Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Obsidian amps?
  1. #16
    xShoWTeKx's Avatar
    xShoWTeKx is offline Drop Bass Not Bombs
    Jan 2011
    Greer S.C.
    28
    1,198
    406 Post(s)
    Re: Obsidian amps?
    Initially I plan to launch some Class-D amps :
    OA-1 : 1200 RMS @ 1 ohm
    OA-2 : 1800 RMS @ 1 ohm
    OA-3 : 2400 RMS @ 1 ohm
    They are all under-rated amplifiers by a good margin. The ratings are to be used to mate with the appropriate Obsidian woofers for daily applications.
    What I have decided to do after much debate is to stick to extremely proven board designs for these three models; initially I was planning otherwise but decided this route would be best -- of course with some modifications and tweaks. All three models feature more robust than normal power supply MOSFETs.
    All of these amps will cut off around 16.0 volts -- they are not made for a 16v electrical system at all. For this you will need to look to Sundown or other brands that support this operation. They are in turn optimized for more power on a 12v system.
    Once samples arrive testing and board photographs will follow along with predicted pricing.
    They will not be the cheapest amps on the market but they will be a good value, IMO, and they will be backed by known excellent customer service and warranty practices.
    I am considering offering extended warranty plans as well for those that value a warranty -- those that do not would not have to pay extra for it. Base warranty will be 1 year and can be extended from there.
    8/31/2011 UPDATE:
    Various testing collected together :
    OA-1 : Rated 1200 @ 1 ohm / 600 @ 2 ohms / 300 @ 4 ohms @ 11v
    1 ohm --> 1440 watts @ 13.3v @ 1.91 ohms actual
    0.5 ohm --> 1960 watts @ 12.65v @ 1.38 ohms actual
    0.5 ohm --> 2130 watts @ 12.2v @ 1.17 ohms actual
    0.33 ohm --> 2230 watts @ 14.2v @ 1.11 ohms actual
    OA-2: Rated 1800 @ 1 ohm / 900 @ 2 ohms / 450 @ 4 ohms @ 11v
    1 ohm --> 2340 watts @ 12.8v @ 1.98 ohms actual
    0.5 ohm --> 2640 watts @ 11.7v @ 1.16 ohms actual
    0.5 ohm --> 2820 watts @ 12.8v @ 0.9 ohms actual
    0.5 ohm --> 2892 watts @ 14.4v @ 1.53 ohms actual
    OA-3 : Rated 2400 @ 1 ohm / 1200 @ 2 ohms / 600 @ 4 ohms @ 11v
    1 ohm --> 2860 watts @ 12.35v @ 2.01 ohms actual
    0.5 ohm --> 3250 watts @ 11.5v @ 1.28 ohms actual
    0.5 ohms --> 3460 watts @ 11.6v @ 0.86 ohms actual
    0.33 ohm --> 3810 watts @ 13.6v @ 0.85 ohms actual
    All amps will be upgraded from IRFP064N power supply FETs to IRF1405 power supply FETs for production... the OA-1 and OA-2 will receive a few % tolerance tweaking in the protect circuit for a tad more power output at lower loads and the OA-1 will lose the internal fusing so there won't be concern for blowing the fuses on burps.
    All pricing will include a 1-year warranty on the amps for 1 ohm operation on the Class-D models and rated 2 ohm stereo / 4 ohm mono on the multi-channels. We will offer discounted replacements for out-of-warranty operation parameters such as 0.5 ohm and so forth; so you simply are not up the creek in these situation.
    OA-1 : $350 + SH
    OA-2 : $425 + SH
    OA-3 : $675 + SH
    This is USA pricing and also for countries without a distributor. We expect to have them distributed in a few other countries upon launch and pricing will be set in those countries by the distributor based on their costs to import, etc.
    I will be working on pricing for extended warranty options as well for those that desire longer coverage.
    Pre-order pricing will be introduced when pre-ordering is ready to open; it will of course be less than the regular price listed above. 2-channel and 4-channel pricing will be announced later on as well. At this time the ETA is not set in stone on the amps -- we WILL announce it when there is information on that.
    only vid
    http://youtu.be/8NRfhnWAo8o
    mobileaudioforum.com is better than CA.com in every way :o
  2. #17
    Dtrom's Avatar
    Dtrom is offline MAF
    Jul 2012
    3,996
    1190 Post(s)
    Re: Obsidian amps?
    Quote Originally Posted by xShoWTeKx View Post
    i saw pricing somewhere a long long time ago they seem to be half way decent, i'll see if i can find it again.
    Awesome. They look promising. Exceed rated pretty well on low voltage.
    REFS alot
  3. #18
    xShoWTeKx's Avatar
    Jan 2011
    Greer S.C.
    28
    1,198
    406 Post(s)
    Re: Obsidian amps?
    super old but......
    only vid
  1. WTT: Big two channel Eclipse amp for SA-12,VVX 12, Obsidian Audio 12, or similar
    By Spooney in forum Wanting to Trade (WTT) - Car Audio
    Last Post: 05-07-2012, 06:39 PM
  2. suggestions for high efficient amp for obsidian 15 D2.
    By Mr.meyhem in forum General Discussion
    Last Post: 01-17-2012, 02:00 PM
  3. 1200W AMP
    By UNTOUCHABLEM3 in forum General Discussion
    Last Post: 07-19-2008, 12:39 PM
  4. Which amp?
    By <andy240sx> in forum General Discussion
    Last Post: 02-11-2004, 07:17 PM
  5. Which Amp is good for VEGA 10''?
    By <IowaBoomer> in forum General Discussion
    Last Post: 12-16-2001, 07:16 PM
