Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 61
Reload Thread: what amp brands put out true rms and great sq?
  1. #31
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: what amp brands put out true rms and great sq?
    Quote Originally Posted by bostonkid92 View Post
    i've heard everyones opinions and the one that i really like is that aq1200d. decent price, power around what i need, i might get it. that collection of old school amps is awesome btw
    Don't let the Lanzar name fool you, sir. This amp is a beast for $240.
    Lanzar OPTI1900D (opti-1900d) Monoblock Class D OptiDrive Amplifier
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  2. #32
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,100
    15
    38 Post(s)
    4138 Post(s)
    Quote Originally Posted by mclerico83 View Post
    lanzar opti drive amps are american brick houses amazing amps
    They haven't been made in USA since the early 90's. Still not bad for Korean mid-fi
    well people say you get what you pay for but i'm looking at the audioque aq1200d and it's only $269 which isn't bad at all in my opinion. i have never dealt with any of the higher end brands for amps like audioque. should i just go with the aq1200d? would it be reliable? would it be pretty well rounded in the sense that i could use it for testing small and big setups? also, would it put out clean power and also put out the power that its rated for? i'm liking this amp
    Audioque 1200d is same board as the MB quart 1500.1, Sundown SAE 1200D, and IIRC one of the Hifonics amps. I suspect the DC 1.2K is the same thing and probably a handfull of others. AQ seems to be competitive prices and those amps are decent for the money.
  3. #33
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    I personally would buy a Soundstream TN1.1200D or PPI Phantom D1000.1. These share the same board. It's an honestly rated amp that will give 1000watt RMS power with 2ohm impedance and about 600 at 4ohm (there is a discrepancy in power output ratings because the PPI was supposedly underrated by an accident). I'd suggest this over MB Quart, Hifonics or their derivatives. If you head unit can send only stereo signal on subwoofer outs (like many Kenwood excelon), then this could be a problem because MB Quarts do not sum their left and right signal, requiring using an rca splitter (see the quart manual on this). I have some SQ recordings, where, to my ear, left and right signal is different even in bass region, so I wouldn't want to throw away something from bass frequency response by using just one channel for subwoofer amp input.
  4. #34
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    Quote Originally Posted by audiobaun View Post
    Nothing Wrong with Lanzar Opti amps at all..Id run that before Id run the MB, or Cadence,or Audiopipes..Lanzar Opti amps are great amps
    lanzar opti over mb, cadence, audiopipe except the cadence a7hc i posted. thats a legendary cheater amp designed by steve manntz of zed audio. built in america amazing amp. i have owned many and one of my fav of all time.
  5. Likes denim liked this post
  6. #35
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    sir if you want a general amp i would get a jblp power 1200 for one reason it runs at 1 ohm and 2 ohm final load with the same power. so if you are testing subs out you will have a lot more options.
    JBL BP1200 Amplifier | eBay
    JBL Power Series BP-1200.1 600W x 1 Mono Subwoofer Amp at Crutchfield.com
    underrated amp that does 1200 plus watts at 1 ohm and 2 ohm.
  7. #36
    slam's Avatar
    slam is offline CarAudio.com Veteran
    Oct 2005
    fort worth, tx
    45
    5,470
    52 Post(s)
    I believe hes talking about the older lanzar amps. like the 2500 optidrive and others
  8. #37
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    Quote Originally Posted by slam View Post
    no the new lanzar opti's are great korean boards
  9. #38
    brianashadow's Avatar
    brianashadow is offline Junior Member
    Oct 2012
    Florida
    4 Post(s)
    Icon11 Re: what amp brands put out true rms and great sq?
    I am in the same boat. I have a Sundown SA-8 2ohm DVC, and I need a small (under my pass seat of Jeep Cherokee) powerfull amp that does not draw a lot of power and is 1ohm stable.
    I am almost 100% sold on the Earthquake MiNi D2000. I like that it is effcient, small (ish), not too expensive, and when I called Earthquake, Boom: Answered the phone and my questions about build quality. They said this amp is assembled here in the US, and I know that's not the same as built here, but it's still kind of good.
    I haven't been into car audio since 1996, so I am trying to learn what is right or wrong. I used to have a 1993 Mustang hatch with 2 Hollywood Excursion 12" pushed by a 2400W Power Aucustic amp. It did 147.3dB on the dash.
    Obviously I want the most bass possible, but I also need the amp to be small and powerful. Thanks for your help.
    BA
  10. #39
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    Quote Originally Posted by brianashadow View Post
    BA
    MMATS Amplifier Class D D1600.0 1ohm stable | eBay
    much better amp and deal
  11. #40
    Oct 2012
    Florida
    4 Post(s)
    Does this amp require me upgrading my battery and altenator? What kind of power can I expect at 1ohm?
  12. #41
    The Silverman's Avatar
    The Silverman is offline CarAudio.com Elite
    May 2009
    Earth
    864
    91 Post(s)
    Does this amp require me upgrading my battery and alternator? What kind of power can I expect at 1ohm?
    Battery and Big 3 first to reduce voltage drops. Then the alternator if those two aren't enough. 1150 @ 13.8 volts.
    Pioneer AVHX3800BHS
    Sub: IA Lethal Injection 10
    Speakers: Morel Tempo Untra Integra 602 (Front) Morel Tempo 6c (Rear)
    Refs thegreatestpenn, mdereske, CRX_620, Spooney, Papito
    http://www.caraudio.com/forum/showthread.php?t=418751&highlight=esilvers
    http://www.caraudio.com/forum/showthread.php?t=441801&highlight=esilvers
  13. #42
    Oct 2012
    Florida
    4 Post(s)
    Quote Originally Posted by esilvers View Post
    What are the big three?
  14. #43
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    I just saw that on ebay today before seeing this posting..Thats a great amp,and a small footprint,and getting hard to find,especially in that prestine condition
  15. #44
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    nothing compares to a Zed made amp in my opinion,,I collect Zed amps,Mainly Autoteck BTS series,and white Mean Machines,and Hifonics VII/VIII series amps..Im running 2-BTS Bass Thrust 7150s on 4-1k [email protected], and head room to spare..love em
  16. #45
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Yes sir, you are correct such as this one here
    Lanzar OPTI 50c Car Amplifier | eBay
  1. SD8000 amp... supposedly puts out 12k RMS at 12v?!
    By Farmacist in forum General Discussion
    Last Post: 04-12-2009, 04:06 AM
  2. Replies: 10
    Last Post: 09-12-2008, 03:53 PM
  3. What amp will put out ~2500 rms at 1.4 ohms?
    By cleanerupper in forum Amplifiers
    Last Post: 09-25-2006, 07:42 PM
  4. does an amp really put out what it says in rms????
    By hardrockfan in forum Amplifiers
    Last Post: 09-11-2004, 10:30 AM
  5. what amps put out true RMS?
    By FLEX4U18 in forum Amplifiers
    Last Post: 05-13-2003, 07:50 PM
