Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
Reload Thread: Memphis 4k fuse
  1. #31
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Re: Memphis 4k fuse
    Quote Originally Posted by dumpbeast86 View Post
    i have argued with you about electrical before. i'm not gonna argue with you guys though, as i am viewed a "noob" to you and it's a losing battle
    It's not a losing battle because you're a newb. If you have some evidence, please enlighten us. I have no problem admitting when I'm worng. You just have to prove me wrong first. And a tip of the cap to you if you can.
    For the current/amperage to increase as voltage drops, the resistance would have to change. It's not my law. But it's Ohm's. Have you measured a resistance change in low voltage situations?
    Since current is voltage divided by resistance... resistance would have to go down to increase the current. And under low voltage and/or high current apps, the resistance is likely to be higher as things heat up. No?
    Unless you mean the internal resistance of the battery? Which I'm not sure is likely to drop as voltage gets lower either.
    It just occurred to me that you might be thinking that becuase your electrical's voltage drops as the amperage supplied increases that you think the current increase is a function of the voltage drop. When, in fact, it's just consequential.
    I'm working all of this out in my head while typing this, man. If you have something I'm missing, I'm all ears.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  2. #32
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: Memphis 4k fuse
    Quote Originally Posted by TaylorFade View Post
    THANK YOU. I couldn't figure out how to type that out without it sounding complicated.
    Low voltage occurs DURING increased current draw, not BECAUSE.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
  1. memphis 4k impeadence
    By matrxx dude in forum Amplifiers
    Last Post: 01-20-2008, 01:20 AM
  2. memphis 4k
    By phillipcyoung in forum Amplifiers
    Last Post: 06-23-2007, 04:48 AM
