Going to order the 1000 watt. For 75 bucks you can't go too far wrong... And if it's a total POS you're out 75. Big fucking deal...![]()
how much cheaper can watts get?
Lol same as audiopipe but cheaper components? You mean there are actually cheaper components out there?![]()
Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
VWBobby liked this post
i can test one. not bench it, but i can try to make it mad with low voltage and weird ohm loads. i have 2 single 8 ohm woofers, 1 4 ohm woofer, and i will have 4 D4 woofers here shortly. im sure i can come up with some odd *** loads and run it at 12V just to **** it off. i can probobly even throw it in my dads work truck. it runs at a steady 16V or more(he also has an external regulator, should be able to keep a solid 14.4V too.)
wait, benching all you need is load and voltage right?
Matt
these are a prime example of just because you can doesnt mean you should
13 Dodge Dart Rallye 1.4T
DD 2515 Supercharged
RF T1500bdcp
Audiotechnix wire and deadening
http://mobileaudioforum.com/forum/forum.php
BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
i would lay odds they do almost the same as the ap. it would be fun to run 8 of them in something.
R.I.P. 2008 Hyundai Tiburon GS
2005 Subaru Baja turbo, build in planing stages.
It would be like switching from Sundown to any other cookie cutter amp... Doubt there will be a diffrence
the race to zero
Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
macsdad liked this post
I installed the qa-1500d today. I have it wired at 1 ohm running a pair of s12l7's and it pushes them great. The amp is relatively small but very heavy. It DOES NOT have any external fuses so I can't verify the amp rating but I really like the simple clean cosmetics of it.
I will play with it more tomorrow but SO FAR I'm happy.
ThatChevyGuy thanked for this post
Would rather run BOSS.
97 4runner, 3RZ, 5 Speed
Headunit: Pioneer DEH-P9800BT
Mids: Lanzar 6m
Tweets: Crescendo CCX
Fronts Amp: Alpine PDX4.100
Sub Amp:Hifonics BRZ1.1700D
Substage: 18" SSA ZCON
Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
Sleeklsc liked this post
Bookmarks
