Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 120
Reload Thread: VVME audiopipe clones cheap!
  1. #91
    babsuhl81's Avatar
    babsuhl81 is offline CarAudio.com Elite
    Nov 2012
    decatur, il
    579
    150 Post(s)
    Re: VVME audiopipe clones cheap!
    [QUOTE=av83;8347358]Please stop typing.
    And for fux sake, clean your house. That's nasty.[/QUOTE
    The orion is only good amp in that pic. And the sony!
  2. #92
    2010hhrumad's Avatar
    2010hhrumad is offline Junior Member
    Aug 2012
    Easy Bay, CA
    7 Post(s)
    [QUOTE=babsuhl81;8347384]
    Quote Originally Posted by av83 View Post
    Are you referring to that POS xplod?
    dnx 6160 - saz1500d v1 - sony xm 4045 - stock tweets - no decent sub for now
  3. #93
    babsuhl81's Avatar
    Nov 2012
    decatur, il
    579
    150 Post(s)
    I was joking
  4. #94
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,654
    96 Post(s)
    DrewImpala's
    Default
    Quick testing specs.
    Only tested at 4 ohm and 1 ohm. Didn't do box rise.
    Electrical: Stock battery, 4 gauge OFC wire(15feet) 200 amp fuse.
    Subs: 2 DB Drive Platinum PT12D4
    4 ohm with voltage drop to 13.6
    920 watts rms
    1 ohm with voltage drop to 13.3
    1290 watts rms
    Nearly identical numbers to the AP1500, but seeing how they are the same board from the same build house I wasn't surprised at all.
    I was planning on doing more testing but after seeing my first sets of results I decided to stop as this amp is indeed a relabeled AP1500. Sorry Audiopipe, but someone stole your amp and is selling it for way less.
    not bad numbers considering how cheap the amps are
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
  5. #95
    babsuhl81's Avatar
    Nov 2012
    decatur, il
    579
    150 Post(s)
    The $100 model I bought just went up to 130. I Shoulda ordered a 2nd before it went up
  6. #96
    ciaonzo's Avatar
    ciaonzo is online now TheContinental
    Feb 2009
    WI
    43
    11,042
    20 Post(s)
    1187 Post(s)
    [QUOTE=2010hhrumad;8347921]
    Quote Originally Posted by babsuhl81 View Post
    The monoblock in that series is actually a sleeper of a good amp, carries three 25a fuses and makes the power. Most will let their brand prejudice stand in the way of a good deal, though.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  7. Thanks Spooney thanked for this post
  8. #97
    Spooney's Avatar
    Spooney is offline CarAudio.com Veteran
    Dec 2007
    Charlotte,MI,USA
    37
    4,416
    3 Post(s)
    793 Post(s)
    [QUOTE=ciaonzo;8348069]
    Quote Originally Posted by 2010hhrumad View Post
    That one I believe is actually based on an mtx design. Sleeper for sure.
  9. #98
    babsuhl81's Avatar
    Nov 2012
    decatur, il
    579
    150 Post(s)
    That sony looks the there main 2 channel model
  10. #99
    zinda's Avatar
    zinda is offline Member
    May 2011
    Phoenix, AZ
    57
    6 Post(s)
    One thing you missed from that picture was as bad as all those amps were, they all sound better than the amp I was sent. Now it may be a defective piece, I'm waiting on a reply from the seller to see what they want to do as far as sending a replacement.
    I asked them to test it when they get it and if it is in fact not defective then I am not interested in a replacement, if they conclude it is defective then I feel I should not have to pay for the return shipping.
    One last thing all those amps in that pic besides the Orion which I bought new in '93 and the Bazooka (replaced a Rockford amp that was powering tweeters when it died the second time) cost me less than $20 each. The VR amps were $15 new and all they needed was a new shroud and fan upgrade to stay working in AZ heat. I had them sitting on a shelf for years without ever installing them. Bought them just because of the price. Used them in a pinch to power 2 12's when my HCCA250 died after 20 years, I was shocked when I heard them. If you haven't tried them then you can't knock'em.
    that Sony amp is the 760watt model paid $28 after shipping, needed a mosfet, will not stay on for very long at 2 Ohms Bridged. But that silver 4 channel American Pro VS-1406 ($8) puts out some sound [email protected] if you have an active x-over to control it - like all 4 channel amps.
    This is the amp I got and the Modified VR3 amp that blows it away!
    Attached Thumbnails Attached Thumbnails VVME audiopipe clones cheap!-image1.jpg   VVME audiopipe clones cheap!-p3140003.jpg
  11. #100
    zinda's Avatar
    May 2011
    Phoenix, AZ
    57
    6 Post(s)
    That's my spare bedroom, now it's my electronics storage room, my Mom isn't here to pick up after me anymore! If I showed you the rest of that room you wouldn't believe your eyes, stacks of bins full of electronics and an entire wall 3 rows deep of home speakers + a closet full and a few stragglers about the place and in the garage. These aren't all of the amps on hand these are the few that I've tested out in the last month, minus the Orion, missing from that pic of recent tested:A Kicker that I'm waiting for parts, Realistic that was on the bench but now working and an Alpine that's currently in the car, all but the Kicker produced more usable bass than the eBay amp.
  12. #101
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    381
    123 Post(s)
    by the looks of their ratings they only screwed about 70 people in 7 months and 90 people in the last 12 months. good luck
    '05 F250 King Ranch Crew Cab 4X4 Off Road Modded Powerstroke
    Rebuild in process
    Pioneer DEH 80PRS
    Modded Linear Power LP4753IQ
    Front Woofer: Infinity Kappa Perfect 6.5"
    Front Tweeter: SEAS Neos in pods
    Back: Pioneer TS-D6802R
    Knukonceptz Karma 12ga
    Stinger HPM3 RCA's
    Big 8: PhoenixGold Oga
  13. #102
    babsuhl81's Avatar
    Nov 2012
    decatur, il
    579
    150 Post(s)
    I'm sure the bad feedback is not just these amps. They sell way more stuff
  14. #103
    Oct 2012
    Guthrie, OK
    381
    123 Post(s)
    True. Not only cheap Chinese junk but bad customer service. Let the buyer beware.
    Rebuild in process
    Pioneer DEH 80PRS
    Stinger HPM3 RCA's
  15. #104
    Sleeklsc's Avatar
    Sleeklsc is online now CarAudio.com Veteran
    Jan 2004
    Topeka, KS
    6,950
    863 Post(s)
    Is that the "1200w" one? (2 40a fuses) I never thought an old Xplod amp would look that good inside.
    Edit: After further research it's the "1000 watt" xm-6001gxd.
    Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
  16. #105
    Spooney's Avatar
    Dec 2007
    Charlotte,MI,USA
    37
    4,416
    3 Post(s)
    793 Post(s)
    Quote Originally Posted by zinda View Post
    Good luck with their customer service bro. I highly doubt they have any means of testing anything in house. I bought a sub from them that died within 5 minutes. They asked me to send them a video of the sub not working LOL. I refused. After about two weeks of emails back and forth with replies from them written in terrible english(engrish maybe) they finally replaced the sub. The second sub performed quite well but their quality is so hit and miss its probably not worth the hassle to deal with them . I imagine their operation consist of a warehouse where they store the cheap china made products until they are sold.
  1. **New OBX Muffler (Apexi WS Clone) CHEAP!!**
    By Slammed in forum Miscellaneous Classifieds
    Last Post: 07-09-2006, 06:49 PM
