Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 82
Reload Thread: This cannot be good! Fried my amp. (Gut pics inside)
  1. #46
    l Droopy's Avatar
    l Droopy is offline Member
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Re: This cannot be good! Fried my amp. (Gut pics inside)
    Quote Originally Posted by americannight View Post
    What about vibration on amps in general? Lots of pressure in my trunk and even with the amps mounted on the side walls, they've got to be shakin' a little. Here's the setup I'm running:
    Volvo S60 build resurrected! Old School!
    Should I be concerned about vibration or is this more of an issue when the amps are mounted directly on the box? Aren't the better built amps designed to withstand the typical vibrations of a car audio system?
    Dam bro that set up is fuccing CLEAN!!! looks so sicc! great job man keep up the good work
  2. Thanks americannight thanked for this post
  3. #47
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Quote Originally Posted by VWGolfMKVI View Post
    Just sent mine in for exchange. Bought from a local authorized dealer. They should have my fried one tomorrow and i will hopefully have a new one by next week.
    I bought mine off of online car stereo so idk if i am able to exchange amps with them or soundstream direct
  4. #48
    americannight's Avatar
    americannight is offline Senior VIP Member
    Jul 2010
    Bellevue, WA
    178
    36 Post(s)
    Quote Originally Posted by l Droopy View Post
    Thanks man, I'm really enjoying this setup. I'm still making small improvements such as tonight adding another layer of sound deadener to the trunk lid. It helped. Now there are two layers on there. Might go for a third. **** VIBRATIONS!
  5. #49
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    How much are you running in there? I bet that **** SLAMS! lol I dont see why not, the more the merrier... The Rubicon i have when it was still working absolutely slammed with my Sundown Sa-12. Rattles way to much, sounds ******... lol I actually just ordered Damplifier Pro and it showed up today, not like i am able to tell the difference now that my amp is completely fucced... =[
  6. #50
    Jul 2010
    Bellevue, WA
    178
    36 Post(s)
    How much are you running in there? I bet that **** SLAMS![
    It slams really good and most importantly I can listen to any kind of music on this system and enjoy it. This system tows the line between bass and SQ. These Zed Deuce amps were really the last of an era of the Stephen Mantz built cheater amps, as some folks call 'em. Class A/B design, they are way under rated and put out a sick amount of clean power. I've exchanged some emails with Stephen and he says these amps put out more power on his bench test than the original hi-fonics Zeuss, if that helps put it in to perspective. So rated, I'm giving 800 watts to the subs. In reality I could get 1000+ out of the amp into 4 ohms if I really push it and the power is really clean. Haven't seen these amps on ebay in a while but if you see one for a good price, snatch it up. You won't look back from the rubicon.
    What are you running for subs?
  7. #51
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    I'll definitively make sure to snatch one up if i get the chance. I have never ran any of his amps yet, reason being they are quite spendy! lol I couldn't imagine going from what i have now to a Zed made amp. From what i have heard they are phenomenal amplifiers... Maybe one day in the near future. Right now i am only running a single Sundown Sa-12 D2 in a 2.25 CuFt box tuned to 32 hz. I was running it at 1 ohm on the Rubicon and it hit so dam hard! Along with the Second skin i placed an order on knukonceptz for a positive battery terminal and a inline fuse, was going to finish my big 3... As of right now i only have the grounds done.
  8. #52
    CaddieJapan's Avatar
    CaddieJapan is offline Senior VIP Member
    Feb 2008
    Japan
    268
    60 Post(s)
    If you guys are mounting your amps on the enclosures or side walls I would recommend vibrapods. They come in different sizes and work very well for shock/vibration absorption. Check them out here.
    The Vibrapod Company
    Even these would help out
    http://www.amazon.com/Amico-40mm-Fur.../dp/B007HKFQS2
  9. Thanks americannight, l Droopy thanked for this post
    Likes l Droopy liked this post
  10. #53
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Quote Originally Posted by CaddieJapan View Post
    Amico 10 Pcs 40mm x 22mm Furniture Cone Rubber Feet Pad Cove Bumper - Amazon.com
    That is exactly what i was looking for before my amp took a dump on me lol i'll have to picc some of those up when i get my amp fixed, or if i buy a new one. Might just picc up an AQ1200D for $269.
