Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
Reload Thread: 2ch Amps
  1. #31
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Re: 2ch Amps
    Quote Originally Posted by zako View Post
    Soundstream TN2.600D is the same board inside as PPI P600.2. Onlinecarstereo.com has them. Also Polk Audio Class D amplifiers use the same (Nakamachi) board design, although the individual internal components are different. The Polk amps have pretty much the same watt output as PPI/SS, even though the 2-channel Polk D2000.2 is rated slightly lower. I saw a test of avtozvuk.com showing 2x150watt output at 4ohm with 12.5 voltage, so it should be same as PPI and SS with 14.4V. I don't how how these compare with the more "noble" brands like Boston Acoustics for pure SQ material, but these class D amps have amazing price/performance, size, great for subwoofers or power-hungry speakers.
    Woops, brain fart. I forgot about the shared design.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  2. #32
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Re: 2ch Amps
    FB | Rubyservsales
    IG | Rubyserv
  1. 8 -12inch subs -2 legacy 2ch amps
    By biggtreee in forum Enclosure Design & Construction Help
    Last Post: 06-22-2003, 04:42 PM
  2. Replies: 0
    Last Post: 04-29-2003, 11:53 PM
  3. cheap 2ch amp for comp speakers...
    By d audio 450 in forum Amplifiers
    Last Post: 04-04-2003, 02:25 PM
  4. Replies: 4
    Last Post: 04-30-2002, 10:07 PM
