+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 48
Reload Thread: I want 1500 rms @ 3 ohms.
  1. #16
    Mythirdgen's Avatar
    Mythirdgen is offline Junior Member
    Jun 2012
    Laredo
    28
    Re: I want 1500 rms @ 3 ohms.
    What about the Kicker ZX2500.1?
  2. #17
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    Quote Originally Posted by kushy_dreams View Post
    t1500.1bdcp
    That one looks pretty good too.
  3. #18
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    t1500.1bdcp
    ---------- Post added at 01:42 PM ---------- Previous post was at 01:42 PM ----------
    t1500.1bdcp
  4. #19
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    Quote Originally Posted by sacsking916 View Post
    ive SEEN them blow off a jl 1000/1. not heard SEEN. there is a difference sir.
    Not calling you a liar. I'm just asking. Not all amps and subs can handle what they say. I had 2 12 Memphis C3 (600rms) and the 1000/1 blew both of them. Now I have a 100/1v2 powering 2 12Memphis M5 and they are doing just fine.
  5. #20
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,436
    6 Post(s)
    that was what i posted originally is the bdcp amp. constant power from 4ohms to 1ohm. i wouldnt mess with the zx2500 like most other things just not as good as the older KX line of kicker amps.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
  6. #21
    Apr 2009
    6,436
    6 Post(s)
    Quote Originally Posted by Mythirdgen View Post
    i know, and i was just answering you bro. if it came off as sounding harsh or anything else i apologize. also you do know there is a difference of clean vs dirty power correct? that could be the culprit among a lot of things.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
  7. #22
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Charleston, SC
    20
    4,019
    24 Post(s)
    I have a JL 13w7. I have a JL 1000/1 hooked up but the pos and neg terminals melted together. JL wants 180 to fix it or replace it but I figured I'd just upgrade since its the v1. I want to get the full potential out of the sub with its suggested 1500rms. I know that JL says the 1000/1 is optimal but that kinda goes against the 13w7 having a 1500 watt rms doesn't it? I would say that money is no object but then I'll be seeing people post $5000 amps. I sure don't want some Boss or any of that garbage either. 1500w @ 3 ohms. Help? Oh. And no I will not wire it to .75 like I see so many people putting on here. I want nice power but I'm not doing comps.
    You'd be better off wiring it to .75 ohms. You're always going to have box rise, which will almost certainly be over 1 ohm, unless 13W7's defy physics as well as reasonable pricing.
    Get taken down to funky town on MobileAudioForum.com.
  8. #23
    Apr 2009
    6,436
    6 Post(s)
    since you folks keep insisting on wiring lower,
    Car Audio Tip of the Day:
    When deciding how to wire your subs to your amplifier, it's important to know that impedence DOES NOT JUST RISE. The reason it is called "nominal" impedence is because the coil will almost never be that impedence during play. On music your impedence WILL DROP sometimes to as much as 1/4 of nominal.
    For burps you can count on rise because you will have the most rise at your peak frequency and that's what you're burping at. For music you cannot count on it because it goes through lots of different frequencies and WILL drop on some of them. Wiring low for daily is NOT smart. We hear that lie all the time on forums about how the nominal impedence is simply the lowest impedence the coil will be and it only rises from there. That is NOT true. Don't fall for it. It's an expensive lie to believe.
    thanks to @cthedinger
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
  9. Thanks GreekBrotha8 thanked for this post
  10. #24
    T.I.K.'s Avatar
    Oct 2010
    Charleston, SC
    20
    4,019
    24 Post(s)
    i guess i believe dingleberry, but I still don't understand how the impedance would drop... I work with electrical coils similar to VCs, and the only thing they do when power is applied to them heat up and thus increase their impedance. Physics, brah.
  11. #25
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    Yeah. That's why I tried to match it with its "ideal" 1000/1 but just couldn't believe what happened to the amp with the melting. I've always had really good luck with JL but it may be time for a change.
  12. #26
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    I like the looks of that the best so far. I've heard that PG amps have gone downhill in the last 10 years. Ever heard anything like that? I used to have 4 of the M series in my camaro.
    No
  13. #27
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
    Quote Originally Posted by T.I.K. View Post
    I see you quoted my original post but you failed to read it.
  14. #28
    Imtjnotu's Avatar
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    No
  15. #29
    Mythirdgen's Avatar
    Jun 2012
    Laredo
    28
  16. #30
    Sonic.'s Avatar
    Sonic. is offline Senior VIP Member
    Jul 2012
    Toronto
    455
    Wire it to 3 ohms and power it with the JL Audio HD1200/1(1200 watts rms @ 11V-14.5v).
+ Reply to Thread
  1. wanted, 500 rms @ 2 ohm amp
    By SmokeEater850 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 06-17-2008, 07:52 PM
  2. wtt wtb: 1500 rms @.5 ohm amp
    By KidThump in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-04-2007, 07:16 PM
  3. WTT:My amp and cash for a 1200-1500 rms @ .5 ohm amp..
    Last Post: 08-02-2007, 11:20 PM
  4. 1500 RMS@1 ohm
    By 86yota in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 01-03-2007, 08:31 PM
  5. 1100-1500 Rms @ 2 Ohms Amp
    By kumanan in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 05-16-2006, 08:31 PM