  11. #54
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,680
    15
    35 Post(s)
    3856 Post(s)
    Quote Originally Posted by raptor727 View Post
    I have always mounted to the box abd have yet to have a problem... quality amps should not have an issure with this imo
    Really depends on how solid the box is. I've discussed this with Stephen Mantz (who by most people's reckoning makes good amps) and he suggested to avoid mounting to box if at all possible.
    Pretty certain that amp is over fused at 160A
  12. #55
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Quote Originally Posted by hispls View Post
    You're probably right bro, but I received the Rubicon with 4 x 40 amp fuses already in it and that adds up to 160 amps... i figured it would be safe to run a 150 amp fuse on the power wire so it wouldn't go over 160 amps. but i doubt that my alt could ever put that much out stocc in a 95 honda civic. Also wouldn't the fuse blow on the power wire if it went over 150 amps or at lease the fuses on the amp?
  13. #56
    hispls's Avatar
    Sep 2009
    9,680
    15
    35 Post(s)
    3856 Post(s)
    The BATTERY can push a lot of current, and fuses can pass well over their rating for long enough to cook an amp before opening. If you can't afford to blow up amps it's well worth under-fusing and only increasing fuse size gradually if you keep blowing fuses. Even a dozen fuses is probably cheaper than return postage you're going to eat sending that amp back.
  14. Thanks l Droopy thanked for this post
  15. #57
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Ok thanks bro i appreciate the response! Learn something new every day. I hit up Spooney and sent him the pictures to see what he thought about it, and he said that "This style of amp was notorious for vibration related failures and mounting the amp on the sub box doesn't help matters any." Regardless I have enough money for another amp, whether it's on the classifieds or anywhere else. What amp would you recommend for a Sundown Sa-12?
  16. #58
    hispls's Avatar
    Sep 2009
    9,680
    15
    35 Post(s)
    3856 Post(s)
    Most of the more popular Korean amps should have a solid 1K offering. More mainstream, the JBL 1200.1 is solid and Kicker has made a few in the 1000-1200W category that are reliable. If you can find one used the ED Nine was really popular for a 1200W amp. If you have some money to spend and a 2 ohm load Zed Minotaur is great and quite advanced, and of course Zapco, Arc, Audison, and the other premium brands are typically good performers that'll hold resale value.
  17. Likes l Droopy liked this post
  18. #59
    l Droopy's Avatar
    Mar 2013
    Eastern, OR
    52
    10 Post(s)
    Thank you for all of the feedbacc bro, i really appreciate it! I decided to purchase a PPI1000.1 Phantom off sonicelectronics just for a temporary amplifier, and it fit my budget at the time. Figured why not give it a chance since it's really underated for 1k at 1 ohm. Spooney pointed out that it is actually fused for about 1200 Rms.
  19. #60
    hispls's Avatar
    Sep 2009
    9,680
    15
    35 Post(s)
    3856 Post(s)
    Over-fused again.... you're a slow learner.
    Dunno much about PPI these days, but I haven't heard any horror stories about those so probably a step up.
  1. Will this amp kit be good for my setup
    By Jberger93 in forum General Discussion
    Last Post: 03-24-2013, 04:21 AM
  2. Replies: 1
    Last Post: 06-18-2007, 01:17 AM
  3. i got my amps.woot pics inside
    By mike dressure in forum Amplifiers
    Last Post: 01-12-2007, 06:53 AM
  4. would this amp be good for my speakers??
    By im2slpy in forum Amplifiers
    Last Post: 06-04-2005, 05:36 PM
  5. will this wiring kit be sufficient for my amp and subs?
    By madmaniac in forum General Discussion
    Last Post: 04-17-2004, 11:18 PM
