+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Reload Thread: Amp to run with 2 12'' Kicker L7's at 4ohms
  1. #31
    Brandon1024's Avatar
    Brandon1024 is offline Junior Member
    Sep 2012
    Chicago
    20
    Re: Amp to run with 2 12'' Kicker L7's at 4ohms
    Quote Originally Posted by Jerhemy View Post
    Nice man I like the jeep! The stock alternator that came with your vehicle should have plenty of amperage to supply the stock accessories, with a bit of excess. Which hifonics did you end up going with?
    Thanks thats my main hobby but who doesnt like a nice sound system in it? Well I went with the hifonics 1700.1 but then an Alpine PDX-M12 came up in the classified and I picked that up for 300 and worked it out with the seller of the 1700.1 to not end up getting it. Worked out for both of us. The Alpine is what I really wanted but the price was way to high... Until this one popped up. So ill be running them each at 600 rms at 4ohms. For an everyday system id rather do that then 1 ohm. And a have a bit more than stock accessories. and will have more to come. Running a winch, lights, compressor, lockers, and more all off it would kill it.
  2. #32
    Jerhemy's Avatar
    Jerhemy is offline CarAudio.com Elite
    Feb 2012
    WI
    1,776
    9 Post(s)
    damn, you're already gonna have some serious amp draw from those accessories. at least you won't be bumpin and using your winch at the same time. Winches use serious power if I remember correctly.
    Sounds like you've got it figured out man.
    post pics of the install when you get it done.
    In the process of being installed:
    (2) DC-Level 3's
    Kicker ZX2500.1
    (2) Kinetik 2400
    Optima YT under the hood
    240amp Mechman alt
    Big Three in 1/0 Monster
    4 Runs Knu KCA 1/0 front to back
    8" Aero by Psychoacoustics
    2008 Volkswagen Jetta S
  3. #33
    Sep 2012
    Chicago
    20
    Yea I definitely do. A dual batter set up is to come soon. The winches grab a TON of power. Took long enough and a little more than I wanted to spend but its figured out. I was going to build a custom box but I cant make it the size I need to so I am trying to find a kicker box and then I will do custom boxes,storage,etc around that to make it fit tightly where I am putting them. Now just to find that box.
+ Reply to Thread
  1. Need to buy the BEST amp for 2008 2 12" Kicker L7 2 ohms final
    By Harsh Patel in forum General Discussion
    Last Post: 03-05-2011, 09:46 PM
  2. good amp to run 2 12" cvx kickers
    By vandiar2 in forum Amplifiers
    Last Post: 12-05-2008, 09:14 PM
  3. amps to run 2 12" d2 subs
    By MikeGray in forum Amplifiers
    Last Post: 01-02-2004, 03:40 PM
  4. Which amp to run with this HU?
    By crewd in forum Amplifiers
    Last Post: 11-15-2003, 11:41 PM
  5. need a good amp to run 2 15" kickers
    By nolimit1386 in forum Amplifiers
    Last Post: 12-04-2002, 10:57 PM
