+ Reply to Thread
Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 16 to 30 of 151
Reload Thread: BC3500 in protect....
  1. #16
    bgowdy31's Avatar
    bgowdy31 is online now IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    Re: BC3500 in protect....
    Quote Originally Posted by dbeez View Post
    Unplug rcas and speaker wires turn amp on and see if its still stuck if so unplug the battery power wire to amp leave ground and remote turn deck on let caps discharge then plug power wire back up and nothing else see if its came out of protect if not it needs serviced.
    how do i know i know when the caps are discharged?
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
  2. #17
    dbeez's Avatar
    dbeez is online now CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,768
    51 Post(s)
    A minute or so should do it
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
  3. #18
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    you are refering to the caps inside the amp right right?
  4. #19
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,768
    51 Post(s)
    Yes you should get the common spark pop when reapplying the battery wire to amp that's when they are filling up. If you don't they didn't discharge and it could be cause amp needs fixed just try it and see more than likely my experience with nendo amps when they protect they are done.
    2002 suburban
  5. #20
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    ok will do this when i get a chance. i hope its not just gone.
  6. #21
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,071
    348 Post(s)
    Have you tried to power it on with the speaker wire not connected? I'm not a fan of doing this, but it will let you know if your subs are causing an issue or not. Of course a DMM is very nice to have to check voltage at the power/ground/remote....
  7. #22
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    na not yet. i had to work to so really havnt had a chance to do alot of checking. but will be on this asap. and just thinking, if i read correctly, an RCA can cause a amp to protect?
  8. #23
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    for the cap to discharge does it matter if the trucks on or off or do i just turn off the HU
  9. #24
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    up for input....
  10. #25
    blobb454's Avatar
    blobb454 is offline CarAudio.com Elite
    Nov 2012
    LANSING MI
    983
    6 Post(s)
    Quote Originally Posted by bgowdy31 View Post
    He's saying with all power turned off. Ignition off then disconnect. I'd try what pro rabbit said too. As for what I meant, if you have a dmm just quick test all of your batteries and make sure none of them reverse polarity.. I have seen it a couple times now..
    Man I hope your amp is ok bro..
    Quote Originally Posted by kpetree View Post
    I feel like you're a waste of your mothers stretch marks, better luck finding your gf next season. Fck off, post dump somewhere else.
  11. #26
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    Quote Originally Posted by blobb454 View Post
    if they did this, how would you tell? like what would the dmm show
  12. #27
    blobb454's Avatar
    Nov 2012
    LANSING MI
    983
    6 Post(s)
    Yes it'll show normal read out if its ok or it'll show - and the number. It's rare so it's more than likely not a prob but... There's a few there and it eliminates.
  13. #28
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    oh ok.... yea she's gone. i went out and checked everything while i was on lunch....
    ---------- Post added at 07:57 PM ---------- Previous post was at 07:57 PM ----------
  14. #29
    blobb454's Avatar
    Nov 2012
    LANSING MI
    983
    6 Post(s)
    What? The amp??
  15. #30
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,494
    61
    8 Post(s)
    What? The amp??
    yea unfortunately..... i mean i can still test the battery thing, but as of right now we have declared her dead....
+ Reply to Thread
  1. avalanche amp stuck in protection
    By honda_dean in forum Wiring, Electrical and Installation Help
    Last Post: 10-21-2005, 09:11 PM
  2. Amp in protection
    By LuNaTiC in forum Amplifiers
    Last Post: 03-10-2004, 12:15 PM
  3. Tsunami 1800 in Protect
    By MD_ in forum Amplifiers
    Last Post: 12-18-2003, 12:28 AM
  4. amp in protection mode.
    By jlaudiow6 in forum Amplifiers
    Last Post: 06-28-2003, 02:08 PM
  5. amp in protect mode
    By loserpunk in forum Amplifiers
    Last Post: 05-19-2003, 05:04 PM
