+ Reply to Thread
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 67
Reload Thread: The truth about rockford fosgate
  1. #46
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    24
    565
    Re: The truth about rockford fosgate
    Quote Originally Posted by cleansoundz View Post
    A lot to learn. I have never blown an amp or subs since 1989, well educated, married with a house and kids. Coming from a 24 yr old you sound like an idiot.
    Lol okay, my statement was strictly about car audio. I don't care how long you have been in this hobby, this thread shows how little you know about it. I was trying to be nice but you are making it hard.
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  2. #47
    cleansoundzz's Avatar
    cleansoundzz is offline CarAudio.com Elite
    Apr 2008
    Buena Park
    1,804
    1 Post(s)
    Even about car audio. I know that the Matrix is a line driver that increases voltage that goes out to the amplifier thus reducing the gain level on an amplifier which also reduces noise. I am aware of the differences in voltage between the RF amp (5 volts) and Kicker amp (12 volts). I am also aware that the difference in bass can be attributed to the lower voltage level of the RF amp. I am aware also that my matrix has been set has been set to the maximum level of distortion with my head unit at 3/4 volume. Knowing all of that I do not use the gains on my amp because I am trying to reduce distortion. I also know that the RF gain at minimum will not be the same because it is 12 volts. I am aware that the gain will have to be turned up to compensate in the differences in voltage between the RF and Kicker amp. I am aware of how to set gains properly using a DMM. I am aware of how to measure an amps actual wattage using a DMM. I am aware that I need to use test tones when I set gain levels on amp. I am not also aware that the birthsheets given by RF do not mean a hill of beans to me.
    02 4-Runner-Knwd X896-Acntrl Matrix-JL 300/4 V3 on Crssfre Separates-JL 1200/1 V3 on-2 RE Audio SE(x) 10s
    90 300zx-Knwd X496-Acntrl Matrix-JBL GTO504EZ on Crssfre Separates-JBL GTO751EZ on RE Audio SE 10
    REFERENCES: BEATNOUTDAFRAME, VIVEET, CX-7HEAVEN, GMAN42, SUNDOWNZ, ZERMELO, M3NTAL, GAM3OVR, HEMI=22s, PROJECTPECKIN, KRISFNBZ, WHEELIEKING71, MR. RONIN-2U, ROBERTQ, DJM4RSHM21LOW, BLACKBONNIE, GYMFREAK101, STUCKINOK, SIACARMAN, ONEINTHESAC, 97SRAD750, ETC AND MANY MANY MORE[/FONT]
    Formerly cleansoundz
  3. #48
    ciaonzo's Avatar
    ciaonzo is online now TheContinental
    Feb 2009
    WI
    8,651
    23 Post(s)
    We all do things different ways. I think it's an old school thing to use the ol' ears to tell you what's going on. I still set gains using my ears most of the time, mostly because I listen to music like floating in a tube down the river as opposed to white water rafting. I'm usually limited by excursion rather than thermal issues, so I just use familiar music and back off the gains when I hear things I don't like coming from my drivers. Then it's simply a matter of blending the drivers' levels to each other for the balance I prefer. Viola!
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  4. #49
    ciaonzo's Avatar
    Feb 2009
    WI
    8,651
    23 Post(s)
    Quote Originally Posted by TaylorFade View Post
    This is hilarious. You start a "Truth about RF" thread, yet have ZERO evidence to back up your "findings." Apparently because "you didn't feel like it." Yet you continue to backhandedly praise RF. I'm confused.
    Their birthsheets are suspect, yet you didn't clamp. You say 40% more output; except that- that would indicate the very smallest increase in sound pressure that we can detect. Yet you go on to say that the 40% increase is a huge difference in output.
    Several people in here have pointed out already that gain position is an absolutely useless indicator without a reference voltage. And your insistance on alluding to gain position is a discredit to your conclusions.
    Basically... you are stating opinions. Which you are certainly entitled to do. But I see no truth in here other than the points made by everyone else.
    And this vvvvv
    Awwwww, Tfade. You go eat a Snickers. You get grumpy when you're hungry.
  5. #50
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,386
    74 Post(s)
    My JL amp gets super loud at only volume 3. I'm scared to turn the volume up to like 10 because my ears might pop. The subs can't barely handle volume 6.
