Results 1 to 9 of 9
Reload Thread: Quick question.
    Flatbush Boi's Avatar
    Flatbush Boi is offline Junior Member
    Jan 2013
    Houston, TX
    1 Post(s)
    Quick question.
    would it be ok to splice a speaker with a sub going into an amp? im just wondring because im worried that itll push too much low frequency to the speaker...
    cfox10's Avatar
    cfox10 is offline Rock the house.
    Mar 2011
    Tillamook, Oregon
    1,956
    3 Post(s)
    811 Post(s)
    Re: Quick question.
    No
  3. Dislikes audiobaun disliked this post
  4. #3
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,131
    25 Post(s)
    2108 Post(s)
    Re: Quick question.
    Quote Originally Posted by cfox10 View Post
    No
    Yes you can..Its called Trimode for you folks out there.I did during the late 80s/early 90s with subs and tweets on a 2ch amp
    Tri-Mode Speaker Connection
    Running dual mode would put you at a 2ohm load IN STEREO for a sub, and a set of 4ohm speakers, provided that the sub is 4ohm as well.
  5. #4
    Jan 2013
    Houston, TX
    1 Post(s)
    Re: Quick question.
    Quote Originally Posted by audiobaun View Post
    given the diagram on the link does it have to be wired like that? im asking because i have two subs, two speakers, and a 2 channel amp. i was just hoping to splice one speaker with one sub and the other speaker spliced with the other sub (simplicity).
  6. #5
    audiobaun's Avatar
    Jun 2011
    Tx
    9,131
    25 Post(s)
    2108 Post(s)
    Re: Quick question.
    Quote Originally Posted by Flatbush Boi View Post
    That would work fine,yet, you will be in stereo mode.need to be sure that you wire the configuration properly to ohm load as well.Make sure that the subs are wired properly for 4ohm load, and add the speakers in which should be 4ohms as well, will give you that 2ohm stereo load, in which 95% of all amplifiers are 2ohm stereo stable..you may want to add bass caps on the stereo speakers poss wiring, so you can turn it up a bit more
  7. #6
    audiobaun's Avatar
    Jun 2011
    Tx
    9,131
    25 Post(s)
    2108 Post(s)
    Re: Quick question.
    To run Mixed Mono, yes you will want to wire as shown, but you can run everything in Stereo mode as well as stated just above
  8. #7
    Jan 2013
    Houston, TX
    1 Post(s)
    Re: Quick question.
    perfect man thanks for the help.
  9. Likes audiobaun liked this post
  10. #8
    cfox10's Avatar
    Mar 2011
    Tillamook, Oregon
    1,956
    3 Post(s)
    811 Post(s)
    Re: Quick question.
    Sorry, I was thinking more along the lines of no... without a crossover.
  11. #9
    audiobaun's Avatar
    Jun 2011
    Tx
    9,131
    25 Post(s)
    2108 Post(s)
    Re: Quick question.
    You can run Stereo, or Mixed Mono..Most amps these days have a built in xover
  1. quick question bout wiring
    By MikeofTulsa in forum General Discussion
    Last Post: 04-14-2002, 03:09 PM
  2. Quick Question
    By blaupunkt in forum Amplifiers
    Last Post: 03-30-2002, 06:10 PM
  3. Hey Zane have a quick question
    By mr.cableboi in forum Amplifiers
    Last Post: 02-28-2002, 02:34 PM
  4. quick question
    By tacoma02 in forum General Discussion
    Last Post: 01-26-2002, 08:07 AM
  5. A quick question?
    By Greg GTS in forum General Discussion
    Last Post: 01-11-2002, 10:16 PM
