+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: Bass knob. ???
  1. #16
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,393
    23 Post(s)
    Re: Bass knob. ???
    Quote Originally Posted by TaylorFade View Post
    It's true.
    All of mine go right in the junk drawer of my toolbox. I either forego them altogether or use an inline RCA knob.
    Could you explain why?
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  2. #17
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    2,627
    131 Post(s)
    Re: Bass knob. ???
    Quote Originally Posted by gckless View Post
    Very simply put... a bass knob/remote is a gain control. But it's just an attentuator. Meaning that it can't go past where the gain is set at the amp. This is a good thing, but playing with the gain constantly isn't. It can introduce distortion/clipping.
    And inline RCA is basically a volume knob. It attentuates the input signal/voltage exactly how your HU would do it. It has nothing to do with your gain.
    The other reason is that when bass knobs go bad, it can jack shit up. When an RCA knob goes bad, it's likely to just quit sending signal. And the failure rate on bass knobs and their cords are FAR higher than a PAC.
    Bottom line is that you can abuse either, but like I always say... gains are a sensitivity setting, not a volume knob. So I don't want to use mine as one.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  3. #18
    bgowdy31's Avatar
    bgowdy31 is online now IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,499
    61
    8 Post(s)
    Re: Bass knob. ???
    [QUOTE=TaylorFade;8267040]
    Quote Originally Posted by bgowdy31 View Post
    Yeah. You know... like preout voltage? It was like .3v or some shit. It wasn't much, but it was enough to notice. And not really anyting to be concerned about since you can just adjust the amp gain.
    ok i see
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
  4. #19
    gckless's Avatar
    Aug 2011
    San Antonio
    3,393
    23 Post(s)
    Re: Bass knob. ???
    I do agree with you, you are correct on most things, except for that. Do you mean when you are actually turning the pot? And while bass knobs may fail, their cords? I tend to think twisted pair wire is pretty durable.
    Also, while these are very good points, the original question was about Bgowdy saying it hurt during comps. Why does it hurt during comps?
  5. #20
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    2,627
    131 Post(s)
    Re: Bass knob. ???
    In essence... yes. It's the same thing as turning the pot. You might as well have your amp mounted on the dash and use a little screwdriver. But like I said, it's only an attentuator. 100% on the bass knob is just getting to where the gain is set at the amp. So... if your gain pot is set for 2v at the amp, 100% knob will be 2v. Conversely, 0% on the knob may be 4v or whatever the most sensitive setting is on your amp because the less gain you have, the more input voltage your amp is going to be huntin' for.
    So, why? Why do you want to attentuate the gains when you went through so much trouble to set them clean in the first place? You should run 100% knob 24/7.
    The cords themselves perhaps. The jack, meh. Not so much. And gain knobs are usually proprietary which is ghey. Since I told you i don't use them, I can only go by the large number of fucked up knobs I've seen and all the jacked up noises I've heard coming from subs because of them.
    How does it hurt in comps? All I can tell you is I'm louder with a PAC vs. a bass knob. I get more clean voltage with a PAC and higher scores. And that's all the explanation I need. If you like your knob, awesome. Rock it out. But I won't.
    Or maybe I have no idea how a bass knob works and I just think PAC knobs are cute.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  6. #21
    armykyle1's Avatar
    armykyle1 is offline armykyle1
    Feb 2009
    Gulfcoast MS
    245
    2 Post(s)
    Re: Bass knob. ???
    LC-1 still FTW
    Tfade explained it lol
    Build
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/550173-amykyle1s-ever-changing-build.html
    Youtube
    http://www.youtube.com/user/armykyle1
  7. #22
    David62's Avatar
    David62 is offline Junior Member
    Jan 2013
    USA, Chicago, Illinois
    Re: Bass knob. ???
    I used it. It's set at max when the obtain is set. That way it can only go down . . . . .. . . . .
    surfers paradise car hire
  8. #23
    pickup1's Avatar
    pickup1 is online now Audiosystem. .
    Aug 2005
    Roanoke,TX
    48
    6,658
    17
    28 Post(s)
    Re: Bass knob. ???
    I use the ones that come with the amp...some have clipping lights on them that might be helpful.
    Otherwise the Pac solution works great.
  9. #24
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,747
    90 Post(s)
    Re: Bass knob. ???
    Quote Originally Posted by DCtC View Post
    I use it. It's set at max when the gain is set. That way it can only go down
    This
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC XL D4 12s
    Sub amp - DC 5.0K
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 1 C&D 400mr
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
+ Reply to Thread
  1. remote bass knob
    By x5-452 in forum General Discussion
    Last Post: 09-16-2004, 02:00 PM
  2. bass knob
    By sk24iam in forum Subwoofers
    Last Post: 01-15-2003, 07:01 PM
  3. How effective are "bass knobs"?
    By maylar in forum General Discussion
    Last Post: 10-24-2002, 08:20 AM
  4. fosgate 800.2 bass knob
    By SuckMikeHawk23 in forum General Discussion
    Last Post: 01-26-2002, 06:23 PM
