+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: saz1500v.3
  1. #16
    macsdad's Avatar
    macsdad is offline boom-boom
    Jun 2010
    birmingham, Al
    789
    8 Post(s)
    Re: saz1500v.3
    So i now have the saz on a 1ohm load, but the subs are in a sealed box. Had some rf silver coned t1's sitting around taking up space. Will let y'all know how it works out, i do have a batt i can put in the back if i have to.
  2. #17
    macsdad's Avatar
    Jun 2010
    birmingham, Al
    789
    8 Post(s)
    Re: saz1500v.3
    Quote Originally Posted by macsdad View Post
    Right now, mb quart 354 at 2ohms. I got it for two ma-8's in a 32hrtz ported box. The apsm2000 was great, just not as efficient as the saz. I will be keeping that amp. I will be re-wireing an older set of rf t1-10's later on today to give the saz a 1ohm load. Keep y'all posted on how it works out.
    Quote Originally Posted by SomeguyinPDX View Post
    Where the gains are at on the "clock" mean nothing. You need a DMM to measure your AC voltage on your speaker output from the amp. With stock electrical you will probably have some dimming at high volume but the fact you are dimming at way less than full volume tells me you are probably clipping the shit out of it.
    Check every single ground and make sure its clean and tite. Also have your batt. load tested to make sure you don't have a cell going out. Those things may be causing your dimming also.
    i had all that tested, thanx for you input. I am getting used to the diff between the amps. I will be getting either a fi bl 12 or a dc lvl 4 12 to fully utilize the saz.
  3. #18
    SomeguyinPDX's Avatar
    SomeguyinPDX is offline GunHappy
    Oct 2011
    Portland, Or
    40
    369
    Re: saz1500v.3
    WTB Alpine KTX-100eq Please PM me if you have one to sell. 3/14/13
    2001 Taurus Work In Progress: HU- Alpine 9887, AMPS- RF T1500-1bdcp, a/d/s M860, Front Stage 2- 6.5" Silver Flutes, 2- Seas Prestige tweets, Rear Stage-CDT HD69cfx Sub Stage 2- AB XFL 1544's, Mobile Enclosure designed box Processing 1-AudioControl EQX Series II, Electrical- 220amp HO alt, lots of 0/1 welding cable,2-yellow top Optima's, Security Viper 2way and XD9 subcompact
    SOLD or Purchased from: CD6551, ace_800, underfire , Cyclone9, mclsound, mylows10, BigSix.....
+ Reply to Thread
