Results 1 to 4 of 4
Reload Thread: 4 channel amp
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    4 channel amp
    For price of under $150 priced new what other amp is considerably more powerful than Rockford PBR 300x4, the one i have has a birth sheet of 91watts per channel.
    Thank you for your suggestions
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Re: 4 channel amp
    What are you really looking for from your system? What are you trying to get besides just a bigger watt rating from your amplifier? Maybe I've failed to address these questions with you, because when I talked to you about the P900.4 I didn't really consider that you may already have a good amplifier. 90W per channel is miles better than head unit power, and while more power is good, you eventually run into some major limitations. These limitations include overpowering your speakers, which leads to power compression and overheating, exceeding the mechanical limits of the speakers, and needlessly drawing more current from your charging system.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: 4 channel amp
    I do appreciate your help Trumpet, I have the pbr300x4 powering my doors 125w per speaker, i am in need of another amp to power my tweeters and get rid of the stock tweeters. I am thinking of using the current PBR and use that for the tweeter and get a more powerful amp to match with the 125w per speaker on my doors. I'm thinking of just getting another PBR priced around $140, so i am asking For price of under $150 priced new what other amp is considerably more powerful than Rockford PBR 300x4, the one i have has a birth sheet of 91watts per channel.
    I have looked high and low and could not find any.
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Re: 4 channel amp
    what makes you think you need close to that amount of power for some tweeters? Unless you're running a bunch of supertweeters then "maybe" you might...
  1. 4 channel amp - 2 subs!!!!!!
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-13-2002, 09:57 PM
  2. 4 channel amp bridging help
    By Unregistered in forum Amplifiers
    Last Post: 02-18-2002, 02:18 PM
  3. 1 channel amp and 2 speakers
    By Brandon in forum Amplifiers
    Last Post: 02-03-2002, 12:38 AM
  4. Mono and 2-channel amp for bandpass?
    By adamawayfrommpa in forum Subwoofers
    Last Post: 01-29-2002, 04:04 PM
  5. Infinity Kappa 202 a versus Kenwood 929 2 channel amp ?
    Last Post: 01-29-2002, 11:49 AM
