Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: Need amp advice
  1. #16
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: Need amp advice
    Btw, are you going to be installing this yourself or taking it to a shop? If you're going to a shop, you might get charged more for installing equipment not bought directly from them and also might not warranty the install so if anything goes wrong, you're SOL.
  2. #17
    Sep 2012
    Sevierville, TN
    1,113
    890 Post(s)
    Re: Need amp advice
    Quote Originally Posted by Dynaxx View Post
    Figured id look at kits on sonic for the simplicity of all one bulk order coming at once.
    Simplicity of ordering is more important to you than the quality of the stuff you're putting in your vehicle?
  3. #18
    Dynaxx's Avatar
    Dynaxx is offline Junior Member
    Oct 2012
    Minneapolis, MN
    2 Post(s)
    Re: Need amp advice
    If you can post some links on good wire kits id appreciate it I don't have a battery terminal either.
    I'm off to work but if you find any in the 70$ range with terminal pp pm me or post it
    and ill check it out over lunch. Ty
  4. #19
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: Need amp advice
    Btw, I work right in Sonic's backyard and can vouch for the staff there. They do know a good amount and if you're local even have an install shop. Hopefully you don't get burned with RMAs (I've only seen two stories about this so chalk it up to isolated incidents).
    Don't worry about having one bulk order. It does help with simplicity but you'll definitely get some fierce customer support with Knu in case anything goes wrong.
  5. #20
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: Need amp advice
    Knu KCA 1/0 Kit:
    Copper Clad Aluminum
    Knu Kolossus Fleks 0ga Dual Amp Kit (more expensive but OFC):
    http://www.knukonceptz.com/productDe...rodID=KFX-PK20
  6. #21
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Re: Need amp advice
    Well I found that hifonics is cea2006 certified where NVX I do not believe is.
    Major FALSE.
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  7. #22
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: Need amp advice
    NVX JAD1200.1 1200W RMS, Class D Monoblock Car Amplifier
    He's right. Still wouldn't recommend, though.
  8. #23
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Re: Need amp advice
    New Audiopipe Apsm-2000 - [email protected] - $170 shipped new
    alll you do is set the amp lower and this will leave some head room for later
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  9. #24
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: Need amp advice
    Quote Originally Posted by bgowdy31 View Post
    or just run the apsm 1500 for $125 and run it full tilt, those P3 would be able to handle this 1500watts
  10. #25
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Re: Need amp advice
    Quote Originally Posted by naughtyca View Post
    this would work as well
  11. #26
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
  1. Friend needing amp advice
    By woody89 in forum Amplifiers
    Last Post: 11-07-2005, 06:46 PM
  2. Need amp advice....audiobahn aw1200q's
    By nycspudz03 in forum Amplifiers
    Last Post: 07-03-2004, 02:14 AM
  3. Need amp advice!
    By birsling in forum Amplifiers
    Last Post: 02-05-2004, 08:22 PM
  4. Need Amp Advice Please
    By CalSpecBoy in forum Amplifiers
    Last Post: 01-05-2004, 05:18 PM
  5. Need amp advice
    By iufan71 in forum Wiring, Electrical and Installation Help
    Last Post: 04-21-2003, 01:06 AM
