Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 67
Reload Thread: DC 2.0 vs AQ 2200
  1. #46
    NuckinFutz's Avatar
    NuckinFutz is offline CarAudio.com Elite
    Jul 2012
    Shreveport, La
    832
    292 Post(s)
    Re: DC 2.0 vs AQ 2200
    Quote Originally Posted by blockburner View Post
    its under battery specs for what ever battery you look at. Do your big three and buy a $20 stinger cig light voltage meter. If your voltage dips below 12volts, then I Suggest you start looking for a battery with at least 75 to 100 AH. Amp hours is how many amps you can draw in one hour.
    But its not saying like "this battery will only last 75 hours with whatever watts"?
  2. #47
    NuckinFutz's Avatar
    Jul 2012
    Shreveport, La
    832
    292 Post(s)
    Stinger SVMB Voltage Gauge - Blue Display:Amazon:Car Electronics
    And will this one be good, don't really like the look of the cigarette lighter one.
  3. Likes joom liked this post
  4. #48
    blockburner's Avatar
    blockburner is offline CarAudio.com Elite
    Mar 2011
    Boston ma, United States
    538
    154 Post(s)
    take this advice and do a google search on an am hour. its a little more complicated but what I previously mentioned is definately a good starting point.
    http://mobileaudioforum.com/forum/itrader.php?u=196
    TEAM TANTRIC
    08 ESCALADE/SINGER/DD/SMS/XS/TANTRIC/KENWOOD
  5. #49
    Mar 2011
    538
    154 Post(s)
    Quote Originally Posted by NuckinFutz View Post
    tis will be just as good. difference is you can take the cig lighter one out
    TEAM TANTRIC
  6. #50
    NuckinFutz's Avatar
    Jul 2012
    Shreveport, La
    832
    292 Post(s)
    I looked it up and just didn't fully understand if when it drained a bit if that was the end of the battery or if you could charge it back up.
  7. #51
    Mar 2011
    538
    154 Post(s)
    no its not the end of the battery but yes you have to understand the charge cycle of a battery. all of this is easy reading to put you to sleep at night. just start google searching and one ? leads to another answer if you really want to know all the ins and outs of it.
    TEAM TANTRIC
  8. #52
    NuckinFutz's Avatar
    Jul 2012
    Shreveport, La
    832
    292 Post(s)
    Will I be able to charge it with my alt or would I have to use a battery charger?
  9. #53
    NuckinFutz's Avatar
    Jul 2012
    Shreveport, La
    832
    292 Post(s)
    Never mind. Found the answer on my first search. Wire in a parallel with the first battery and it'll charge it.
  10. #54
    Mar 2011
    538
    154 Post(s)
    TEAM TANTRIC
  11. #55
    Austin175's Avatar
    Austin175 is offline CarAudio.com Elite
    Jan 2010
    Burlington,Ia
    872
    2 Post(s)
    242 Post(s)
    I have never used the AQ before I did have a older dc pai 2k an I clamped it doing 1876 starting at 1ohm rising to 1.9ohm with just a singer 250 amp alt and big three and a kinetic hc1800 under the hood.
    Not sure how good the new dc 2ks are but I loved my pai 2k. But I I'm no gonna recomend which one to get as I haven't used the AQ before.
    2003 Lancer ES
    H/U- Pioneer 80Prs
    Mids/Highs- ????
    Sub Stage- DC Xlm2 12s(soon to be FI BTL Neo's)
    Mids/Highs Amp- Crescendo 1000C4
    Sub Amp- 2 Ampere 3800.1s
    Wiring- Welding 2/0, Welding 4g & Welding 8g
    Alt-Singer 270A
    Batteries- 4 Xs Xp3ks & 1 Lithium
    Enclosure- 3.33Cf tuned to 34hrtz
  12. #56
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,188
    15
    38 Post(s)
    4190 Post(s)
    Quote Originally Posted by cdc351jeferson View Post
    jsut because they are both 2k amps from korea does not make them the same amp even if they are the same board not the same parts on the board. that being said both are great amps. With the dc you will get a warranty that will be backed up no questions asked . I've seen the 2ks run wired down to .34 with ease beating on them . Aq makes great stuff i run it check my sig but with dc your getting better warranty and a little better build amp .