  6. #51
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    You my friend are a clown. I am not going to sit here and argue with you. My ears dont lie and regardless of what you say, I can tell the difference between more and less power and bass in my system. I am not some 22 year old who turns up the bass boost to maximum and makes stupid comparisons. LIKE I SAID BEFORE WHEN I CONNECTED THE RF P1000X1BD TO MY SUBS! IT TOOK A LOT OF WORK TO GET SOME DECENT BASS OUT OF MY SYSTEM. AS SOON AS I DISCONNECTED THE RF AND CONNECTED THE ZX 750.1AND LISTENED TO THE SAME TRACK THERE WAS A HUGE DIFFERENCE IN BASS. IS THAT TOO HARD FOR YOU TO UNDERSTAND. DO YOU WANT ME TO EXPLAIN IT TO YOU LIKE A FIFTH GRADER. MORE BASS. THE GAIN ON THE RF AMP WAS 3/4 OF THE WAY SET RIGHT BEFORE CLIPPING. I USED A DMM TO SET THE ZX750.1 A WHILE BACK BEFORE I DISCONNECTED THE AMP. EVERYTHING WAS SET ON THE ZX750.1. I DIDN'T THINK I NEEDED A DMM WITH THE RF AMP BECAUSE IT HAS IT'S OWN CLIPPING INDICATOR. CLIPPING INDICATOR'S ARE NOT ENTIRELY USELESS. "THAT MY FRIEND IS A GENERALIZATION". ALL I STATED IS THAT RF BIRTHSHEETS ARE PROVEN TO ME TO BE USELESS. THEIR MONOBLOCK AMPS DISSAPOINTED ME. DOES THAT SOUND LIKE I AM PRAISING THEM? IF YOU CAN'T ACCEPT THAT THEN TOO F67CKIN BAD.
    EITHER YOU ARE A RF NUTHUGGER OR ARE VERY STUPID.
    I'm neither an RF nuthugger nor stupid. And no, I don't want you to explain it to me like *I* am a fifth grader, but you certainly explained things like *you* are a fifth grader. You see... when exposing "truths" or doing any testing at all to share information... you need like, umm... facts. Which, you have none.
    I'm not surprised you're not going to sit there and argue with me. I wouldn't want to argue with me either.
    Quote Originally Posted by ciaonzo View Post
    I eat ignorant people when I get grumpy. Philosophically speaking, of course. I also can't abide by subjective "testing" like this. It's annoying and misleading. I'm all for subjective tests when subjectivity is called for. But this isn't one of those cases. If you want to do an amp throwdown, at least bring a damn DMM and a scope to the party.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  7. #52
    Apr 2008
    Buena Park
    1,804
    1 Post(s)
    You are a clown. I stated my case, it wasn't accepted and that's it. Time to move on. Good day to you chump. I am done.
  8. #53
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    At least I'm a clown that knows how to test amps and present the information in a useful manner.
    ZOMG!!! muh keecker map is 50 deebeez lowder then a stoop rockford en teh birthsheet is bolonie!!! in das duh troof. i beez tessed eet.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  9. #54
    Apr 2008
    Buena Park
    1,804
    1 Post(s)
    Are you speaking English or Ebonics? Making a point and not using proper English, really makes you look like a fool. Learn how to use proper grammar when speaking online.
  10. #55
    Sep 2010
    Drowning in milk
    7,386
    74 Post(s)
    Palm meet face
  11. #56
    Apr 2008
    Buena Park
    1,804
    1 Post(s)
    Quote Originally Posted by princ3cmo View Post
    Palm meet face
    Make sure you enroll TaylorFade at a local college, have him take an English Assessment test and get him in an English class to teach him how to write. Also teach him that testing car amplifiers is not the end all be all in life and there is more to life than car audio. Such as paying bills, taking care of your family and most of all not taking life too serious. When I start stooping down to his level and arguing about testing a God **** car amplifier then it's time to check out. I have other more important priorities in life.
  12. #57
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    Says the fellow using a 'z' to pluralize his screen name. Duly noted, professor.
    By the way... can you stop by the pits at finals and set my amp for me before I run? I want to make sure they're set up perfectly. Like yours.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  13. #58
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    You mean "seriously"?
    Bro, do you think you're the only one with a job that can pay a mortgage and feed the family? AND enjoy CA? You're not a special or unique snowflake.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  14. #59
    Apr 2008
    Buena Park
    1,804
    1 Post(s)
    The more you talk, the more stupid you sound.
  15. #60
    Apr 2008
    Buena Park
    1,804
    1 Post(s)
    Maybe not but I can do more than test amps. I never said anything about enjoying California you fuckin idiot. I never said I was special. You **** sure ain't my bro.
+ Reply to Thread
  1. the truth about WOOFERSETC and other online stores
    By therealdeal in forum General Discussion
    Last Post: 07-03-2005, 07:35 PM
  2. The truth about capacitors?
    By teqnek in forum General Discussion
    Last Post: 01-21-2005, 10:43 AM
  3. The truth about capacitors?
    By teqnek in forum Wiring, Electrical and Installation Help
    Last Post: 01-19-2005, 12:12 PM
  4. the truth about dampening? jlaine? anyone?
    By d audio 450 in forum General Discussion
    Last Post: 06-25-2003, 02:49 PM
