Mmats......
Mmats......
YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
my old crossfire cfa 1000 Was the most efficient 1k amp I ever had
^this^^ amp efficiency is measured at 4ohm and usually at 100HZ dropping your amp to 2-1-.5 ohms completely destroys its efficiency,yes there are amps that will draw less amps at 1ohm than some other amps,but you need to remember the less(power) an amp takes in the less(power)it will put out
bought from: wccoug21 sundownz thegreatestpenn loudwhat? woofercooker jonny101abc spooney fasfocus00
sold to: jpx18 Nateberrier Ge_off_me spm_215 2lo2flo akheathen etm34 djjdnap jfroghobo traded: SPLaudio Zeuslicious
under construction:
1992 Toyota Paseo(1) Pioneer DEH-P500UB head unit(2)American Bass VFL 500.1 amps(4) stinger batteries,building 2 10's in tubes
Zed Minotaur would probably be very solid on average since it runs at a lower rail voltage until you ask it to produce more power, then jumps up.
Class D amps are at optimum efficiency at full power and at higher impedance.
Real world your average efficiency will be nothing like the numbers manufacturers claim, though of course, real world you're likely only seeing 10-15% of it's rated output on average either.
R.I.P. 2008 Hyundai Tiburon GS
2005 Subaru Baja turbo, build in planing stages.
tc300 liked this post
Probably most answers are a speculation as you need to test this formally. If you're worried about efficiency, get a solid Class D mono amp that does 1200watts with 2ohm load. I can't imagine efficiency being worse than 70% at max output level.
MMATS
MMATS
and MMATS!!! Lol
MODS
What is your electrical like as of now? You are NOT going to switch to a different ~1100 watt amp and suddenly see much better voltage.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
Front stage amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
Team SSA
I think with your setup you need to be asking what the most efficient 1500 watts amp is which again is Mmats.
Hu: kenwood kdc-x995
Sub: Boston acoustics G5 12 in a quasi 6th order
Amp: Eclipse Xa5000
Front Speakers: Eclipse sc6500
HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
Bookmarks
