Heres the gut shots. No burn spots or loose parts......
@pro-rabbit ; @dbeez ; @NASTY08IMPALA ; @Austin175 ; @Wanacustomx ;
YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
That board looks to be in really good shape I think im going to stick with the reason is because it had a short some where along the protect circuit or something that has to do with it.
Ref's- Bass14(smd),the rest on caco.com, ddbump, GearGuy2001,extremechevyman67,pieper88,
southparkgucci,807tubenut,Oldbass38,Mythyone
Zookporter17, White91Formula
Its gonna be a resistor somewhere it will show no signs you will have to have it looked at by someone who can check it all properly
2002 suburban
Security System Code alarm
Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit pioneer 880prs
Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
Wiring lots of 1/0 stinger, tsunami
Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
Subs 4-18" nightshade v2's d2
System DetailsDaily driver.
DBR FTW /thread
headunit : Sony xab-601bt
fronts: infinity kappa 60.9's
subs: 2x dc 12" xls
box : 3cuft net 33hz ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
sub amp: AQ3500.1
others: Mechman 240amp alt, 3 xs3400batts , all 1/0 knukoncepts kollosus flex, stinger deadener
REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
subs: 2x dc 12" xls
sub amp: AQ3500.1
not saying it to damaged just aq and crescendo have been rumored to say "user error" and charge you for repair . Sundown and dc for example cost more but your paying for a warranty and they will cover stuff period just saying heard a lot of stories from reliable sources and people its happened to
subs: 2x dc 12" xls
sub amp: AQ3500.1
Was it used before you got it?
If the amp was mounted to a box it can be damaged. I bought an amp that was mounted to a box and it just went into protect. Vibrations loosened something up.
| Pioneer | DC Audio | Crescendo | XS Power | SHCA & Knu | CDT | DC Power |
Take it out and put it in another car
Western Rep.
99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
-Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
-Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
-Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
-Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
-Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
Western Rep.
Bookmarks