    What precisely is different? Every time this sort of thread comes up some nut-hugger swears there's so much difference between one brand and the next, I have yet to see any real evidence.
    Quote Originally Posted by mylows10 View Post
    this , also the efficiency on the dc amp is better than the aq ,hence a clean signal .dc is greater than 90% rated at 4 ohms and the aq is 86% at 4 ohms
    This is because of some magical DC pixie dust that makes the same circuit perform differently, or possibly just the way each derives their specs? Also if you think you're going to see anything near those published efficiency specs real-world you're out of your mind.
    Quote Originally Posted by cal View Post
    ok im wrong can u plese explain what the differance is ? not being a smart @ss just want to know so i make sure not to confuse the 2 in the future .
    You will never get a legit answer to this question because there will be no statistically significant difference in performance.
    Quote Originally Posted by PapaGeno21 View Post
    You can believe what you like, but just because they "could" be in the same build house does not mean they are the same thing. Not even close.
    Misinformation like you are spreading is why so many untrue rumors get started. Someone hears from someone this and then x leads to y and then everyone is being told the wrong shit.
    That is what the internet is for. You just have to assume that 65% of the shit you read on the interwebz is just not true.
    So what precisely is different besides the heatsink?
    one thing is clear dc makes a great amp as does ab.aq.sundown,crescendo etc....
    Actually none of them make amps whatsoever. Mmats makes amps, Zenon makes amps, Zapco makes amps. The companies you listed buy amps from Korea to slap their brand name on. There's a very few designs and 2 or 3 build houses. IMO the only thing that should sway you from one "brand" to another that would justify price is customer service and how much value you put on that. That's not dowing any of them, and I'd certainly not discourage anyone from running any of those products, but let's call a spade a spade.
    Quote Originally Posted by Austin175 View Post
    I've clamped more than that out of mine when I ran one (that was a fantastic little amp), but that's a whole different animal. PAI series amps were same as Atomic/Sundown amps of that time period.
  13. Thanks cal thanked for this post
    Likes Austin175 liked this post
  14. #57
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,447
    142 Post(s)
    1 Thread(s)
    6019 Post(s)
    Quote Originally Posted by hispls View Post
    i agree with pretty all of what you have said ,but just because they are made at the same place doesnt mean that they are the same 100%.every one has they'er own little tweaks to try to be the best .i do agree with the efficiency statement tho .when you drop the ohm load on any amp you never know how well the efficiency is thats why they are not published .
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  15. #58
    cal's Avatar
    cal
    cal is offline CarAudio.com Elite
    Mar 2011
    43
    1,006
    298 Post(s)
    LOL.
    jim u contridict yourself hispls, pretty much said what ive been saying in this thread and u agree ? i never said they were 100 % percent the same. the case changes then some use tiffany stlye rca the point is u say dc uses " the best of parts " well then so does the rest of the amps in that catergory that come from the build house do too.
  16. #59
    NuckinFutz's Avatar
    Jul 2012
    Shreveport, La
    832
    292 Post(s)
    Well if that's true, then they also cost around the same, so as usual it comes down to who's nuts you wanna swing from
  17. #60
    cal's Avatar
    cal
    Mar 2011
    43
    1,006
    298 Post(s)
    i mean price can vary because some of them are dealer based unlike audioque who is a consumer direct so u will find some what of a price differance . imo if u take dd,dc,sundown etc its all about what amp case u like better,the price and the customer service really . for example i have no problem running an audioque hard core or a sundown . whatever i find the best deal is what i run . and yes i ran aq,dc,dd,rd,ab,sundown and b2 and i never blew any of them or did any of them dissapoint .
  1. dc lvl4 vs aq hdc
    By deLeo in forum Subwoofers
    Last Post: 07-25-2008, 10:15 PM
  2. DC Lvl4 vs AQ HDC3
    Last Post: 07-20-2008, 06:07 PM
  3. AQ 2200 vs. Orion 2500D
    By soloXgt in forum Amplifiers
    Last Post: 07-17-2008, 10:26 PM
  4. AQ 2200 vs mmats dhcx2200
    By tc300 in forum Amplifiers
    Last Post: 06-25-2008, 04:24 PM
  5. AQ 2200.1 vs Orion 2500d price for price
    By mobeious in forum General Discussion
    Last Post: 04-05-2008, 09:13 AM
