+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: should i get a bigger amp?
  1. #16
    babsuhl81's Avatar
    babsuhl81 is offline Senior VIP Member
    Nov 2012
    decatur, il
    324
    Re: should i get a bigger amp?
    My alt is weak already tho
  2. #17
    Sonic.'s Avatar
    Sonic. is offline Senior VIP Member
    Jul 2012
    Toronto
    455
    If you are going to put in a system approx 1100 watts rms then you can replace your alt with the highest amprage stock alt that would work on your vehicle.
    IF you are going to go well above the 1100 range, then to get a proper system with decent equipment, you will have to save up and raise your budget wich will include a ho alt.
    Do it right, do it once ! The choice is yours.
  3. #18
    babsuhl81's Avatar
    Nov 2012
    decatur, il
    324
    That's y I want the ho alt. I wanna run about 2.5k in the future. The bc is right in the range I want. If I have to sacrifice on the sub side for now I will. I have a few ideas on subs and might try a couple different setups. I mainly wanna buy the right amp the 1st time
  4. #19
    Sonic.'s Avatar
    Jul 2012
    Toronto
    455
    Quote Originally Posted by babsuhl81 View Post
    Cool, sounds like a plan.
+ Reply to Thread
  1. Should I get a bigger amp for my BTL?
    By THXdts in forum Amplifiers
    Last Post: 10-01-2007, 04:08 PM
  2. Should I get a bigger amp for my Type-R?
    By 93 saturn sl2 in forum Subwoofers
    Last Post: 08-12-2006, 04:59 PM
  3. should i get a new amp?
    By destruction in forum Amplifiers
    Last Post: 06-04-2005, 09:08 PM
  4. what should i get for an amp
    By JMOCK in forum General Discussion
    Last Post: 01-23-2004, 06:40 AM
  5. What 12's should I get For My amp?
    By adammk5 in forum Subwoofers
    Last Post: 06-01-2003, 04:02 PM
