Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: AQ3500 or Crescendo 3500?
Originally Posted by
04murdalanche
I've got someone lined up for 350 already. So unless you wanna pay more for it, it's his lol
Well let me know if that doesn't work!
CaptM
If he doesn't buy it, it will be posted for sale on here!
New Car, New Build coming
soon... will consist of:
RF 360.3&Apple iPad Mini
Tantric comps
Sundown subs and amps
Mechman HO alt
Deka batts
Knu Conceptz&Shok wire
Audio Technix deadening
Aq3500 Vs. Bc3500 - The Amplifier Area - Car Audio Forum - Car Audio's Forum!
Same discussion on another forum complete with board pics.
You should not have an audible difference in output assuming the two are within 500W of eachother.
hispls
Thanks for your input! I think I am going to stick with the AQ. One question I do have though, on the dual inputs, from my batt to the aq, do I fuse 300 at each wire? Or 150 at each wire?
Tantric comps
Mechman HO alt
Deka batts
AQ is rated at 4300watts, so it does not do over rated.
Why fuse from batts to amp, assuming your runs are short and not in danger or shorting on anything.
For a 3500.1 with an HO alt I'd do 2 G31 batts in the rear, more if you play long periods at full tilt...
mlstrass
I meant that one the basis that its called a 3500 but does more, lol
That's exactly why I run them, safety precautions, would much rather replace a $1 fuse then spend $200 to get all the fets and **** replaced
And okay sounds good, I just need to pick up another Deka and ill be good then
Tantric comps
Mechman HO alt
Deka batts
just bought a 2nd 2200!!!!!
Tantric comps
Mechman HO alt
Deka batts
By luis e in forum Wanting to Buy (WTB) - Car Audio
Last Post: 09-25-2012, 02:39 PM
By travicles in forum Amplifiers
Last Post: 01-02-2012, 05:24 PM
By Bassin Brandon in forum Amplifiers
Last Post: 06-26-2011, 07:02 PM
By pimpnyou204 in forum Amplifiers
Last Post: 06-02-2011, 01:03 AM
By SWFL in forum Wanting to Buy (WTB) - Car Audio
Last Post: 07-10-2009, 10:18 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
