(s)
    Quote Originally Posted by l Droopy View Post
    Fuse wire for wire size for sure. Many amp manufacturers have discovered that various forum smarty pants' figured out Ohm's law well enough to know they lie about power ratings by looking at on-board fuses... so they over-fuse.
    It's a shame if PPI is now Soundstream/Power Accoustic. Good luck with that.
  5. #65
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Oh ok thanks for the info bro. I appreciate you being straight up with me and letting me know some real facts, I'm not afraid to admit that I was wrong about the over-fusing. I was just a little confused for a minute there lol What would you suggest I go about this situation? I looked all over for reviews on the ppi phantom and only found like 3, all were 5 star reviews though. So i am really curious as to how it will perform. I'll write up a review when i receive it and get a little play time, I know a couple ppl who would like to know if it is worth their time and money as well.
  6. #66
    NIHL8ION's Avatar
    NIHL8ION is offline RUN ur car NOT ur mouth !
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    If you are looking for a half way descent "Budget amp" - I've heard good things about Lanzar Opti's - NOT The Newer 2001 / 3001 / 5001 series, but the slightly older 2000 / 3000 / 5000 Series which if you look around, can still be had new or refurb with a warranty for dirt cheap - You can get a Lanzar Opti2000D That's rated at:
    700 rms @ 4 ohm / 1100 rms @ 2 ohm / 1600 rms @ 1.3 ohm / 2000 rms @ .5 ohm - For $239.95 Shipped - I bet that would beat the tar out of an SA Wired down to 1 ohm ;-) Other than that I'd look for a nice Used DD, Sundown, Audiodique, Or Crescendo For what you are looking to do... I like to run Orion HCCA's, but that's just my preference, there are better amps out there, but Every Orion I have had over the years has been nothing but good to me :-)
    - Cadence DCA2500.1 Running a Tantric HDD - 12" D2
    *Bought From: cx-7heaven, nutnbutcustm, naughtyca, agarabaghi, Skip01*Traded With: infamous_e46, basswiigee**Sold To: DeanG, R.S.D., livinloud!*
    Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
  7. #67
    PPI_GUY's Avatar
    PPI_GUY is offline Senior VIP Member
    Dec 2009
    Somerset, KY
    274
    44 Post(s)
    OP, you shouldn't have a problem with that PPI amp you just picked up. It'll do 1200 watts at 1 ohm. That same circuit board is being used by several popular manufacturers currently...NVX, Nakamichi, Polk, etc.
    Read the manual PPI sends with it and fuse exactly as they recommend. Double check your ground and do NOT mount an amp on your sub box ever again.
    Absolutely State of the Art!
  8. #68
    PPI_GUY's Avatar
    Dec 2009
    Somerset, KY
    274
    44 Post(s)
  9. #69
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Quote Originally Posted by NIHL8ION View Post
    Dammit, wish i heard that earlier before I purchased the ppi. Ohwell if i dont like it i'm pretty sure i can send it bacc to sonicelectronix for a refund.
    besides that was slightly out of my budget at the time and i need a new amp asap
  10. #70
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Quote Originally Posted by PPI_GUY View Post
    Yup had to learn that the hard way unfortunately... **** happens. Well that is reassuring, I need a smaller amp i could mount under the seat or somewhere else other than the box. That will never haapen again!
  11. #71
    NIHL8ION's Avatar
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    Just giving you a heads up ;-) I've installed a few of these over the past 2 years or so, All of them are still up and running, or else I would have gotten an earful about it I'm sure lol - GL with your system :-)
  12. #72
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Ya for sure lol Thanks bro, i appreciate it! =] The ppi will just be temporary for now unless I end up liking it alot. I'll be sure and checc one of those out, doesn't sound to bad for the price.
  13. Likes NIHL8ION liked this post
  14. #73
    hispls's Avatar
    Sep 2009
    9,963
    15
    36 Post(s)
    4053 Post(s)
    "reviews" on retail sites are typically by people who have no idea what a good product is. Search forums for more reliable reviews.
    Definitely this^^^
    If size is an issue you should look at Stetsom. I don't know what they have for that little power, but I've run the 7K and 4K2d and had good luck with both.
    Go over to the Zed Audio site and download his manual. 80% of it is just general info on electronics and amps and is well worth a read. He has a very good philosophy on fusing. You would be amazed at how little fusing you actually need 99% of the time for normal music.
  15. #74
    Nov 2006
    North AL
    2,754
    6 Post(s)
    IDK what your problem ended up being, but it really looks like you are just in a big hurry and cutting any corner you can. This isnt really related to your thread, but take your time brother.
    2- 3515's
    2- RD 1750v2's
    Critical Mass 5x7's
    2- C&D batts
    Box
    Check thread for pricing
  16. #75
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Definitely this^^^
    Ok sweet i'll definitely checc out his manual. I Could really use the knowledge and learn a bit more about car audio/ electricity
    2 AQ QP-MR6.5's
    Sundown Sa-12 D2
    Custom 3/4" MDF 2.25 CuFt Tuned @ 32Hz
    Precision Power PPI P1000.1
    Streetwires Negative battery Terminal
    Kolossus Flex 0 Gauge for big 3
    Kolossus Flex 4 Gauge running to amp
    KonFused Positive battery Terminal
    KnuKonceptz Krystal Kable 2 Channel RCA's
    Second Skin Damplifier Pro
  1. Will this amp kit be good for my setup
    By Jberger93 in forum General Discussion
    Last Post: 03-24-2013, 03:21 AM
  2. Replies: 1
    Last Post: 06-18-2007, 12:17 AM
  3. i got my amps.woot pics inside
    By mike dressure in forum Amplifiers
    Last Post: 01-12-2007, 05:53 AM
  4. would this amp be good for my speakers??
    By im2slpy in forum Amplifiers
    Last Post: 06-04-2005, 04:36 PM
  5. will this wiring kit be sufficient for my amp and subs?
    By madmaniac in forum General Discussion
    Last Post: 04-17-2004, 10:18 PM
