Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 48
Reload Thread: I want 1500 rms @ 3 ohms.
  1. #31
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Re: I want 1500 rms @ 3 ohms.
    Quote Originally Posted by Mythirdgen View Post
    I see you quoted my original post but you failed to read it.
    Fuck off hombre. I read you cry for help, I gave you a suggestion. You're obviously in the market for an expensive amp, and good amps are able to handle loads down to .5 and below, so wiring to .75 isn't an issue. You're creating road blocks for yourself. The amp will be less expensive and give you the same performance.
    Get taken down to funky town
  2. #32
    TitoThePirate's Avatar
    TitoThePirate is offline Newb Nuthugger
    Feb 2012
    Milwaukee,Wi
    26
    456
    161 Post(s)
    people need to stop worrying about overpowering a sub, if you know how an amp works, you could run a Sundown NS1 to a Kicker Comp and be just fine.
  3. #33
    Mythirdgen's Avatar
    Mythirdgen is offline Junior Member
    Jun 2012
    Laredo
    28
    24 Post(s)
    Quote Originally Posted by Sonic. View Post
    Wire it to 3 ohms and power it with the JL Audio HD1200/1(1200 watts rms @ 11V-14.5v).
    HD is their new line right? I heard people complain about the RIPS tech. I don't even know what that is.
  4. #34
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    24 Post(s)
    Quote Originally Posted by T.I.K. View Post
    Thanks for the suggestion but if I said "I don't want a hifonics amp" and you "suggest" a hifonics amp then I can only draw the conclusion that you can't read. Hombre.
  5. #35
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Do you even have a legitimate reason for not wanting to wire down lower? Plenty of people wire sub 1 ohm for daily, with no issues.
  6. #36
    Sonic.'s Avatar
    Sonic. is offline CarAudio.com Elite
    Jul 2012
    Toronto
    570
    122 Post(s)
    Not new, its been around, the slash v3 is the newer line. The have the 1200 slash v3 which does the same power as the hd, I have not herd about that complain you mentioned.
  7. #37
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    24 Post(s)
    I'm lazy. It came wired in the box and I already had to take it apart once just to fit it in my trunk. I want something that I can just plug and play. I have wires. I have a sub in a box with speaker wire coming out of the box. I just want something to connect the 2 without too much hassle. I don't have meters and all that professional stuff and I don't plan to buy all that since I know there's other options. And to be completely honest (if you couldn't tell already) I don't know that much about electronics in general. I can hook stuff up but don't know anything about resistance, amps, volts and all that stuff. That's why I came to a board with people that know what they are talking about.
  8. #38
    Sonic.'s Avatar
    Jul 2012
    Toronto
    570
    122 Post(s)
    Run the HD 1200 @ 3 ohms and you will be fine !
  9. #39
    GreekBrotha8's Avatar
    GreekBrotha8 is offline Senior VIP Member
    Apr 2012
    Redding, CA
    177
    80 Post(s)
    Bro its super easy to wire in parallel. Just run a positive and a negative from each voice coil into the negative and positive inputs on your amp and you're done! Tons of online diagrams and stuff.
  10. #40
    Apr 2012
    Redding, CA
    177
    80 Post(s)
  11. #41
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    24 Post(s)
    Alright everyone. Lets say I've narrowed it down to the JL HD1200 and the Rockford t1500. Is the jl worth the little bit extra? It's only a couple hundred bucks which I'd be willing to spend just so everything matches but.... Does the t1500 have anything significant over the JL?
  12. #42
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    ... so you're too lazy to get a drill/screwdriver, take your sub out for 5 minutes, follow a wiring diagram (http://www.carstereo.com/help/images...g_parallel.gif) and put it back in? you need exactly one tool.
    you realize that in that 5 minutes, you saved yourself around 200-400 dollars, right?
  13. #43
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
  14. Likes GreekBrotha8 liked this post
  15. #44
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    24 Post(s)
    Quote Originally Posted by GreekBrotha8 View Post
    I know how to do it. I just don't want to. Like I said, I'm lazy.
  16. #45
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    24 Post(s)
    Correct. I'd rather pay someone. If I was that worried about price then I'd have pyramid subs.
  1. wanted, 500 rms @ 2 ohm amp
    By SmokeEater850 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 06-17-2008, 07:52 PM
  2. wtt wtb: 1500 rms @.5 ohm amp
    By KidThump in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-04-2007, 07:16 PM
  3. WTT:My amp and cash for a 1200-1500 rms @ .5 ohm amp..
    Last Post: 08-02-2007, 11:20 PM
  4. 1500 [email protected] ohm
    By 86yota in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 01-03-2007, 08:31 PM
  5. 1100-1500 Rms @ 2 Ohms Amp
    By kumanan in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 05-16-2006, 08:31 PM
