+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 57
Reload Thread: SQ 6ch. amp?
  1. #31
    ge_off_me's Avatar
    ge_off_me is offline I sound better than you ge_off_me is a Supporting Member of the forum!
    ge_off_me is a Supporting Vendor of the forum!
    Apr 2010
    Ohio
    22
    6,330
    75 Post(s)
    Re: SQ 6ch. amp?
    Zuki
    PHD Audiophile Systems Dealer
  2. #32
    dragnix's Avatar
    dragnix is offline LXIX
    Dec 2006
    Socal cuz i'm So cool
    19,321
    21 Post(s)
    Re: SQ 6ch. amp?
    Quote Originally Posted by ge_off_me View Post
    Zuki
    Their amps are expensive last I checked
    Got a pm regarding my sig
    Quote Originally Posted by audioholic
    please change it to something non-******. thankyou.
  3. #33
    ge_off_me's Avatar
    Apr 2010
    Ohio
    22
    6,330
    75 Post(s)
    Re: SQ 6ch. amp?
    Diyma sometimes has used ones for cheap. Great amps and worth the money.
  4. #34
    dragnix's Avatar
    Dec 2006
    19,321
    21 Post(s)
    Re: SQ 6ch. amp?
    Guess i'll have to do some hunting, don't see them having a 6 channel anymore though
  5. #35
    ge_off_me's Avatar
    Apr 2010
    Ohio
    22
    6,330
    75 Post(s)
    Re: SQ 6ch. amp?
    Quote Originally Posted by dragnix View Post
    You never know, they pop up from time to time lol
  6. #36
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,260
    6 Post(s)
    Re: SQ 6ch. amp?
    Personally, I'd look into a solution with more amplifiers. It seems a bit of a waste to spend money on "high power" 6-channel amplifier, then use two channels to power your tweeters. I'd look into using a cheaper relatively low power 4-channel amplifier to power mid-range and tweeters, and use something bigger to power the mid-bass, or a relatively high wattage 4-channel amp could power the midbass and also subwoofer with the other two channels. Alternatively, you can go with a 4-channel amp to power mids and mid-bass, and throw in a cheap 2-channel amplifier to power tweeters (e.g. Boston Acoustics GT-275, if they're still sold). Wiring and fusing the wires can get a bit messy. However, if the complete system could be built with just three devices (2 amps + DSP, or just three amps), I'd take this route. Wiring and fusing for three devices should not be too bad. Take a look at the fused 3-way power distribution blocks from knu.
    PS: Also take a look at SoundStream STL6.620. Two channels are rated 2x100watts RMS, and the other four are 4x60watt RMS. I have seen a test that showed that the test amp provided more like 4x70watts + 2x 130watts (all at 4ohm).
  7. #37
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    24
    565
    Re: SQ 6ch. amp?
    If you can stretch your budget a bit Zed Audio Leviathan III - SSA Car Audio Forum
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  8. #38
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: SQ 6ch. amp?
    Yea, that's why I want it badly
    the sherwood is not really what I want since it's 35x5 and 100x1 I believe
    Specs on those? I checked ebay recently, no US Amps six, and I doubt I can afford one lol
    ZED FTW and the head room yo.
    I'll chip in $5 to help you lol send me your paypal addy.
    The power consumption is crazy low, and low noise, very low noise if you have good rca's and a good deck/processor.
  9. #39
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,503
    24 Post(s)
    Re: SQ 6ch. amp?
    Quote Originally Posted by zako View Post
    This. If you have that much of a budget why are you trying to get by with the lowest cost 6 channel you can? Get decent 4 channel and 2 channel amps.
    But also, Zed FTW.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  10. #40
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: SQ 6ch. amp?
    Love the way it looks too...
  11. #41
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Re: SQ 6ch. amp?
    Quote Originally Posted by West View Post
    Yup. That is not an amp you hide behind anything.
  12. #42
    gckless's Avatar
    Aug 2011
    San Antonio
    3,503
    24 Post(s)
    Re: SQ 6ch. amp?
    Quick question: how the hell do you mount a leviathan? Doesn't seem to have any mounting feet?
  13. #43
    gckless's Avatar
    Aug 2011
    San Antonio
    3,503
    24 Post(s)
    Re: SQ 6ch. amp?
    Damn, this thread sure has piqued my interest. Just emailed Vertex about trading my DC 175.4 towards a Leviathan
  14. #44
    RicksI30's Avatar
    May 2011
    Tucson, Az
    24
    565
    Re: SQ 6ch. amp?
    Quote Originally Posted by gckless View Post
    It comes with mounting feet that you screw into the amp.
    Team SSA
  15. #45
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,823
    72 Post(s)
    Re: SQ 6ch. amp?
    I just got a new MMATs but they retail at 1200...
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
+ Reply to Thread
  1. WTB: Alpine tripath 6ch amp or 5-ch V12
    By elduderino in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 02-24-2005, 06:25 PM
  2. 6ch amp?
    By luczjasp in forum Amplifiers
    Last Post: 08-19-2004, 08:13 AM
  3. 3 ways and a 6ch amp
    By d audio 450 in forum Speakers
    Last Post: 09-26-2003, 11:24 PM
  4. How much better sq with amp?
    By swtguy in forum Amplifiers
    Last Post: 04-07-2003, 11:25 AM
