+ Reply to Thread
Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 46 to 60 of 151
Reload Thread: BC3500 in protect....
  1. #46
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,765
    51 Post(s)
    Re: BC3500 in protect....
    No idea man my buddy had the 3kwp's and one kept doing same **** would work couple days then pop protect and had to be sent in they fixed it like 3 times finally sent him 2 new 3500's which he sold and left audio no.idea why was going on but it did just like yours is now.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
  2. #47
    bgowdy31's Avatar
    bgowdy31 is offline IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    Quote Originally Posted by dbeez View Post
    hmmm.... the first night we got it in which was last sat. we got all my wires in and everything, then went and listened to it. sounded awesome. my guess was ATLEAST a 148 maybe a 149 @ the headrest(thats probly not that great but i would be happy with that lol).... but anyways played flawlessly. went home home and parked it drove it on sunday to the gas station and back probly at 1/4 gain maybe alittle more. then today was going to get the wife something to eat it made it to the end of my street and it protected...... d@mn it pisses me off. i did blow another cheaper planet audio amp similar to this but i had a bad ground then. i dont thinks its the ground this time, i have 2 1/0 grounds from front batt to the back batts as well as a ground in back from the body to the batts.....
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
  3. #48
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
  4. #49
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,765
    51 Post(s)
    Body grounds are no good need to ground to frame then up front ground bat the Alt bolt and Alt bolt to frame as many as you can fit you can never have to little ground wires.
    2002 suburban
  5. #50
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,706
    15
    85 Post(s)
    tl;dr 4 page thread.... the amp is most likely blown.
  6. #51
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,069
    348 Post(s)
    Amps never "just blow" there is always an issue. Many times the issue is from something that happened days..weeks before it finally blew. Could have been a voltage issue from the previous owner that caused minor damage and it finally just gave out on you.
    Far to many things to list...but they never "just blow" though.
  7. #52
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    I mean i have that one done but also my front batt is grounded like 3 times under hood and what not. The 2 runs from that batt ground to the back batt ground. Then theres a ground in the back from body up to those batts as well. Theres probly like 7 or 8 total.
  8. #53
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    I guess thats possible.... He could have had it wired down to .25 also. He had 2 dual 1 subs so yea he could have wired low or low voltage. But it gets me because the amp in no way smells blown and didnt make any noise when it protected
  9. #54
    Austin175's Avatar
    Austin175 is offline Senior VIP Member
    Jan 2010
    Burlington,Ia
    420
    5 Post(s)
    **** bro that *****. I have had my 3kwp for about a month and a half now, got it in a trade an had the power supply repaired well in this 2 mo th time of owning it I have listened to it maybe 8 times. Well last Sunday it was working and I parked my jeep cause I was having surgery on Monday.
    Well I go out yesterday now mind you it was working all this time an I just been listening to deathcore no rap or any heavy bass stuff just metal an I go to start the jeep an low and behold this mug is in protect I checked my grounds an everything just like you did and everything checked good
    Well tonight my cousin was driving me to the guitar store cause I needed strings an this thing was playing just fine. So it's like it decides to work an not work when it wants an it's pissing me off. So I feel you on this man it ***** an I bet mine is heading down just like yours an is gonna need repaired again.
    Ref's- Bass14(smd),the rest on caco.com, ddbump, GearGuy2001,extremechevyman67,pieper88,
    southparkgucci,807tubenut,Oldbass38,Mythyone
    Zookporter17, White91Formula
  10. #55
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    Quote Originally Posted by Austin175 View Post
    ****.... That *****.....
  11. #56
    infamous_e46's Avatar
    infamous_e46 is offline hArRy_DaNgLeRs
    Jul 2008
    HaTeRs On My dlcK LiKe A JeAn ZiPpEr
    25,369
    28 Post(s)
    I know what happened ........you didnt buy my amp
    Quote Originally Posted by RyanM923 View Post
    Damn, look at that midget ***...love me a midget ***. 3 foot 4 standing up, 3 foot 6 sitting down.
    Quote Originally Posted by michaellane View Post
    don dont come in here ruining my thread. i hate you and jose
    www.alphadamp.com
    Got Mad Feedback Son http://www.caraudio.com/forums/buyer-seller-feedback/364675-infamous_e46s-feedback-thread.html#post5697823
  12. #57
    Austin175's Avatar
    Jan 2010
    Burlington,Ia
    420
    5 Post(s)
    Ya I never had a amp act like this before except the last 2 amps I had were a dc 2k and a Skar 1500 an they only were going I to protect cause I had bad ground. This one idk it just works when it wants to an I'm about to throw it lol
  13. #58
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    I dont blame you for wanting to lol.... I took it out opened her up and there are no burn spots what so ever ANYWHERE on the amp nor is there any burn smell on the amp.... So im lost....
  14. #59
    Austin175's Avatar
    Jan 2010
    Burlington,Ia
    420
    5 Post(s)
    I'll pull mine tomorrow an post pics or maybe get a video I I can get it to do it again. I mean like it really ***** cause I needed more power so traded for it an paid $120 to get it repaired an now it's doing this an after seeing and hearing so many ppl have these amps an getting great power then yours acts up mine is messing up.
    I wonder if it just bad luck or something? Especially yours I wonder if something inside yours was on it's way out or had a short in the board an tripping the protect circuit that's the only thing I can think of.
  15. #60
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    it was playing just fine on saturday when we got it in. And yes this amp is a beast. It does good power. A short is the only thing that i can think it would be. Or like pro rabbit said, perhaps the other guy damaged it alittle and it gave out on me
+ Reply to Thread
  1. avalanche amp stuck in protection
    By honda_dean in forum Wiring, Electrical and Installation Help
    Last Post: 10-21-2005, 09:11 PM
  2. Amp in protection
    By LuNaTiC in forum Amplifiers
    Last Post: 03-10-2004, 12:15 PM
  3. Tsunami 1800 in Protect
    By MD_ in forum Amplifiers
    Last Post: 12-18-2003, 12:28 AM
  4. amp in protection mode.
    By jlaudiow6 in forum Amplifiers
    Last Post: 06-28-2003, 02:08 PM
  5. amp in protect mode
    By loserpunk in forum Amplifiers
    Last Post: 05-19-2003, 05:04 PM
